Question about Sanyo Katana SCP-6600 Cellular Phone
Katana II likely water damage... Help!
I was riding my motorcycle and had my phone in my "water proof" pocket, a little water got in becuase I saw some drops on the screen when I opened it. It was completely black like it ran out of batteries, so I tried pluging it in and turning it on. I've gotten a Sanyo with a white background but it just stays like that for about 20 seconds and then turns off, it will turn on like that about 1/7 attempts.... I'm going to try to dry it, anything else I can do?
  • 4 more comments
  • njkraemer Feb 08, 2008
    Its gone from bad to better to worse. I got it to turn on again and stop the power flicker, but it wouldn't grap any signal. Then I was able to make 1 call with it, then it dropped it and wouldn't get a signal again. Now it wont turn on period.
  • squidums Mar 02, 2008
    I dropped my Katana II 6650 in a water puddle. I pulled it out quick and took the battery out and dried it. It looks and works like normal except that no on ecan hear me when i talk. i can hear them, i can text, everything. They just can't hear me talk.. suggestions???
  • Anonymous Mar 15, 2008
    i spilt beer on my phone and ive tried to dry it but there is a lil bit of water in the screen it turns on but all it says is looking for services.
  • heyyou21 Jun 04, 2008
    My phone got drenched. Took the battery out, for a number of hours, blow dried it. It has gotten "better" but the buttons still do not work.
    I can receive calls, and make calls only if I have recorded a voice tag, then
    I can make calls through the bluetooth.
    Does the pad underneath the buttons still have to dry, or will it come back
    at all? I have read where people have put their phones in the oven and so
    on, but I am a little hesitant to do that since it does work some.
    Thanks
  • ldgotfoosed Jul 10, 2008
    I went swimming with mine and Sprint Tech support told me to put it in some rice. I was told the rice would draw the moisture out. I tried that and I'm still having issues, but it did improve. May cure someone else.
  • Anonymous Jan 09, 2009
    My phone got water damage too and worked fine for about a month occasionally dropping calls (even when I was in the Sprint store). However, the phone finally just kept turning off all the time and now won't turn on. Nothing is wrong with the battery, its been tested. The opening screen will come on but then shuts down. Any suggestions?
I put mine in some rice.
Posted on Oct 01, 2008
Mine was drenched. tried the rice and the phone is better. however, it seems to be turning on and off in the middle of calls. any advice???
Posted on Aug 04, 2008
Went swimming w/ mine and Sprint Tech Support told me to put it in some rice. They said it would draw the moisture out. I tried and got some improvement but I'm still having issues. May be worth a shot for you.
Posted on Jul 10, 2008
    Problem Solver:
  • 7 Answers
When ever your phone gets wet you are going to want to dry it out that is the 1st thing you want to do and take the battery out set it out for a few days, from what it sounds like you might have to get the lcd replace. ca you still hear? make calls?
Posted on Feb 08, 2008
Katana II: my keypad doesn't work.
there is a possibility that teh contacts ar dirty or the circuit itself for the keypad is damage.
let me check for parts you may check on to.
Aug 12, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Katana II
if you are using a new katana you can either memorize or write down teh button sequence to navigate to the bluetooth settings that need to be changed for the data transfer to occur. thats what i had to do with mine after i ran it over with a snow plow. phone still works just no display... and its in two pieces. it took about an hour to get it all right, but it should work.
Aug 24, 2009 | Sanyo Katana SCP-6600 Cellular Phone
Can i insert a memory card to my katana 2 cellular phone?
The Katana II is a good durable phone and well priced, has a 21 Mb internal memory but, does not sport a memory card slot. It is not a GSM phone and therefore does not utilize a SIM card. So the answer is no. You can, however, download your data to a computer from a memory card such as a SIM, SD, Micro SD, Memory Stick (Sony), XD, or CF using software tools, the proper USB cable, and a Digital Concepts 6 slot card reader or the like, and then upload them to your Katana II. The only limitation is the size of the internal memory. If I did not work at a cell repair shop with all the goodies available, I would take it to a service store and pay the pros. It can get a little tricky.
Check out this link for the "Phone Scoop" on the Katana II.
http://www.phonescoop.com/phones/phone.php?p=1231
Aug 05, 2009 | Sanyo Katana® II Cellular Phone
Weak roaming signal with Sprint Katana 2 cellphone
Call sprint and ask them to flag you for a PRL update. Then dial *2 and it will automatically update.
I checked in the Katana II menu and there is no option to update the PRL
Feb 03, 2009 | Samsung Instinct Cell Phone
Can you do a hard restart on a Katana II?
You can do a hard reset on the phone which will erase everything but you have to know the Master Subsidy Lock code on your device. If you can't turn the device on that will not work though because you have to access the Erase Tool from the menu while the phone is on. Have you every exposed it to any kind of liquid or extreme physical damage? If the device will not charge the battery, it sounds like you have a loose charging port. Take it to the Sprint Service Center and see if they can issue a brand new battery and check to see if there is physical damage to the port.
Dec 18, 2008 | Sanyo Cell Phones
Sanyo katana II
i'm having the exact same problem--mine only works on speaker phone. people can hear me, but i cant hear them unless i go to speaker phone
Aug 08, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Six months is well under the manufacturer warranty. Call Sprint or take it into a store.
Apr 24, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Take the battery off, unfold the phone, set it in a warm, dry place and pray like heck. plugging it in may help it stay warm but leave it off.
If its minor water exposure it'll likely be fine in 2-3 days.
Mar 02, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Sanya Katana will not power on and it has a fully charged battery
I must say that Wiska, cell phone are water accepting thing. It absorb water from climate like AC and fog. If it is realy damaged by falling in water then the service people can deny the claim. Otherwise there is no moral right to reject claim of valued customers. OK... It is their lookout. Let us discuss the problem. Now u can not do anything if they are not ready to accept their responsibility. But don't worry, there is another way. Any skilled technician can repair it after check wether it is short, open or leakage. This things are basic which are their routin testing of any circuit. There are lot of technician who posssess enough skills to workout this problem. Only ask fixya for such serviceman arround you.
Dec 22, 2007 | Sanyo Katana SCP-6600 Cellular Phone
Sanyo Katana SCP-6600 Cellular Phone Logo
392 people viewed this question
Top Sanyo Cell Phones Experts
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
270rexton
270rexton
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
