Question about Wacom Intuos2 A6
Pointer Nib Cannot hold the pointer still. It has no precise location. when pointered onto anything it keeps jumping around on the location but nearly impossible to hit the target. Even placed on the tablem with no moment it continues to pulsate liake a magnetic pulse
  • Gary McGinty Feb 05, 2008
    I was unsure of his solution.Its no good they dont sell these parts. Does this mean return the product to the place it was purchased as no parts are available and if it an older model you sggest to purchase a new one.
    i do appreciate your assitance and do apoligise for not reponding immeadiately
    Regards
    Gary
  • Anonymous Feb 21, 2008
    I have the same problem as Gary.
    Genius:
  • 1,067 Answers
Its no good take it back they dont sell these parts
Posted on Feb 03, 2008
6ya staff
SOURCE:
My acer aspire has a roaming curser
sounds like you need to go to your control panel and go to mouse and go to pointer options and check pointer precision, uncheck snap to or uncheck display pointer trails. Your problem will be in mouse and what you have checked or not checked.
Nov 20, 2012 | Acer Computers & Internet
The cursor jumps around on my ASUS K501J notebook.
Step 1
1. Open Mouse by clicking the Start button, clicking Control Panel, clicking Hardware, and then clicking Mouse.
2. Click the Pointer Options tab, and then do any of the following:
To change the speed at which the mouse pointer moves, move the Select a pointer speed slider towards Slow or Fast.
• To make the pointer work more accurately when you're moving the mouse slowly, select the Enhance pointer precision check box.
To speed the process of selecting a choice when a dialog box appears, select the automatically move pointer to the default button in a dialog box check box.
To make the pointer easier to find when you move it, select the Display pointer trails check box, and then move the slider towards Short or Long to decrease or increase the length of the pointer trail.
To ensure that the pointer doesn't block your view of the text you're typing, select the Hide pointer while typing check box.
To find a misplaced pointer by pressing the CTRL key, select the Show location of pointer when I press the CTRL key check box.
Change mouse settings
http://windows.microsoft.com/en-US/windows7/Change-mouse-settings
Step 2
If you are using touchpad, try reducing the Touchpad sensitivity and check
1. Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers."
2. Select the "
Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop.
3. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "
Apply."
4. Pick the "
Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings."
5. Read the information provided in the next dialog box. It gives you options for tapping your
touchpad, using the buttons, scrolling, pointer motion and sensitivity.
6. Make any changes you want from the various topics. When you make a change, click "
Apply." Click "OK" when you finish making all your changes.
7. Do some work on your computer for a while, If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
Step 3
If the issue persists try to perform a clean boot and check whether the issue is still persists.
Follow the steps mentioned in the article given below.
How to configure Windows Vista to start in a "clean boot":
http://support.microsoft.com/kb/929135
Note:Once the troubleshooting is over, reset the computer to start as usual.
Also I would suggest you to keep in touch with mouse manufacturer
Oct 08, 2012 | ASUS K50IJ Notebook
Cursor jumps all over the place. My husband is ready to throw the computer away.
See if you are using Enhance pointer precision,if so try and turn it off. Click Start, click Run, type control mouse, and then click OK. Click the Pointer Options tab, click to clear the "Enhance pointer precision" check box,click Apply and OK. If you are using a wireless mouse try changing the battery.You can also go to the mouse control in the control panel.Uncheck the options to "automatically move pointer to default button". Also check the sesitivity of your touch pad , if it set to a high sensitivity and you barely touch it , it could register as a double click.
Nov 17, 2010 | Samsung N150 (36725723009) Netbook
Jumping cursor on windows7
change ur driver, update os, and install antivirus, download reginout intel partner may fix it
Sep 03, 2010 | Sony VAIO Notebook
Drifting mouse pointer
Go to Control Panel - Mouse - Pointer Options - and uncheck 'Enhance pointer precision'.
Feb 28, 2010 | Dell Precision M60 Notebook
Have tried 3 different mice with this hp520OJ model computer, how to fix problem of the mice not working well at all - pointer does not go where you want it to, have to try for a really long time
is it jumping or go very slowly? If it is very slow then go to control panel and find mouse under pointer options find pointer speed and increase or if very fast then decrese and mach your requirement. If jumpes and one time is in one corner and then to other vithout your "help" to move then check latest antivirus software and scan for viruses , also find anything newly installed application may conflict with it.
Aug 03, 2009 | Computers & Internet
Jumping curser
its probably in the mouse settings.go to control panel/mouse/pointer options.. take the check mark out of Enhance Pointer Precision..click apply and ok.
I’m happy to help further over the phone at https://www.6ya.com/expert/william_83fc156eee2b555e
Jul 20, 2009 | ASUS Eee PC 1000H Laptop
Mouse Cursor Jumps to the right of the screen
Have you tried going into the control panel - mouse - pointer options - motion speed (slower) and experiment with pointer precision check box? Try it, see what that gets ya.
May 05, 2009 | Dynex Wireless Optical Laptop Mouse...
Pointer jumps around on screen when touching touch pad
hello, have you tryed adjusting the sensitivity of the touch pad to a less sensitive touch ?
Mar 31, 2009 | Acer Aspire 5610 Notebook
Open Questions:
See all Wacom Intuos2 A6 Questions
Wacom Intuos2 A6 Logo
149 people viewed this question
Top Wacom Computers & Internet Experts
Edward Easley
Edward Easley
jasbo
jasbo
Alun Cox
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
