Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Cable stations interrupt while watching DVD
I own a Sony KV32FV16 32" Trintron Wega Flat Screen TV and the strangest thing has been happening lately. I have a cable connection and I'll be tuned to channel 13 when all of a sudden channel 2 invades the scene. The audio of channel 13 is on but the image from channel 2 is on the screen. This happens only when the set has been on for less than a half hour or so. It takes about 30 minutes of the set being on before this phenomenon disappears. At first I thought it was a loose cable connection but I checked that out and it's not the case. Is there any way of adjusting the set? It's driving me k-razy! It even happens when I'm watching a dvd. The cable channel will invade.
Help!
  • 979 Answers
Remove power from your cable set while watching DVD and see if the problem magically goes away. If that's the case, the cable box is to blame...accordianman
Posted on Feb 19, 2008
6ya staff
SOURCE:
Need to know which optocoupler ic is used in str 6267 based power supply in sony trintron crt tv
Sony FD Trinitron WEGA... Repair Questions - Fixya
www.fixya.com/.../p228979-sony_fd_trinitron_wega_kv_36fv310_36_t...
Hello, i have a sony FD Trinitron WEGA #KV-36FV310 ... Need to know whichoptocoupler ic is used in str 6267 based power supply in sony trintron crt tv.
Sony KV-TG21M61 21" TV Repair Questions,... - Fixya
www.fixya.com > Forum > Standard (CRT) Televisions > Sony
Need to know which optocoupler ic is used in str 6267 based power supply in ... My sony crt Tv totally dead when touch any components and the IC strs6307 ...
Tv code hi i'm looking for a 3 diget programming code for my ...
Dec 21, 2015 | Sony Televison & Video
My sony trintron 21" the bottom half is black i
solution
step 1 : Now at first test your fly back transformer
step 2 : A.C. transformer out put voltage test
step 3: Vertical yoke coil adjust
Jul 30, 2011 | Sony FD Trinitron WEGA KV-21CL10 21" TV
I need to hook up the dvd player to my new Sony
you have a flat screen, look on the back of the flat panel for digital in (yellow, white & red jacks). this will be connected to yes the DVD player. using your tv remote switch the source enable to watch a DVD. you comcast cable is still connected to watch this simply switch back to cable source..
Jul 19, 2010 | Sony DVP-NS50P DVD Player
I want the codes for my remote to control the vcr/dvd rather than just the tv
The Sony remote that came with your TV will not be able to code to your DVD / VCR combo unit, combo units have to be operated by their original type/style remote, because they operate on very specific frequencies.
Now you may be able to code the combo units remote to operate the TV, but usually not the other way around, it just won't work.
Good luck !
Jan 27, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Wega TV --24F... does it need a converter?
No. all flat screens have converter chip built in.
If you are having problems getting channels, make sure you go to the settings, and broadcast settings, and make sure it is on AIR for regular tv, or CATV for cable.
May 05, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Green symbol AV2 won't go away! Sony Trinitron KD-28DL11U
You need to have original Sony TV remote and press Display button on it, on-screen display will disappear.
Nov 25, 2008 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Sony 65 inch
Do you loose the screen completely to a black screen, or does the video just drop out to blue screen or snow?Do you still have audio?
Jan 16, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
DVD works, but no cable
YOU CAN EITHER SWITCH YOUR CABLES ARE CALL UR CABLE PROVIDER AND IF U HAVE SATTELITE THAN IT COULD MOST LIKELY BE UR CABLE ON THE REAR OF UR HOUSE WHERE UR BOX IS ARE THE CABLE IN SIDE THE DISH. MAYBE EVEN U DIDNT SWITCH THE LINE BACK TO CABLE TRY SOME OF THESE THINGS THEN U CAN SEND ANOTHER MESSAGE IF IT WORKS ARE NOT LETTING US KNOW WAT HAPPENED THANK U
Dec 10, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony Trinitron Flat Screen 15" TV - Sound not working, image pauses every 5 seconds
Sounds like a DVD player issue. The TV is all analog and can't replicate issues like that.
Jan 28, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
65 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
