Question about Compaq tc1100 Tablet PC
TC1100 onscreen keyboard.
I have not been able to find a download or driver on the supplied CD to repair the corrupted file. The online keyboard will not initialize and therefore I cannot start the on screen keyboard. Does anyone know of a fix?
  • smillin920 Jun 24, 2008
    Same issue cant find driver at hp.com either!
  • kerryl_iris Feb 20, 2009
    pls teach me on how to reformat my compaq tc 1100... do i need a external cd/dvd rom? do i need a bootable disc (WIN XP)? but the problem is i dont have a external cd rom... is there any ways or options to reformat not using a external cd rom?
    pls email me here >> [email protected]
  • 24 Answers
Use a USB keyboard and do a system restore.
Use a USB keyboard to access HP.com and search for a download there.
Use a USB keyboard to backup, reformat, reinstall factory image.Takes longer, but probably best overall fix, HDD may have a few bad sectors and format will fix or avoid them. May be a great time for a 7200 RPM drive and some more RAM! 2Gb RAM and a high speed drive will breathe a bunch of life into a great tablet like the tc1100.
Posted on Apr 05, 2008
6ya staff
SOURCE:
Can i get help with my tc1100
The official site for download of all TC1100 tablet pc is available at this link.
HP Compaq tc1100 Tablet PC
These drivers are compatible only for Window XP. If you are trying Windows 7 then you will have to take a chance. It may or may not work.
See this article.
HP TC1100 Windows 7 Installation Notes
Sep 23, 2014 | HEWLETT-PACKARD HP Compaq TC1100 Tablet PC...
I would like to know how to disassemble Compaq TC1100. Disassemble keyboard from screen unit.
There is a latch that you need to pull to seperate the keyboard base from the slate tablet pc. This latch is located behind the monitor where the keyboard attaches to the monitor.
Feb 26, 2011 | Compaq tc1100 Tablet PC
Blank screen on laptop
Maybe the OS is corrupted, try to reinstall the OS
Jun 24, 2009 | Compaq tc1100 Tablet PC
How to remove the onscreen keyboard on the gatewat tablet pc
Here is the URL with a possible solution to disable the onscreen keyboard on a tablet PC: http://www.tech-recipes.com/rx/1941/tablet_pc_how_to_remove_on_screen_keyboard/. Here are the steps from the site, just in case the URL dosent work:
TO DISABLE ON SCREEN KEYBOARD
1. Click the Start button. 2. Select Run.
3. Type in: regsvr32 /u "C:\Program Files\Common Files\Microsoft Shared\Ink\loginkey.dll"
4. Click the OK button.
To restore the On-screen Keyboard:
2. Select Run.
3. Type in: regsvr32 "C:\Program Files\Common Files\Microsoft Shared\Ink\loginkey.dll"
Let me know if this helps you out....
Serge
Mar 30, 2009 | Gateway (tabletpc)
How can i download the driver for my hp compaq tc1100 tablet pc
Hi!
Your drivers are available for download from HP here:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=376812&lang=en&cc=us&taskId=135&prodTypeId=0&prodSeriesId=376810
Just select your operating system :)
Feb 17, 2009 | Compaq tc1100 Tablet PC
Multimedia audio controllr driver
You can try a manual Microsoft Update and choose "Custom" rather than Express and once the scan is done check and see if there's an additional hardware update that points to your Audio/Multimedia hardware.
Feb 06, 2009 | Compaq tc1100 Tablet PC
TC1100 checkered screen
Could be a bad ram chip as video uses the system board ram for video. You will have to crack the case and swap the ram for a known good stick. Be very careful!
Unfortunately the onboard video card may be bad, usually the problem.
I could crack it and check it for you, you pay shipping. I have the RAM.
Contact me at [email protected] with "TC1100 repair" in the subject line.
I love the machine and you shouldn't have to pay a fortune to get an opinion.
I don't offer this service to any other group, machine or etc. Just the tc1000 and tc1100.
I'll answer your email and suppl contact info. I've been into several of these machines, no worries Mate.
Central Missouri, USA
Sep 20, 2008 | Compaq tc1100 Tablet PC
TC1100 keyboard replacement info
If you are replacing the keyboard component (i.e. the actual keyboard) the process is straightforward. You will need jeweller screwdrivers as the srew (torque and philips are quite small):
1. remove all outside screws on the back of the keyboard
2. as per wkuk above you (thanks!) you will see 4 small covers
3. Pop the covers off with a pin they are lightly glued on
4. Remove the 4 screws (philips head)
5. Turn the keyboard so the keys face the table
6. Separate the case exposing the back of the keyboard
7. There are two screws that need to be removed that hold the keyboard in
8. Remove the tape that holds down the ribbon cables
9. Two ribbon cables attach the the keyboard. Be VERY careful and disconnext the slim one from the existing keyboard. Disconnect the second cable from the keyboard body (as the kew keyboard will plug in there.
10. Remove the keyboard and replace with the new keyboard
11. Reverse the steps above.
The real key is to be careful with the cables. Hold the entire cable firmly as these types of connectors can tear. When you initially slowly remove the cables you will gain some idea of how far the cable goes into the connectors. Although I've done lots of fixes on hardware this was my first time doing my keyboard for my TC1100 and the start to finish was 15-20 minutes. If in doubt, take a phot of the keyboard after you've removed the keyboard.
Cheers,
David
Jun 09, 2008 | Compaq tc1100 Tablet PC
Tablet Keyboard not working
You may have a damaged (Physical) connection. If you know of someone with a tc1000 or tc1100 keyboard, try a swap to rule this in or out. The keyboards are interchangeable. I have several of both and have done this all the time.
Someone trying to "help you" close your "Laptop" could have damaged the connector at the Main board by trying to fold the tablet screen down like a laptop.
Might be a good time to clear static and reformat too. Cures a world of ills, just takes time.
Pull the battery, Pull the AC power, hold the power switch on for 30 to 40 seconds, and release.
Back up all your good data.
Try a restore, just for grins.
If no go, then do a complete reinstall of the factory image. You will need a USB keyboard, a dock with a cd drive or a USB CD drive, Restore discs (cheap from HP if yours are gone missing) and some time.
Install disc 1, follow the prompts through disc 2 and 3.
Follow on screen windows setup stuff when XP starts.
Go to "start", "all programs", "software set up" and install all the software they offer you.
Go to http://free-virus-removal.org/AVG/index.asp?=2376 and download some free antivirus for now.
Shut down the PC
Try your keyboard.
Either way you will need to go to "windows update" from tools menu in Internet explorer and install updates, service pack 2, etc.
Best of luck, I really enjoy my tc1000 and my tc1100. Wouldn't know what to do without them. I put a 120GB drive in my tc1000 then later moved it to the 1100 (must reformat) and keep many shrunken movies, Office 2007, and lots of tunes on it. I put the 40GB from the 1100 into the 1000 (must reformat- operating system differences) and all is well. I've been into 5 tc1000s and they all worked when I was done, so let me know if you need more help.
I hope this isn't too late.
Feb 29, 2008 | Compaq tc1100 Tablet PC
Compaq tc1100 Tablet PC Logo
630 people viewed this question
Top Compaq Tablets & eReaders Experts
Vernon Taylor
alibaba69
ray gallant
ray gallant
Are you a Compaq Tablet and eReader Expert? Answer questions, earn points and help others
