Question about RCA P61927 61" Rear Projection Television
Rca model #hd61w66
What is the power supply that i keep seeing in all of the answers and where can i get one?
    Genius:
  • 1,030 Answers
Power supply can mean different things in this set theirs the Main input doubler.. sort of a ac to dc converter.. theirs the convergence power supply.. then theres the deflection supplies. first what is you set... hyd61w66 or p61927 what is it doing is the led blinking. shutting down..
Posted on Feb 15, 2008
Humming, static noise when answering message is playing, RCA 25425
First thoughts are is the device near to a wall socket power supply?
Non "Switch mode" power supplies use transformers and these give off a radiated 50/60Hz hum which can be picked up by devices with amplifiers such as answering machines and phones etc. Try moving the answering machine to a new location where there are no power supplies nearby and see if that makes a difference? If it does you have a couple of choices, leave the machine where it is or move the power supply to another wall socket further from the answering machine.
Kevin
Jul 22, 2014 | RCA 25425 / 25425RE1 4 Line Corded...
Tv keeps turning off every 10 minutes
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.4_23_2012_4_19_57_pm.jpg
Apr 22, 2012 | Vizio VO47L 47 in. LCD TV
My RCA PurFlat keeps beeping and the light in front (near the power button) keeps blinking, it won't come on, can this be fixed?
ISSUES:
Answers to issues:
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.4_23_2012_2_17_42_pm.jpg
Apr 22, 2012 | Televison & Video
Keeps turning off by its self. at home fix?
It depends on the brand and model number which are not indicated here.
General answer:
ISSUES:
Answers to issues:
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
Mar 24, 2012 | Televison & Video
I have a maxent 42 inch tv for the last 2-3 weeks the picture keeps blinking intermitentley last night while watching it we heard a pop and we have sound but no picture any answers
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Apr 30, 2011 | Maxent MX-42HPM20 42 in. Plasma HDTV
Pc hp dc 5000 sff does not power on, a red light keeps blinking, no beeping, no noise. Replace with a new power supply. Does the same thing
sounds like you have your answer, your computer is hosed. unless you want to keep swapping parts to try to see if it's memory or cpu, I'd just get a new motherboard/cpu/ram combo (they've come a long way since you got that computer, I'll bet)
Oct 07, 2009 | HP Compaq Business d530 Small Form Factor...
Power supply has become intermittentand causes the telephone to which it supplies power to turn answerer on and off.
replace the phone, phones made today are of pretty low quality. Keep receipts and know the warranties on the equipment.
Aug 27, 2009 | Lands Phones
Auto answer button?
SOLUTION:
  1. Ensure that you have a two contact phone cable connected to line 1 socket of the printer and that the other end of the cable is connected to the phone jack in the wall.
  2. Perform a partial reset on the printer. To do this first remove the power supply from the back of the printer. With the power off press and hold the # and 3 keys.
  3. Plug the power back into the printer, keep holding the # and 3 keys till you see “ Partial Reset ” displayed on the printer screen.
  4. If this does not resolve the issue contact HP
Mar 03, 2009 | HP OfficeJet 7110 All-In-One Thermal...
RCA P61927 61" Rear Projection Television Logo
139 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
