Question about Sharp UX 300 Plain Paper Thermal transfer Fax
Sharp ux-300 it won't let me clear the memory it keeps printing the same item
  • 1 more comment
  • mo101 Feb 05, 2008
    very helpful info. thank you so much!!!!! appricate your time. thanks mary
  • mo101 Feb 19, 2008
    my husband took care of the problem he took it all apart and threw the sharp fax machine away.
  • kilane38 Jan 30, 2009
    I have the same problem but I don't see the posted answer on this site. My Sharp UX-300 won't let me clear the memory and keeps printing the same item. Worse, when I send a fax the receiver gets a black page. Hope someone can help
    Problem Solver:
  • 5 Answers
I dont see any solutions????
Posted on Dec 15, 2009
Posted on Feb 19, 2008
  • 63 Answers
You are going to be banned if you keep making posts for the same problem! I gave you details on your latest post ok!
Hope this helps - Josh
Posted on Feb 03, 2008
How do I clear the memory and stop the print..
Surely I can clear the memory without wasting a stack of paper! But how?
May 26, 2010 | Sharp UX 300 Plain Paper Thermal transfer...
Sharp ux a1000. I need to clear the memory. Can
Just unplug the machine.
When the power supply is interrupted (intentionally or due to power failure) the memory is cleared.
Download the manual from here:
http://www.sharpusa.com/files/fax_man_UXA1000.pdf
Aug 09, 2009 | Sharp INKJET FAX UX-A1000
UX-B800SE Fax
I had the same "Full Memory" problem & called Sharp. You need to unplug the fax, then hold (press down) on both the "Start/Memory" & the "Stop" buttons at the same time. While holding them down, plug the fax back in. After it's plugged in, you may need to press the start button again. That should clear it.
Aug 02, 2008 | Sharp UX-B800H Fax
How to Clear Memory in Sharp Fax UX P115
call sharp tech support (905 568 7140) for instr. they are very helpful and will guide you thro' the deleting memory process in madel ux-p115.
thanks
lk
Apr 11, 2008 | Sharp UX-P115 Plain Paper Thermal transfer...
Sharp fax to receive
Switch off the fax. press the stop key and power up the fax again, keep pressing stop button. memory clear will appear. press start and the memory will clear.
enjoy
Viren
Nov 25, 2007 | Sharp UX P200 Plain Paper Thermal transfer...
Line error
I have a Sharp UX-300. When I get a line error, the easiest way to clear it is to unplug the fax machine from the power outlet and let it stand for at least a minute. Then plug it back in to the power outlet. If this does not clear the problem, use a regular phone to check if the phone line between the fax machine and the wall is 'OK'.
Nov 15, 2007 | Sharp UX 355L Plain Paper Thermal transfer...
Al-1551cs / L!
Sharp Error Codes
Sharp ram clear (most models with LCD displays)
Press function 9 * 8 # 7 then # or * until display reads memory clear, then press start. Note the other maintenance mode options displayed on the screen when pressing # or *.
Sharp UX-170 maintenance mode: Turn power on, set the line selector at "T" (tone), turn the program switch ON, then press 9 * 8 # 7. Select the next entry from this list: 01 all black copy, 02 ROM/RAM check, 03 auto feeder mode, 04 aging mode, 05 panel check mode, 06 G3 transmission, 07 check pattern, 08 product check (includes diags, 06, 03, 09), 09 signal send mode, 10 memory clear, 11 led array on mode (lamp), 12 product program sw mode, 13 telephone number list printing mode, * soft switch mode, # transmission level. This same procedure works on similar, older models that do not have an LCD display.
Sharp UX-2100 often has power supply problems which cause the unit to lock up.
UX-3200/FO-3250: FO32TD toner/developer costs less than UX30TD and will work in the UX model if 2 fins are broken off so that the unit can be installed in the UX model. Similar duplicity exists with many Sharp laser supplies.
Sharp FO-4800: fuzzy print often results from a bad Motor PWB (polygon mirror) #RMOTN0020GCZZ located in the optical unit.
Nov 06, 2007 | Sharp AL-1551CS Printer
UX A460 Paper Jam during fax reception how do I prinmt from the memory
open the machine and clear the paper jam and then closed.The machine will start printing again.
Oct 17, 2007 | Sharp UX 108 Roll paper Thermal Fax
Sharp UX 300 Plain Paper Thermal transfer Fax Logo
391 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
