Question about Magnum 257 CB Radio
Operator/instruction manual I purchased a magnum brand 257 radio. The instructions really don't explain how to operate the radio. I need a more detailed manual to explain how to actually accomplish things such as sideband, how to memorize frequencies etc. I need a more hands on manual.
  • 204 Answers
Ghilger, First off, has your radio been converted to open up all the other channels(including CB)?? That has to be done first, or it's locked in the ham freq's. I think the factory manual is pretty well detailed, but i've been around radios my whole life. The mode button does the changing from am/fm/usb/lsb.Here's from the manual;
MODE: Operating Mode. Press the MODE control to select the operating mode. The operating mode is indicated on the liquid crystal display: am, fm, usb, or lsb.
* See, there is 2 different functions for each button. One set of functions are by just pushing the buttons, the other set of functions are obtained by pushing the function button first. The function button is activated by pushing in on the clarifier knob.
*Here is for saving of freq's;
Memory Save. To save in memory a specific
frequency and operating mode, select the desired mode and rotate the FREQUENCY control to the desired frequency. Press the FUNC button, and then press the M.SAVE button. S will appear on the LCD next to the frequency. While S is displayed, immediately press any of the memory channel buttons (1 - 5). The mode and frequency is now saved into memory. If the S indicator disappears before you press the memory channel button,
the information will not be saved and the process
must be repeated.
M.LOAD: Memory(Recall). To recall, any of the saved memory channels press the M.LOAD
button. L will appear on the LCD for several seconds. While the letter is displayed press the desired memory channel button (1 - 5). The programmed mode and frequency will be displayed.,
If you have any more questions about the radio, repost them here and I'll try to walk you thru them. The radio is a very good ssb rig, especially set up with a power mic. Hope this helps,, Mechanic
Posted on Feb 03, 2008
6ya staff
SOURCE:
Tengo un magnum 257 y un micro dm 452 y necesito la combinacion para instalar el micro con el radio
tengo un magnum 257 y necesito la COMBINACION PARA INSTALARLE UN ROAD DEVIL RD104E.
Mar 17, 2014 | Magnum 257 CB Radio
Will the 257 work on 11 meters/cb40 channels?
The Magnum 257 is a 10-meter Amateur radio, but it can be easily modified to operate on the 11-meter CB radio band. The modification and use of this radio on the CB frequencies is, of course, illegal. To modify one of the newer blue-faced models (this will not work on the original yellow-face models), remove the speaker side cover and look for the CPU board in the front of the radio close to the mic connector. This board has four sets of pins and a jumper that fits on the pins. To convert/expand the radio, move the connector to the CON3 position. This will give you frequency coverage from 25.165 to 29.699 MHZ, and the CB frequencies will be on Band E of the radio. Again, this modification, and use of the radio on the CB frequencies, is illegal. This modification information is provided for shop/calibration and experimental use only.
Nov 01, 2010 | Magnum 257 CB Radio
How do i get the magnum 257 80 watt to operate on 11 meters it will be used out of the country thanks bill smith
This radio will need to be converted. Do you know anything about that? If not take it to a shop.
Sep 10, 2010 | Magnum 257 CB Radio
The Magnum 80watt 257
go to cb tricks .com
Apr 20, 2010 | Magnum 257 CB Radio
Compre un cb magnum 257 pero perdi las instrucciones y quiero agarrar frecuencia con otros radios pero no se como empesar cual es el primer paso des pues de en cender el radio
mira el magnum force 257 es un radio de 10 metros y modificable a 11 metros , los canales mas usados en 11metros son el canal 9 osea 27065 mghz , o si tienes licencia puedes usarlo en 10 metros 28,000 por ahi para arriba se usa mucho 28315 en usb , en 11metros se usa am mucho, busca en yahoo , el manual de servicio para que te familiarizes con el suerte.
Apr 02, 2009 | Magnum 257 CB Radio
Lost buttons/1 and 2FOR 257
Yes, if this is the Magnum 257, then contact the company at 1-877-624-6869
or e-mail them from their site,, https://www.rflimited.com/Site.asp?CID=2
Hope this helps you, let me know,,, Mechanic
Nov 02, 2008 | Magnum 257 CB Radio
Magnum 257
If it all discteet components cb parts (most of them) can be purchased from any electronic components store quite freely
assuming you know what you want...if the set is full of ICs....
forget it as the said ICs are made for that set , transistors for
HF and UHF cb are available if you know how to use replacemant with another type / brand
GOOD LUCK
Jun 24, 2008 | Magnum 257 CB Radio
Magnum 257 No Audio Being Transmitted
Hello.I have a similar situation on a Magnum 257 HP operating on SSB (AM and FM works fine). If i Transmit it works fine, but when i release the Mic button (after TX), in the bottom side were the RX level should be, it appear somth like a signal level 3 to 5 (constant and continous), but i can't get any reception at all. Only if i turn the TX power level to MAXand i transmit, then it goes back to reception, but not every time. Somtime after TX i need to push the mic button 2-3 times to make it recive somthing, but this wors only if the power level is over 60-70% an i repeat, only on SSB.Can i get some help with this issue?
May 10, 2008 | Magnum 257 CB Radio
Magnum 257 off freq
Colin, here is all the tech info on alignments that your looking for,,,go here;
http://www.cbtricks.com/radios/rflimited/magnum_257/index.htm
Hope this gets you on the right track,, let us know.
Mechanic
Mar 09, 2008 | Magnum 257 CB Radio
Radio Communications Logo
244 people viewed this question
Top Magnum Radio Communications Experts
Tom
Level 1 Expert
John Porter
Are you a Magnum Radio Communication Expert? Answer questions, earn points and help others
