Question about HP OfficeJet 7410 All-In-One InkJet Printer
HP 7410 streaks when using auto document feeder to make copies
I get a black streak (when making B + W copies) or a red streak (when making color copies) about 1 inch from the edge when using my HP 7410 printer's auto document feeder to make copies. I experience no problems when lifting the cover and placing the original flat on the glass to make either color or B+W copies. I am puzzled by this.
    Problem Solver:
  • 18 Answers
Good, so u are having probs in ADF. Open the cover, lift the rollers and u can see the scanning glass. Take a lint free cloth and clean it. it will be ok.
Posted on Mar 17, 2008
    Problem Solver:
  • 10 Answers
The above solution is 100% correct. If it doesn't resolve it, clean it some more. I'm sure even after one cleaning you'll notice a huge difference.
Posted on Mar 21, 2008
SOURCE:
How do I fix this
Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans
support.hp.com/us-en/document/c02881567
Figure : Sample output with vertical colored bands or lines ... Remove any paper from the automatic document feeder (ADF) tray. ... To protect the scanner, do not spray the glass cleaner directly on the glass. .... determine if your printer is still under warranty, and then Contact HP Support to schedule a repair or replacement.
How to get rid of lines on a copied page - YouTube
? 2:10
https://www.youtube.com/watch?v=xTJpCg5sHl0
Feb 17, 2010 - Uploaded by Wayne Springer
When you make copies on your copy machine, does it ever leave a black vertical line ... QLS ' How to Eliminate Vertical Linesfrom Scans, Copies & Faxes ... Part 2- Fix or repair color laser printer with fading, light print, or lines ...
Dec 29, 2015 | Office Equipment & Supplies
When using the auto feed, copies come out with black streaks down center of page
If you only get streaks when using the automatic document feeder, then in most cases it is dirt on the scanner glass. You do not state model but if you can also scan flat objects, trying copying a piece of paper that way. If that copy comes out fine, then you definitely have dirty glasss, if that copy has streaks you either have dirt on the scanner itself or a faulty scanner unit.
May 08, 2015 | Office Equipment & Supplies
Scan streaks with HP LaserJet Pro 200 color MFP M276nw
This may not always be the solution, but in my case it was. If you are getting black streaks on your copies, try this first:
The problem is that that there a small piece of glass that the doc feeder use's to scan the original. You will have to clean the small glass it's about a half of a inch piece and is normally under the doc feeder unit. It will either be to the right side of the main copy board glass or it is under the doc feed unit where the paper goes down through the feeder. It is mostly some white out or other residue, on the glass, just clean with a monitor wipe or take a cloth & wipe, etc...... Good Luck
Online tip from Chris Coughlin, but I changed a few of his words.
Feb 05, 2013 | HP LaserJet Pro 200 color
I have a black streak all on one side when i copy ?
If it is just when you copy and not when you print then it is a cleaning issue. Toner cartridge would cause the line to appear on copies, printouts and faxes. There is a piece of glass inside the auto document feeder that is probably dirty. Open up the document feeder as if you were clearing an original document jam. Look for a piece of glass inside the ADF, it will run the length of the document feeder. There is probably some dirt or another popular problem is white out. Clean off the glass with glass cleaner or alcohol and it should fix the problem.
Oct 04, 2009 | Brother IntelliFAX 4100 Laser Fax
Black streaks on copies. Gestetner 1302 How do I get rid of them
Do the streaks appear when you use the contact glass or just when you use the Automatic feeder?
If both, then you need to replace either the (drum unit) or the fuser roller(s).
If it just happens through the auto feeder, then lift up the "feed-in section" (left side) and clean the narrow scanner glass.
Mar 11, 2009 | Gestetner DSc224 Copier
HP Officejet 6300 All-in-one machine makes black streaks
The problem is that that there a small piece of glass that the doc feeder use's to scan the orginal. You will have to clean the small glass it's about a half of a inch piece and is normally under the doc feeder unit. It will either be to the right side of the main copy board glass or it is under the doc feed unit where the paper goes down through the feeder. It is mostly some white out on the glass, just clean with a dam cloth with water or windex..... Good Luck
Nov 15, 2008 | HP 190 Copier
the document feeder of that unit have its own scanner glass. try opening the document feeder and clean the scanner glass with a lint free cloth that is moist with water and also clean the rollers of the document feeder
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP Office Jet 7410 - Streaks in photos
try this link. copy and paste it into your address bar.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00219809&cc=us&lc=en&dlc=en&product=391194&dlc=en&lang=en
also you can search at the top for answers to other problems if this does not help.
Nov 21, 2007 | HP OfficeJet 7410 All-In-One InkJet...
Streaks
It sounds like the lamp/light is going out.  Open the top and try to make a copy and see if the light stays on the entire time.
Erice
Oct 29, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP 7410 streaks on scanning and copying
First you need to determine if it's doing from both the  top and the glass.
1-assuming you are using the feeder to fax,copy or scan (the part that automatically picks up the paper) it comes out with a streak. Make a copy putting the paper on the glass and look at the copy. Does it have the streak?
2-lift the top and look to the left there should be a small 1inch glass, this is where it makes the copies from the feeder, is there a dot or white out or is the glass dirty? that's your streak, the paper is moving to make the copy,so the dot now looks like a line as opposed to making a copy on the glass it just sits there so a dot will stay a dot.
2- Clean with water or alcohol.
Oct 23, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
307 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
