Question about Kitchen Ranges
Kenmore Elite Electric Range, Display stuck on LOC
I loosened the control panel glass for cleaning as per instructions and then replaced but now the display says LOC and I cannot use the oven or oven light though can use some burners.
  • 5 more comments
  • boiledegg Feb 03, 2008
    The controls are very location sensitive.  Try taking all the knobs off again and moving the glass slightly whilst checking whether all the controls work.  Once you find that location hold the glass in place and replace the bushings and then the knobs.
  • Anonymous Apr 02, 2008
    we lost power and when it returned our Kenmore range (surface and oven) did not work and displayed LOC.
  • Anonymous May 24, 2008
    set the stove to clean and now it says lock and will not work
  • lborden Jun 04, 2008
    my gas range displays LOC now the burners will not work, how can i get the LOC off, and turn the burners on?
  • jrobles376 Nov 30, 2008
    my kenmore elite range is stuck on lock
  • lbrown0 Apr 08, 2009
    My Kenmore stove is stuck on LOC mode, please hlep?
  • Anonymous Mar 28, 2014
    The center burner has stopped working. Can I fix this myself, or do I need to call an expert?
I pressed the lock icon on the panel and held it for a few seconds and the display cleared.
Posted on Dec 03, 2008
  • saada10ca Mar 14, 2011
    Thanks it's working
  • maremare1 Mar 24, 2011
    That did it. You just saved me a service call...thanks.
My Kenmore electric oven/stove has been stuck on lock and beeping non-stop for the past few days. Neither the oven nor the stove was working.
Our solution: Unplug, wait a few seconds, then re-plug it in. While it's starting up again, press & hold the Stop/Clear button. Everything should clear up!
Hope that works!
Posted on Jan 13, 2009
On my panel the 9 and 0 buttons held simultaneously for 3 seconds will toggle between lock and unlock. If you accidently lean on the display you can lock it without realizing what you did. If you lock it by mistake simply push and hold the 9 and 0 buttons together for 3 seconds and it will unlock. I guess this a child lockout function but I have long lost my manual.
Posted on Jan 06, 2013
My husband unplugged the the range in order to replace the light bulb in the oven as there was broken glass as well he removed the oven door to clean the glass on the door.When he went to plug the range in,the oven and stove top are not working,and the controls are flashing non-stop.
Posted on Nov 12, 2011
Solution 3 worked but it took unplugging and waiting twice to get it to work. The first unplug and wait got the door to open. The second unplug and wait got the LOC to go away. However, I would not attempt to run the self-cleaning again because that's what caused the problem in the first place.
Posted on Jan 20, 2010
I cant press start on my Kenmore Elite Electric Range.
Posted on Oct 21, 2008
How to clean glass cooktop on Kenmore electric range
Razor blade paint scraper at 45 degree angle, then use non-metallic dish scrubber with stove top cleaning product.
Jun 06, 2014 | Kenmore Elite 44173 30 in. Electric...
After cleaning the outside surfaces of the stove, the oven door is locked and does not unlock if we push the stop button. Display reads LOC. No self cleaning cycle was initiated. The stove is a Kenmore...
What about child lock? Read user manual or try holding button for 10 seconds, might be two at once.
(I bought a $200 control board and travelled 150 kilometers for that one....)
Oct 15, 2013 | Kenmore 49043 Electric Single Oven
Code LOC
Take three screws out of bottom panel have something to catch water and loosen two inch plug on bottom right slowly and catch about four gallons of water then clean change and whatever else is in compartment
May 01, 2012 | Kenmore Elite 45986 Front Load Washer
How do you unlock a kenmore elite cooktop?
You can do this by:
Check the oven display to see whether the screen says "LOC." When "LOC" is displayed, the oven lock is activated and the door cannot be opened. You need to make sure it is locked so you do not mistakenly lock the door.
  • 2 Press and hold the "Stop" button on the oven control panel until "LOC" disappears from the display. Some oven models have a button marked "Oven Lock," which should be used instead of the "Stop" button.
  • Lock the oven again by pressing and holding the "Stop" or "Oven Lock" button until "LOC" appears in the display
  • Feb 03, 2011 | Kenmore Elite 44173 30 in. Electric...
    I have a kenmore elite electric range and it is diplaying a F7 code what can I do to fix it.
    f7 error code usually means stuck function switch on control panel. Need to check each button or switch to see which one is stuck
    Mar 19, 2010 | Kenmore Ovens
    Flashing bake and probe indication on GE JD968S
    I found the Mini-manual inside the control panel area of the range. I followed the instructions for resetting the control. Instructions are shown below:
    Glass touch models only- Lock Reference Command
    When the control panel is accessed, the signals used by glass touch panel may be adversely affected. To compensate for this change in signals, the following procedure must be followed every time the control panel is accessed.
    1. Make sure power to the range is turned off.
    2. Completely close the range control panel and return range to it's normal installation.
    3. Apply power to the range.
    Accessing the the control panel area but not replacing the control.
    4. Enter Special Functions area by pressing BAKE and BROIL keys at the same time for 3 seconds.
    5. Reset the control by pressing the 9 and 0 or the HOUR DOWN and MINUTE DOWN keys for 3 seconds at the same time.
    6. Approximately 20 seconds after the time is displayed, press the 1 and 5 or the TEMP UP and MINUTE UP keys. The control should briefly go blank, briefly display all segments, briefly display LOC REF, display all segments for 30 seconds, and then display LOC REF.
    7. Acknowledge LOC REF command by pressing the 6 and 8 or the HOUR DOWN and MINUTE UP keys at the same time. the control should then display the time of day.
    8. The oven should then be ready for normal operation.
    9. Test the functionality of the glass control panel, especially the CLEAR/OFF and/or CANCEL key(s).
    Steps 4 through 7 are appropriate if you have not opened the control panel area. I had to open mine to clean up moisture caused by a boil over.
    Judging from the number of inquiries on this same issue, this is a common problem. GE is more than happy to schedule a service call for this issue, but not so happy to give the information over the phone. This is a fairly simple procedure for most people to accomplish.
    The ERC on my range appears to be a fairly common unit. I hope this information helps.
    Sep 22, 2008 | Kitchen Ranges
    F2 error on Kenmore Elite...
    if you're talking about inside the pump housing..nope ain't supposed to be there pull it out if possible if you can't try removing all hoses and pull pump out completely remove 3 screws holding motor to housing sponge may be wound around impeller remove it ck impeller should turn with some resistance but not freewheel if it freewheel replace pump
    Sep 02, 2008 | Kenmore Elite 45986 Front Load Washer
    Display says LOC,
    I have a whirlpool range and I'm trying to get my display off of lock. I reset timer wrong and now nothing works.
    Feb 03, 2008 | Kitchen Ranges
    Kenmore Elite Range/Oven problem.
    My kenmore glass top stainless steel slide in range has an error message code F93. I was attempting to allow my range to self clean when this err message appeared. Now I can't get the door unlocked. Help?? We've had a lot of problems with this range. We've had the service tech come out probably 4-5 times for different things. I think I got a lemon. It just turn a year old-we extended the warranty . I've called to complain but I got no help. They said it had to be for the same problem each time. Even the tech said the oven was a lemon but he couldn't help us. Any suggestions?
    Jan 29, 2008 | Kenmore 46123 Stainless Steel Electric...
    Kitchen Ranges Logo
    3,541 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
