Error message i had a system recovery done on my computer and ever since then i can't install the Print workshop 2008. the error message says: "Error reading from file C:program filesprint workshop 2008dbl cliparts_thumbnails.pwd. verify the the file exists and that you can access it" what dio i do to fix the problem??
  • riajane Feb 03, 2008
    i don't know how to remove it from registery. i've never done it before.
Dear riajane
Uninstall the workshop 2008 and reinstall it. If it is not passable remove the manually in program folder as will as registry be careful wheal removing in registry. And reinstall it
Posted on Feb 03, 2008
6ya staff
SOURCE:
Reset hp amd to factory settings
The particular error code (1009) is a generic error code for 'interrupted' for system recovery. Meaning, somehow, the recovery process was interrupted. For most HP machines this can be a simple as a few keys being pressed on the keyboard, a power interruption, bad disc, faulty hard drive, or some other form of read error during the process.
Unfortunately, the error code isn't specific enough to give you the best possible troubleshooting information, but I shall try to help as much as I can.
If you can provide the exact HP model number, I can provide a more specific solution for you; but, if you have a Desktop or Notebook computer that uses F11 (on start-up) to enter into system recovery, then you can do the following:
  1. Click Next when Welcome to Recovery Manager displays.
  2. Select No and then click Next when Microsoft System Restore displays.
  3. Select Yes and then click Next when System Recovery displays.
  4. Select the appropriate item (backup file or not) and then click Next when Recover your computer to original factory condition displays.
  5. Allow the system recovery process to complete.
NOTE: The PC will appear to FREEZE for several minutes (it can take quite a while depending on the Operating System you are installing), so do not turn off the power to your machine. If the machine stays frozen for longer than several hours, then chances are the hard drive is having issues, or the recovery image cannot be recovered.
If you have tried the above steps, and you are still failing with Error 1009, it usually points to a failure with the recovery medium (image on a CD, or image on the hard drive), or that the hard drive it is restoring too is having a write/read error. This can be worked around if you have a USB recovery media you can use.
If you have access to another computer, you can create a recovery key on a USB stick to boot your HP computer from, and then kick off the recovery process that way.
Those options, however, shouldn't be taken unless you have tried the above solutions first.
Regards,
Phillip
Dec 23, 2013 | HP Pavilion Computers & Internet
Packard bell zh7, had virus did reboot ,now has message which reads,The computer restarted unexpectedly or encountered an unexpected error.windows installation cannot proceed.To install windows,click ok to...
You are going to have to use the restore/recovery process to get past this. The virus corrupted a major file and now it wont boot. I hope you made backups.
Oct 28, 2013 | Packard Bell Computers & Internet
I got an installed printer, and it can't print. It seems that my PC cannot read the printer, like there is no printer installed. When I try to uninstall the printer and to install again the error
When you try to install a printer and get an error message "Print Spooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the General tab then select these items - Startup type select Automatic Service status click Start Then click OK MICROSOFT PRINT SPOOLER FIXES
http://support.microsoft.com/kb/934885
Jan 11, 2013 | Office Equipment & Supplies
Did recovery, error message: encountered unexpected error
If you made backup recovery cd's do a fresh install of the operational system to factory setting.
Apr 17, 2012 | eMachines EL Computers & Internet
Bootmgr missing on hp pavilion slimline s5503w
This document pertains to HP and Compaq desktop PCs that came with Windows 7.The following error opens when attempting to start the PC:BOOTMGR is missingPress CTRL+ALT+DEL to restart the PCIf you recently installed an additional hard drive, turn off the computer and remove the drive before using the following steps:
  1. Open HP System Recovery:caution.pngCAUTION:Do not perform a system recovery! Stop at the first recovery screen.
    • Press the F11 key repeatedly while the computer is starting.
    • If you have a recovery disc, turn on the PC and insert the first recovery disc into the drive. Use the disc to enter the system recovery.
  2. Select Microsoft Startup Repair tool and wait for repair to find and fix errors. When finished, restart the computer; even if the startup repair tool finds errors but cannot fix them.
