Fax machine it won't clear the memory.
  • mo101 Feb 04, 2008
    sharp ux-300 plain paper facsimile it just won't let me clear the memory. how can i clear it thanks mary
I lost my manual, I do you retrieve the fax in the first place, please help.
Posted on Mar 01, 2008
  • 63 Answers
Hello FixYa user,
Please include a bit more details and what model you have otherwise yoiu will have no chance getting an answer!
Hope this helps - Josh
Posted on Feb 03, 2008
  • Josh Howard
    Josh Howard Feb 04, 2008
    Thanks Mary,
    Apparently with that model the silly manufacturers did not put a reset button anywhere So it is clearly impossible to reset memory. But if you ring Sharp on they MAY/MAY NOT provide you with a new fax or details to clear the memory!
    Also thanks for the rating!
HOW TO CLEAR MEMORY ON FAX MACHINE
Most likely the memory is full because your fax machine either can't print what is in the memory (check paper, ink, etc), or it can't send out faxes you've already scanned into it. (check phone line and ability to dial).
To clear the memory, unplug fax from phone and wall, wait 30 seconds, and plug back in.
Jun 15, 2015 | Panasonic Office Equipment & Supplies
What is a 116-386 error code
Resetting to Factory Defaults / Clearing the Memory
You can selectively clear information stored in your machine's memory.
  1. Press Menu on the control panel until Maintenance appears on the top line of the display.
  2. Press the scroll buttons until you see Clear Memory on the the bottom line and pressEnter.
  3. The first available menu item, Paper Setting, displays on the bottom line.
  4. Press the scroll buttons until you see the item you want to clear.
    • Paper Setting: Restore all of the Paper Setting options to the factory default.
    • Copy Setup: Restores all of the Copy Setup options to the factory default.
    • Fax Setup: Restores all of the Fax Setup options to the factory default.
    • Fax Feature: Cancels all of the scheduled fax jobs in the machine's memory.
    • Advanced Fax: Restores all of the Advanced Fax setting options to the factory default.
    • Sound/Volume: Resets the sound and volume settings to the factory default.
    • Machine Setup: Resets all of the system settings, such as the machine ID, date and time, display language and save modes, to the factory default.
    • Set Report: Clears all records of your faxes sent.
    • RCV Report: Clears all records of your faxes received.
    • Phone Book: Clears the speed dial or group dial numbers stored in the memory.
  5. Press Enter. The selected memory is cleared and the display asks you to continue clearing the next item.
  6. Repeat steps 2 and 3 to clear another item.
  7. ORTo return to Standby Mode, press Stop/Clear.
http://www.support.xerox.com/support/enus.html
May 08, 2015 | Office Equipment & Supplies
How to I retrieve a fax that is stored in the memory and also, how do I clear the memory
If you run out of ink, paper, or the machine jams the fax will be stored in memory. After these conditions are cleared the "stored fax" will print and automatically clear from memory.
You can download the manual here ...
http://pdf.textfiles.com/manuals/FAXMACHINES/Panasonic%20KX-FHD331%20Plain%20Paper%20Fax.pdf
May 12, 2014 | Panasonic KX-FHD331 Plain Paper Thermal...
Clear memory of Brother intellifax 2900
with this model, power the Brother fax machine off with the power button, then, while holding down the Stop button, power the fax machine back on. Keep the stop button held down for a few seconds. That should clear the jobs resident in memory.
Aug 19, 2009 | Brother IntelliFax-2920 Plain Paper Fax,...
Fax running slow
try unplugging machine. then press and hold "stop/exit" button while plugging in machine. continue holding button for 5 secs, then release. that is a procedure to clear any faxes stuck in memory.
hth,
razors
Feb 18, 2009 | Brother IntelliFAX 4100 Laser Fax
FO 5700 Won't print from memory
You have memory lock up. to ram clear the machine we need to clear out all memory. ( like it came out if the box )
1. have machine turned on
2. press 8,*,9,#.7 ( this will git you in to the programing of the fax )
3. press start
4. press the # key till memory clear
5. press start !( will clear out all memory )
it should print out a memory clear report
6 press stop key 2 times now lets se how it worked
let me know
good luck
Jan 28, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Clearing memory Brother 8360p
Press quickly......MENU 2864 then press 91
Oct 16, 2008 | Brother FAX-8360P Plain Paper Laser
Brother fax 560
Try this: Press MENU, select FAX, then scroll down to REMAINING JOBS. If any jobs are displayed , you can choose to print them. To print from the fax memory, first exit out of the MENU functions totally. Then, press MENU,2,5,4. Next, press START. After all faxes in memory have printed, press STOP/EXIT button. Check REMAINING JOBS again, if it is clear, fax memory should be clear, Also.If the fax machine has a PRINTER function, press the JOB CANCEL button to clear the print Queue.
Apr 15, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Memory on my fax machine
just do this menu # 9000*550 start memory will bi cleared.mian jee
Feb 23, 2007 | Panasonic KX-FB421 Plain Paper Film Fax
189 people viewed this question
k24674
jasbo
jasbo
