Sony TA-AX301 Amp looses left speakers
Left speakers go off and on? Mostly off.
    Problem Solver:
  • 5 Answers
Many times this problem is the result of dust and or dirt that has collected in your control pots.ie.volume,balance etc....the solution is usually to take the amp apart to get to the pots and clean them out with tuners cleaner or some such product...a quick fix would be to rapidly move the knobs side to side or press the buttons or toggle the switches as fast as you can in hopes of clearing some of the particles from the affected area...
Posted on Feb 03, 2008
Will a ipod player play in my sony TA-AX301 AMPLIFIER-No sound
You need a 3.5mm to stereo phono/RCA cable
Plug the red and white ends in to any of the following sockets that are free - Tuner, Tape In, CD, Aux, Video In. They all do the same job. The names are just suggestions, they're not mandatory.
Plug the headphone jack plug in to the MP3 player's headphone socket. Turn the volume up on the MP3 player to about half way. Then select the source input on the amp that matches where you plugged the cable.
That's it. Hope this helps..
Sep 16, 2014 | Audio Players & Recorders
Can i get my ipod player to play in my sony TA-AX301 AMPLIFIER-No sound
How can i get my ipod player to play in my sony TA-AX301 AMPLIFIER-No sound
On the iPod, (or the Doc) is a 3,5 mm socket, where the earphone or speakers go in. On your Amplifier, are two gulp entrys, called line input. Just use (perhaps you still have to buy one) a cable from 3,5 mm Stereo, to 2 tulip plugs to connect both. Then when playing, test the volume you should put the iPod top, so your amp can handle he signal and the sound through the speakers sounds good. Then use the volume knob on the amp to fine adjust.
The amp was build in a time there were no iPods, so don't expect an USB entry o that one.
Cable you need:
Sony ta av431 Stereo Amp Front speaker do not
Have you check your sound configuration at front panel?
Oct 09, 2013 | Audio Players & Recorders
I NEED A RIBBON CONNECTOR FOR A SONY SYSTEM MODEL TC-W301,ST-JX301,TA-AX301
You should be able to get the length and conductor count from Digikey, as well as the Berg/Tyco type connectors. They may not match the originals, but they should work fine. Otherwise your best bet is Ebay.
Oct 24, 2012 | Sony Audio Players & Recorders
Voice of both left and righ speaker is not equal
Can say I've seen this on a H/K. First swap the speakers left to right and right to left if the sound is low on the same speaker its the speaker not the receiver (could have a driver out). Could also be a dirty output relay.
Is the sound good other than it being low?
Is it that way with all inputs?
Jul 17, 2010 | Harman Kardon AVR 25 MKII
No sounds from the left speaker even with the balance turned fully to the left. all connection are fine.
Check the speaker, switch the left and right ones and see if the left speaker still has no sound. If it works the speaker is bad, if it doesnt your left output is bad...
Dec 06, 2009 | Sony TA-FE370 2-Channel Amplifier
My left speaker to my Sony HCD-GX450 stereo is
Make sure that Loudness switch is turned off & bass is not boasted up. Most cars have small cheap speakers that can't handle the bass. also its better to cut the low frequency from the woofer using a passive or active crossover. Most nowadays head units have got some sort of built in crossover. Refer to your head unit manual.
Sep 20, 2009 | Audio Players & Recorders
AUDIO AMPLIFIER'S ONE CHANNEL DEAD
Hi there.
Check for shorted speaker wires on left channel. If not, disconnect speaker wires and check to see if headphone jack works. If left works, you may have a blown speaker. If left still doesn't work, left power amp blown.
Thanks
Paul
Jul 06, 2009 | Sony Audio Players & Recorders
Sony TA-VE100
First of all check for loose connections. Also see if the left front audio output is working or not.
Jul 17, 2008 | Electronics - Others
537 people viewed this question
 Grubhead
Grubhead