  3. If the error message persists, open the recovery manager screen as was done in step 1.
  4. At the recovery manager screen, press ALT + D.
  5. Enter the following text at the command prompt: bootrec /rebuildbcd
  6. If bootrec displays "Add installation to boot list?", press y .After bootrec completes successfully, the computer displays "The operation completed successfully".
  7. To close the command prompt, enter the following text: exit
  8. At the Recovery Manager screen, select Microsoft Startup Repair tool (again) and wait for startup repair to find and fix errors. When finished, restart the computer.
  9. The error should no longer open. If it does, perform a system recovery, making sure to backup important files.
If you removed a hard drive before using these steps, replace the drive. If the error occurs again, make sure the additional hard drive is not set as an active drive. Only the main bootable drive should be set as active.
Feb 10, 2012 | HEWLETT-PACKARD Pavilion Slimline s5503w...
When i am start my hp pavilion this shows Bootmgr is missing alt+cntr+del to restart again it same cycle
1. Error: BOOTMGR is missing:
??¢ If you recently installed an additional hard drive, turn off the computer and remove the drive before using the following steps:
??¢ Open HP System Recovery:
??¢ CAUTION: Do not perform a system recovery! Stop at the first recovery screen.
- Press the F11 key repeatedly while the computer is starting.
- If you have a recovery disc, turn on the PC and insert the first recovery disc into the drive. Use the disc to enter the system recovery.
??¢ Select Microsoft Startup Repair tool and wait for repair to find and fix errors. When finished, restart the computer; even if the startup repair tool finds errors but cannot fix them.
??¢ If the error message persists, open the recovery manager screen as was done in step 1.
??¢ At the recovery manager screen, press ALT + D.
??¢ Enter the following text at the command prompt: bootrec /rebuildbcd
??¢ If bootrec displays "Add installation to boot list?", press y .
??¢ After bootrec completes successfully, the computer displays "The operation completed successfully".
??¢ To close the command prompt, enter the following text: exit
??¢ At the Recovery Manager screen, select Microsoft Startup Repair tool (again) and wait for startup repair to find and fix errors. When finished, restart the computer.
??¢ The error should no longer open. If it does, perform a system recovery, making sure to backup important files.
??¢ If you removed a hard drive before using these steps, replace the drive. If the error occurs again, make sure the additional hard drive is not set as an active drive. Only the main bootable drive should be set as active.
Dec 12, 2010 | HP Pavilion Ze4900 Notebook
Cannot Reformat Toshiba Satellite P200 using the Recovery P200
first boot your laptop with bootale recovery diask.
Tehnnenter in recovery console.
Then type "chkdsk /r" comand in prompt.
Then popress "y"
then you can easily fix error on harddisk.
Tehn it works.
Jun 21, 2009 | Toshiba Satellite A215-S4747 Notebook
Installing to second computer
Hi Cathy, script errors fall into the (Software did not install correctly issue, most common). Uninstall the printer software from the notebook. Than go to the link below & download this registry cleaner.
(Its free).
http://www.pctuneuptips.com/recommends/clean/?gclid=CL2RiIrTmpICFSFMGgodODIPzg
Once finished restart your notebook. Install the Lexmark software from the CD or download it from Lexmark, there (may) be some updating within the downloaded software. http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:463:0:0
Click the above link. Pick your operating system & the link to download will open.
Good luck Cathy!
Mike
Oct 03, 2008 | Lexmark X7170 All-In-One InkJet Printer
Print Workshop 2008
Describe Your Problem:Please describe the problem to get it solved
I bought this print workshop 2007 since around November 2006. It work wonderful until January or February of this year. I rely deeply on this programme in which i used every week until this message below stop me.
I did reinstall this programme.Still will not work.
Same message.I did click the continue button but the programme will freeze.I will go crazy if this does not work for i need the programme for work.
The message is below.
An unhandled exception has occured in your application. If you click Continue, the application will ignore this error and attempt to continue.
If you click Quit, the application will be shut down immediately.
Exception has been thrown by the target of an invocation.
Aug 14, 2008 | ValuSoft Print Workshop 2003 for PC
Open Questions:
Computers & Internet Logo
87 people viewed this question
Ekse
Marvin
Marvin
