Question about RCA TruFlat 27F520T 27" TV
Same problem i am still having te same problem with my tv. i got a new remote and neiither one have a reset button. my kids somehow keep putting passwords on it. the front panel is blocked and i cant do anything with the front panel. please help.
  • Anonymous Feb 14, 2008
    i have the same problem.. the remote that i have has a menu botton but the select botton is not working. How can i change the setting without using the remote.
    Scholar:
  • 48 Answers
Some reset sequences involve a CLEAR button on the remote, simultaneously holding clear on remote and one of the panel buttons. Each tv is different, some are the same, but agreed, answer is always in user manual. Example, my 26" truflat HD TV:
If you forget your password, you can reset it; here is how to do it:
1. Make sure the TV is off.
2. Press VOL- on the
TV’s front panel and then CLEAR on the remote for approximately 5 seconds. The TV will turn back on.
3. Enter a new password the next time you access the PARENTAL CONTROL or the Title menu.
Posted on Mar 14, 2009
  • 59 Answers
Unlock is in the tv menu not remote if you still have owners book that came with tv it will tell you how
Posted on Feb 05, 2008
Somehow I am getting "button locked" on every button but the power button. Does anyone know how to fix this??
A factory reset on several AOC models can be performed by unplugging the TV for 5 to 30 minutes. When it comes back on it should be reset to factory defaults and ask to do a channel scan. You have somehow enabled the so-called childproof or "Bar mode" of the TV which deactivates the panel buttons so kids (or patrons) cannot mess it up.
Sep 08, 2013 | AOC L24H898 24 in. LCD TV
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
Hi, I have a problem with my rca television model number RCAS01BA. My dauther has somehow put the child lock on without using the remote control as we had lost that a couple of months ago. (God bless...
You don't need the remote to unlock the TV. Any RCA universal remote will change channels etc if you want a remote.
Now from the manual: simultaneously hold down the menu/OK button and the Volume down button for 3 seconds. This resets the pasword and unlocks the TV. You can then enter the menus as usualI believe to control/clear parental settings etc.
May 22, 2009 | Televison & Video
None of the buttons on the TV will work...can't turn TV off
Hi you will need to reset your Tv & remote sounds like that children may have played with the remote reset should clear the problem.
Feb 19, 2009 | Funai MWC24T5 24 in. OLED Television
Magnavox model# 19e604-00aa stuck in demo mode
Press +vol and -vol buttons on the tv at same time.
Jan 23, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
The kids broke my tv
The only way to fix it is to open the tv up and relocate the button also check that the cables are plugged in properly hopefully no clips have been broken, Make sure you unplug the tv first.
Sep 13, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Parental lock
Child Lock
Combos
OR TRY THIS..
CTC169AU
CTC185's
CTC203's
TX808 Chassis
Mar 26, 2008 | RCA TruFlat 27F520T 27" TV
VChip password forgoten
http://www.youtube.com/watch?v=0Zc8Jbq3qE4
Here's your  answer - Hold the down volume control on the TV. Then press the remote # 0. This will bring up the reset password menu. Then reset the password. We need a kid to solve are problems. FWL
Oct 19, 2007 | Toshiba MW20FP1 20 in. TV/VCR/DVD Combo
How do you reset forgotten parental control password?
You can try these codes 2211 or 3308 if they do not work you will need to reset the unit. You will need to unplug it for 45 minutes that will reset the TV to factory settings. Then the pass codes I provided should work.
Oct 23, 2006 | Daewoo DTQ-13P2FC 13" TV
RCA TruFlat  27F520T 27" TV Logo
168 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
