Question about LG WM-2277HW Front Load Washer
Error Code FE
I have a WM2277HB and the water does not turn off even when the machine is turned off. When turned on it continually runs a cycle never stopping. The error code is FE. Does anyone have any suggestions, clues?
Has anyone ever had this problem - if so what needs to be done. I have laundry to the ceiling HELP!!!
  • 3 Answers
As a temporary workaround, until you repair/replace the valve - you can shut the water off at the tap. Frequently, that will get the water valve in the machine to shut off, and when you reopen the tap the water won't be running (until the next time the machine wants to fill). You can babysit the machine, shutting off the water when necessary, and it will eventually wash your load.
Posted on Mar 24, 2008
  • 66 Answers
You need to ck the water valve is not truning the water off. open the top cover and you will see it you may need to replace it
Posted on Feb 05, 2008
LG Dishwasher runs to about half of cycle than code comes up on screen with FE
"Water Overflow Error"?
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/413-200-684362-/LG-FE-WATER-OVER-FLOW-ERROR-Water-continuing-to-enter-machine-LDS5811WW
Dec 01, 2017 | LG Dishwashers
WHAT DOES A UPSIDE DOWN FE CODE MEAN ON A WM2277HB LG WASHER FRONT LOADER
I think it is actually a 'tE" error code. Thermistor error. Pretty easy fix. And under $10 part. Repair videos exist on YouTube, repairclinic.com or appliancepartspros.com. I would suggest that you look at videos and see how they all suggest you do the repair. Top off, control panel off, front off. Fairly complicated but very doable. If you get the part and study the parts diagrams, you can do the part replacement by turning washer on its side and do replacement from underneath. Takes a little feeling around but much easier.
Feb 16, 2017 | LG Washing Machines
Lg model lds5540 smells, will not clean properly and doesn't seem to have enough water during cycle. also occasionally shows the fe error code. ??? any thoughts?
WATER OVER FLOW ERROR // Water continuing to enter machine
The manufacturer has assigned this error or fault code to indicate that the washer is overfilling due to a defective water inlet valve. The valve is not repairable and will need to be replaced.You can check it with a multimeter to confirm, it should show continuity on both hot and cold pins. try exchanging the how and cold water hoses, cold on hot and hot on cold, see what happens. have u tried running only cold water or hot water wash? as for the smell could be a build up of detergent or frabic softner, try washer running machine with hot water and vinigar to clean out also check inlet valve for dirt build up
Dec 08, 2016 | LG Washing Machines
FE code on LG washer.
The FE code is an excessive water supply if the water is continuously running into the machine it may be due to a failing inlet valve or stuck float switch since you mentioned the drain pump filter being changed it could be that the old filter was restricting the flow.
Apr 28, 2015 | LG WM Washing Machines
During the rinse cycle the water continues to run until I turn it off at the valve. Error FE shows on the screen. What's wrong?
dirt has finds it way into the water inlet valve,,,why?,,,,,,no filteru can loose it out,,it has four screw each
Jan 16, 2015 | LG Washing Machines
FE Code for model WM1812CW LG Washer
Hot water inlet valve most likely needs replacing
May 14, 2017 | LG Washing Machines
Error code FE
From the manual ,FE means Water level is too high due to a faulty water valve. hence the possible leak
Dec 22, 2009 | LG WM2277H Front Load Washer
"FE" error code; won't stop filling
Hello Sheri Tucker,
The "FE" code is referring to a bad or malfunctioning water valve. The machine continues to fill because the solenoid on the valve inside the machine isn't closing to stop the water. The valve should be inspected and/or replaced if bad. This will require some dis-assembly, if washing machine repair isn't something your comfortable with then a service call is the best bet. If you are going to try and inspect yourself please make sure you unplug the machine before starting any dis-assembly. Hope this helps.
Thanks,
edgin96
I’m happy to assist further over the phone at https://www.6ya.com/expert/ryan_7b238a1b08d97b98
May 19, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM-2277HW Front Load Washer Logo
334 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
