Question about RCA R52WM24 52" HDTV Projection Television
Cannot find code number for programming remote control. the brand of tv is DURABRAND. THANKS
    Scholar:
  • 76 Answers
Some universal remotes have a SEARCH function that allows you to try ALL of the codes. This method tells you that you have a working code when the TV power button on the remote works during the code search. I recommend that as you do the code search that you do it slowly and count each time you hit the button for the next code. Then the next time you change the batteries you will know to hit the code search button say 79 times. This should work!
Posted on Mar 08, 2008
  • 934 Answers
Try this site: http://www.remotecodelist.com/remotes/
You'll need the remote you're trying to program, then follow it to a link that will give you the codes for what you're attempting to program it too..
Bill
Posted on Feb 03, 2008
How do i program my tv i dont have the remote its a 2004 057141221650 is one number not sure which one and i have this number to 7-55805020561
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites Check this site too.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
Feb 24, 2016 | Durabrand DU1901 TV
I need a code for RCA remote RCR311STR for a Durabrand television model BH2004D.
In order for the 4 component universal remote to control your TV, you must program it with the TV code that matches your TV. These instructions explain the preferred method of programming the remote-the Direct Entry method.
  1. Manually turn on the TV.
  2. Locate the enclosed TV Code List. Find your brand of TV.
  3. Press and hold the CODE SEARCH key until the indicator light illuminates. Then release the CODE SEARCH key.
  4. Press and release the TV key. The indicator light blinks and then remains lit.
  5. Use the number keys to enter the first code listed for your brand. After you enter a valid three-digit code, the indicator light turns off. Note: If you enter an invalid code, the LED flashes rapidly for two seconds. Start over at step 3.
  6. Aim the remote at your TV and press the ON•OFF key. If your TV turns off, you have found the correct code.
  7. Write the code down for future reference.
  8. If your TV doesn't turn off, repeat steps 3-6 above, entering the next code for your brand. If none of the codes work or your brand is not listed, use one of the Code Search methods to program this remote.
Program for VCR: In order for the 4 component universal remote to control your VCR, you must program it with the code that matches your VCR. These instructions explain the preferred method of programming the remote-the Direct Entry method.
  1. Manually turn on the VCR.
  2. Locate the enclosed VCR Code List. Find your brand in the VCR Codes.
  4. Press and release the VCR key. The indicator light blinks and then remains lit.
  5. Use the number keys on the remote to enter the first code listed for your brand. After you enter a valid three-digit code, the indicator light turns off. Note: If you enter an invalid code, the LED flashes rapidly for two seconds. Start over at step 3.
  6. Aim the remote at your VCR. Press the ON•OFF key. If your VCR turns off, you have found the correct code.
  8. If your VCR does not turn off, repeat steps 3-6 above, entering the next code for your brand. If none of the codes work or your brand is not listed, use one of the Code Search methods to program this remote.
May 11, 2011 | RCA RCR311B Remote Control
Durabrand TV stuck on AUX mode
You can program a Comcast remote to work with the TV. Press the "TV" button on the Comcast remote. Then, hold down the "Setup" button until the red light blinks 3 times. Enter a 5 digit code:
These are the Durabrand codes: 10171 10463 10180 10178 11034
The 10171 code worked for my Durabrand DWT1905. Then use the TV/VCR button located beneath the "7" to switch inputs.
Jul 30, 2009 | Durabrand DWT1905 TV
Lost original remote to my 20" Duraband tv n cant get any universal remote to program to it. is there a code for it?
Durabrand codes are very difficult to find, only few codes are public, as this manufacturer is not listed on universal remotes user manuals.
You can find few codes on discussion groups, often they do not work. The requests usually stay unanswered:
RC Forums: Durabrand codes one for all (Page 1 of 2)
Star Choice IRC442 Remote Code for Durabrand dbtv1020
Durabrand Remote Code? - TiVo Community
Durabrand Remote Codes??
The best thing to do is purchasing a replacement remote.
You can purchase the remote opening the link below, chose your model or contact the seller to purchase the remote:
Replacement Durabrand tv remote controls .
Or:
Used Original Durabrand TV-5620-16 Remote Control
DURABRAND remote control, UK
Contact the seller to ensure you are purchasing the right remote for your model.
Thanks.
Apr 03, 2009 | iLO 3200 32 in. LCD Television
Can't find a code for tv brand D
if your tv brand says "d" buy a philips universal remote . use the brand program guide. since you don't know the brand put 0 in for the brand number. this searches all the brands . follow the directions. it works i just programmed mine .
Feb 25, 2009 | One For All URC 7740 Remote Control
Problem finding the code for my durabrand tv
Sorry it took so long to respond to you request for assistance.You will have to call RCA customer support for a answer to your question about using the remote control with a Duraband television. The customer support telephone number is 1-800-645-4994. Thank you for using FixYa and have a nice day!
Jan 12, 2009 | RCA 3-Device Universal Remote with...
Can't find a code for a Dura brand T.V.
I wish someone would bring a suit against any of these manufacturers using the term 'universal.'  At best, they are 'multibrand' and, with the proliferation of 'brands,' there never will be one that can rightfully claim to be 'universal.'
Durabrand is one of the several names that appear on Funai built consumer electronics so try those and also Emerson which now belongs to Funai.
If that is also not help, you might want to try the RCA website to see if they have an updated code list.
Dec 03, 2008 | RCA 3-Device Universal Remote with...
Cant find code to work our durabrand tv
if ur directtv remote works withy ur tv use it i have a tv that can not use certian remotres cause it has am/fm radio/dvd/vcr/tv so some remotes just are not in to off brand or multi use fuctions
Nov 13, 2008 | Durabrand BH1304D 13" TV
Durabrand tv codes
I seem to be the only person on the net with the 3 digit Durabrand universal remote code which works for 13' and up Durabrand TV's and TV/DVD TV/VCR combos. The culprit is 3 digit code 189 for a Funai and Emerson. I only know this because I have like 4 of these TV's haha.
Ron
Smellycircuits@aol.com
Feb 06, 2008 | Durabrand BH1304D 13" TV
Want to use cable remote 4 tv as well
reade the booklet that came with the cable box to get the program #'s for the remote to control you tv as well
Dec 25, 2007 | Durabrand DWT1905 TV
RCA R52WM24 52" HDTV Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
