Question about RCA P61927 61" Rear Projection Television
61 in rca model # hd661w66
My tv wont come on the on button just keeps on flashing green. it will even flash green after i unplug the tv. why is this?
  • littlebut Feb 03, 2008
    what exactly is the power supply/deflection board and where can i get one? how much does it cost?
    Problem Solver:
  • 40 Answers
???...if course the green LED will go off ater a few seconds of unpluging it...LOL...anyway....power supply/deflection board will solve this problem
Posted on Feb 03, 2008
My flat screen Sylvania TV is flashing different colors what's wrong
Better late than never. The problem is that your TV is in the service mode. There are many ways this can happen. But, lets just get down to fixin this! With the original remote and the TV on. If the TV will not shut off, do this. Press the left cursor button on the remote, followed with pressing the right cursor. Power off the TV with remote, or press off button on TV.
Secondly, your TV will power on and off. But you have flashing colors. Do this. With the original remote and TV on. Press the up cursor button, on the remote, followed with pressing the down cursor. Power off TV with remote, or press off power of TV. Thanks for asking me, Matt of Martins TV Repair.
Jan 20, 2016 | Sylvania Televison & Video
RCA rear projection 61
why did you take apart the lenses did you take other parts a loose. may you unpluged a conniction or you need to back trace what you did if it was working before you did it. did you open the tubes
May 28, 2012 | RCA D61W20 61" Rear Projection Television
We have a flashing power button on front of TV, and wont turn on.
your bulb well tv lamp is probably no good there is a cover on the side you can remove and check the bulb make sure you do this with the power cord unplugged if the bulb is bad, advanced lamps.com has the best deals for replacement bulbs about 120 dollars
Mar 15, 2010 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Tv wont turn on but green power lite flashes 3 times if i use the remote or press power button on front of tv i have unplugged tv replaced the batteries in remote trouble started 2 weeks ago if i hold...
it sounds like youre describing a RCA HDTV which needs the CP150, CP120 and CP114 repair kit. You can get that repair kit at www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Sep 22, 2009 | Televison & Video
MY 61 IN RCA MODEL # HD61W66 WONT COME ON ALL IT WILL DO IS THE ON BUTTON WILL FLASH GREEN ABOUT 9 TIMES THEN PAUSE AND START AGAIN BUT IT STILL WONT COME ON.CAN SOMEONE HELP ME?
Ur BD power board is dead.It have many burns capacitors.Must rebuild the board by replacing caps and other cause by the caps.Or replace the whole board.Tries these Websites.Shopjimmy.com.Tv Repair World.com.
Aug 04, 2009 | RCA HD61W66 61" Projection HDTV
RCA 52inch HDTV (2004 model) green power light flashes 3 times
Replace the flyback 259296 and the cp150 You can get the aprts with detailed instruction on how to do the repair at the following link.
http://servicemanuals.vstore.ca/
Jun 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
The green button will flash so its got power but tv wont turn on
your lamp has gone bad your going to have to buy a new lamp for it
Mar 29, 2009 | RCA P52926 52" Rear Projection Television
Tv won't come on
Typical reset sequence is: unplug the set, press the power button a few times ( Yes, with the set unplugged ). Then, hold the power button down and at the same time ( maybe with your other hand ) plug the set in. If that doesn't do it, there may be a button marked reset on the back of the set. If there was a lightning strike nearby, your set is probably toast. The antenna or cable brings it into the house.
Dec 26, 2008 | RCA R52WH76 Television
Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Oct 12, 2007 | Mitsubishi VS-50707 50" Rear Projection...
RCA P61927 61" Rear Projection Television Logo
63 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
