Tip & How-To about Computers & Internet
So many people ask here about:
Test your PSU or replace it if your power supply units fan
is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or
to shutdown or fail to detect your hard drive
Test the leads that attach
to your ((hard drive from the motherboard)) or replace all the leads that
attach to your hard drive including electrical extensions + IDE,SATA and the
ones that attach from your ((motherboard to hard drive))
make sure all leads that
are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections
and are not faulty even the electrical extensions or just replace them they
could be faulty a computer needs its connections needs its connections continue
its cycle and to have an end so any faulty leads will end up with a computer
error
hope this helps
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
