Question about Vtech Lands Phones
V Tech 1930c display screen doesn't display and off button doesn't work
I have a V Tech 1930c Cordless Phone that has been laying around the house for awhile. The display screen doesn't show numbers or letters, just bits and pieces of both. How can the display screen be fixed? Also the off button doesn't work, and the only way to hang up the phone is to put it back on the cradle. Is there anything to be done with that? This phone is out of warranty and I am not the original owner. The phone is operational. but the screen not displaying is very irritating
6ya staff
SOURCE:
Anonymous
SOURCE: Cordless phone 25881
Sounds like a power problem.
This model of phone will work as a regular corded phone when no ac power is available.
IE the cordless function is only available when you have electricity.
- is the ac adapter plugged into a working outlet.
- is the ac adapter working.
- is the ac adapter pluged into the base.
hope this helps
Posted on Jan 21, 2008
wyomugs
SOURCE: Caller ID does not work
I FIXED IT!!!  YIPEEE!!
What I did was UNPLUG the base's power unit from the wall... waiting about one minute, and plugged it back in.  That caused it to "reboot" the entire system, and the CID now shows itself.
Posted on Mar 07, 2008
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: hello -need help with phone
It's not charging the battery, clean the contacts on the base, put it on another base to see if it says CHARGING.
Verify that you have power to the base.
Battery might be bad. Try it in another handset.
Posted on Nov 06, 2008
Anonymous
SOURCE: vtech cordless phone/ detc 6.0
This worked for me. Unplug the power to the base for 10 seconds then plug the power back in. That did it for my "connecting....." problem. Good luck!
Posted on Dec 20, 2008
Anonymous
  • 5 Answers
SOURCE: Display light is on but the words don't show up.
Dear a1trkr,
Press the menu button on the handset and type in (1) (4) (5) THen press 1-6 for LCD Contrast.
Hope that works! I have a panasonic and I love the clarity and range.
Best of Luck, The Writer.
Posted on Jun 02, 2009
I have a GE model 25836CE-B cordless phone. My problem is this: when the phone is off the charger base, after a few minutes it will keep on beeping even if no one pressed the paging button at the charger...
Actually, you can't overcharge the battery. The base is designed to hold the handset indefinitely. Once the battery is charged it doesn't do any damage. You probably just don't have the battery charged enough to use the phone. Leave the handset on the base overnight, let the thing charge, and it should work properly.
Jul 12, 2011 | Uniden Cordless Phone
I have Presidian Corded phone and DECT 6.0 Cordless Phone with Answering System and Caller ID -- phone doesn't ring, though two other phones in house do. How I do I get the ring tone back?
if you look aroun on your menu / buttons on your phone there is usually a silense button / switch just select the ringer you want if this does not work let me know i have more solutions
Jun 30, 2011 | Lands Phones
Had a power outage during a lighting storm and now the GE spacemaker phone/unit does not work; it's showing in the display screen "Initializing". The phone works, but when you press any of...
Does it have a battery backup? If so, after disconnecting the AC power adapter, remove the battery for 15 minutes, then re-insert it (make sure it is a good battery), plug the AC adapter back in, and try again. Hopefully, this will re-set it. If not, it probably isn't worth tryiing to repair. May have to buy a new phone.
May 06, 2017 | GE Spacemaker 26976 Cordless Phone
Hello i had my phone laying on my bed and i must have fell a sleep and layed on it when i got up this moning the display screen was white with not picture i can call out and receive calls put i can not...
mcdevito75 here, I just imitated sleeping on a cell phne and found mine will turn off, try turning your cell phone off, (red button) and then turn it back on. If this doesn"t help call your cell phone carrier for their advise.
Sep 21, 2010 | Nokia 2680 Slide Cell Phone
Have new CD155 cordless phone. phone does not
I'm having the same problem. My temporary solution is to turn on the speakerphone on the cd 155. Also if you happen to have an older phone laying around, you can use a phone jack splitter and use the old phone to alert you of incoming calls.
I just noticed this problem today, i'm still working on it. I'll let you know if I come up with a better solution.
Dec 07, 2009 | Philips CD1552B/17 Twin Cordless Phone
Handset display not working
Display can be damaged change ur display install new display
Jul 11, 2009 | Vtech V-tech Speakerphone
Our 5.8gh uniden phones all have static one land phone 3 extension.
disconnect the ac adapter from the base - before you plug the phone back in with power - press and hold down the menu button (center silver button under the led display) and the number "1" and then plug it back in - keep holding those two buttons until the date and time reappears - it worked for me and it didnt erase the phone numbers stored in the base unit.
Jun 01, 2008 | Uniden EXA15580 Cordless Telephone
hope this helps
Nov 30, 2007 | GE 25881EE3 Phone
Lands Phones Logo
50 people viewed this question
Top Vtech Lands Phones Experts
Marvin
Marvin
Ekse
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
