Question about Sony DAV-C990 System
DVDs play in black and white
5 year old system started flipping out, first had red blinking power light, now audio works but DVDs play in black and white. Sounds like a power supply issue, but that's just a guess. Any opinions before I use it as a door stop?
  • 38 Answers
Try use connect your dvd player with just RCA(composite video) and see if you get regular color picture.If so,you need to go to the system menu to check the video output and see if it is under R Pr Pb-component video setting?If not,be sure to change it to component video setting AND use component video cable to connect to your TV unless your TV don't have this connection.
Joe
Posted on Feb 04, 2008
My Phillips HTS3520 plays DVDs fine and the sound is excellent. However, it is not playing the TV channels thorugh the theatre system.
Without more data, I can only make some general suggestions.
First: Check your cables. If you are using a converter box, there must be a set of audio and video cables going from the cable box to the Home Theatre unit. These will be a yellow/white/red set of cables. Second: If these cables are plugged into "AUX1" or "AUX2" make sure this is what reads on the front of the HT unit. You already have cables going from the HT to the TV because your DVD works.
Although this sounds obvious (please forgive me-I am not underestimating you) IF your TV receiver is 6 years old or more, and you are NOT using cable or satellite, there will be nothing for your set to pick up since the conversion from analog to digital.
Jun 05, 2011 | Philips Audio Players & Recorders
Will not power on.power switch is flashing repeatedly red/white?
My same BD8200 unit did the red and white blinking on the start button and tech support could not solve the problem, unit is 13 months old and junked.
Jan 16, 2011 | Samsung HTBD8200 BluRay Sound Bar Home...
Blacked out screen
If the power light is blinking amber – The computer is receiving electrical power, but an internal power problem might exist.
Ensure that the voltage selection switch is set to match the AC power at your location (if applicable).
Ensure that the processor power cable is securely connected to the system board (see page 73).
flip off the surge protector and then flip it back on.
Jan 26, 2010 | Computers & Internet
Coby DVD-937 playing DVDs in Black and White
you did not connect it to the right port in you tv with the right cables. if it came with a cable using red, blue, and green wire you need to connect all three to the appropriate place on the tv in this case the red is a video cable and not audio they are white and black in component video... if it is the other way around you have a red white and yellow cable the red and white are audio and yellow is the only video and needs to be connected to a yellow jack on the television
Jun 23, 2009 | Televison & Video
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Philips LCD TV - Red blinking lights
I would check the capacitors on the power pack for failed or blown ones. doing this work will require soldering skills
FYI
Mar 21, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Playstation 3 at power on, light becomes white then blinks red
Probably and overheating problem. Here's what I suggest:
Try using some compressed air and cleaning the vents out below. If that doesn't work then you'll have to remove and replace the thermal compound on the GPU and CPU.
You might also consider a System Restore if you can do it before it shuts off.
Jan 24, 2009 | Sony Playstation 3 (PS3) Console
Colours
Hello, imho you must initialize your jvc.
Follow the instructions:
(1) Unplug the power plug.
(2) Insert power plug into outlet while pressing both "PLAY" key and "STANDBY/ON" key of the main body.
"Area code" is indicated at the upper left of display.
(3) Press "PAUSE" key of the main body.
(4) When initialization is completed, "00" and "RDS" is displayed in the FL display.
(5) To release test mode, press "STANDBY/ON" key of the main body.
(6) Now unplug the power plug an insert it again after a 5 seconds.
Be carefully and press no other key then the list above.
Now it will be work fine again.
I hope it would be helpfully.
Aug 27, 2008 | JVC TH-S5 System
Color to black and white and back again
Since you're using a composite cable (yellow RCA) that carries both luma (brightness) and chroma (color) information, it's not the cable that is the problem.
That means it's either the DVD player itself, or the TV. If you have another video device (VCR, etc) that you can connect to the TV, try that. If the other device also goes from color to black and white, then it's your TV. Otherwise the problem is your DVD player.
Since your TV only has mono audio (white RCA, but no red) I would recommend getting a new TV if the TV is to blame.
Jun 13, 2008 | Sony DVP-NS57P
Have a panasonic 47" HDL projection tv..under 5 years old model # pt-47wx53g, chassis Ap 825,manufactured August 2003 Purchased Oct. 2003. Have cable service..TV works fine until 2 weeks ago. Screen...
3 blinks means the convergence circuits are shutting the set down. Usually the convergence ICs will take care of the problem, but I would recommend getting the service manual from the following link, as they will provide you free support to help you diagnose why it wont start as usually the convergence ICs wont prevent a set from powering up, unless another component in the convergence circuit has failed.
http://servicemanuals.vstore.ca/
Mar 24, 2008 | Televison & Video
Sony DAV-C990 System Logo
145 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
