Question about Samsung CLX 3160fn All-In-One Printer
Color smears or runs on entire page wherever there is color when printing or coping. Black is crystal clear. No Error codes. Changed all of the Color Toner Cartridges. No different. Turned off computer and printer and rebooted as manual suggested but didn't help. Removed imaging cartridge and cleaned inside of printer, didn't help. Has printed 3084 images. Any suggestions? The machine is still under warranty but didn't want to send it away if something simple. Thanks.
  • jmsjrs Feb 05, 2008
    Samsung Tech had me send color print job to printer, shut unit off when paper was pulled in one inch. Turn off machine, remove imaging unit, check image on green drum. OK. Next, remove next cartridge unit (might be called fusor unit) and check image on that. Couldn't see any, but found piece of crunched paper stuck in it. Removed piece of paper and reassembled all parts, sent color print job to printer, Everything OK. Weird - paper always fed properly and color only was smeared. Black was always OK. Anyway, problem solved.
    Thanks,
    jmsjrs
  • 3 Answers
Any smearing usually indicates a crunched up paper somewhere in the machine. Take the whole machine apart and look for any crunched paper. A crunched paper is not a jam - so therefore the machine still works with a foreign paper inside. Remove paper - run of a few prints with not much on them - to clean the drum. Print a demonstration print to test machine. Should be problem solved!
Posted on Feb 22, 2008
  • 4 Answers
Uninstall the driver of your machine .reinstall again use the cd driver to update
Posted on Feb 04, 2008
Smearing on the right side of the page
See the user guide on page 191 and following to clean the paper path.
Nov 16, 2011 | HP Laserjet CM2320nf All-In-One Color...
I changed black ink cartridge and now pages that are printed are really poor quality and really hard to see...faded in color and sometimes smeared in some spots. Help.
Try going into the menu and cleaning your print heads. If that doesn't work, take out the cartridge and using a cotton swab and alcohol, clean the print heads.
Aug 16, 2011 | Epson Stylus 880 InkJet Color Printer
Yellow smear on left side margin from top to bottom of the page. After cleaning, the smear reduced to one third and confined to the lower left corner. How do I get rid of it entirely?
What did you clean? If it was the Image Transfer Belt (the big mylar belt in the front), do it again. Print and see if the yellow is smearing again. If it is replace the yellow cartridge.
Jan 31, 2011 | HP Color Laserjet 3550 Printer
Images smeared but fused & I get a 49.2FEE
Your fuser is failing, specifically the thermostat...but generally you have to replace the entire assembly.
Sep 30, 2009 | HP [4/PK] BLACK TONER CARTRIDGE FOR COLOR...
Print is smeared and unreadable
go to pages 49 to 59 of the manual ("http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf" if you don't have it) good luck!
Feb 08, 2009 | Dell 924 All-in-One InkJet Printer
Magicolor 2400W error
This happens to me every few months, I have to do a VERY detailed cleaning of all toner sensors. The knowledgebase on KM's website is actually very good about walking you through which sensors to clean and pictures indicating where they are located. This has fixed me up every time. GOOD LUCK!
Jan 19, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Smearned Printing on Ricoh Aficio AP3800C Laser Printer
Hi there the smudges are most likely down to the black PCU (Drum Unit) and following are the reasons for the two fault caode you have given me.
SC 261 LD HP sensor
not switched
off (for K only)
After the laser beam pitch was
changed, it takes more than
five seconds for the HP sensor
to switch off.
• Defective motor
• Defective sensor
• Mechanical problem
when switching the
actuator
• Brown fuse (FU81) on
the Power supply unit
1. Turn the main switch off and on.
2. Check the sensor actuator position of
the LD positioning motor.
3. Replace the LD positioning motor.
4. Replace the LD home position
sensor.
5. Check and/or replace the PSU.
SC 380 Black
development
motor error
SC 381 Color
development
motor error
When the motor speed is
within the target level, the
motor sends a lock signal
(High to Low at CN214-5) to
the BCU.
SC380 is detected under the
following conditions:
• The Lock signal stays High
2 seconds after the motor
turns on.
• The Lock signal stays Low 2
turns off.
for more than 2 seconds
while the motor is on.
• Defective motor
• Defective BCU
2. Replace the motor.
3. Replace the BCU.
Hope this is any help
Thanks J
Feb 21, 2008 | Ricoh Aficio AP3800C Laser Printer
HP Printer problem
Sounds as though one of the drum cleaning blades is failing.
When you see the double image shadow, is it any particular color? If so, that's the drum unit that is failing.
Feb 06, 2008 | HP Color LaserJet 2600n Printer
Gestetner DSc332 streaks and smears when printing in color
Check to see if you have a paper jammed near the drum near the color ink cartridge interface.
Nov 28, 2007 | Gestetner DSc332 Copier
HP Color Laser Jet 3550 Smearing Colors
Do you use original genuine cartridges or refilled ones. It sounds like you have had a leak and need to completely clean out your printer heads, rollers and perhaps do a deep claean as well. You can buy faulty cartridges and toners that have one leak, then the ink continually leaves traces as it prints. When you say callibrated, do you mean you ran print tests and setting tests. Running a print test can often help to diagnose ink issues an d narrow the results down a bit. After a thorough clean, you could try uninstalling and reinstalling unit.
Aug 11, 2007 | HP Color LaserJet 3500 Printer
Samsung CLX 3160fn All-In-One Printer Logo
326 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
