Question about Kenmore 46462 Front Load Washer
Won't do anything
We have the Kenmore HE2 model #46462. We started a load of laundry. Went back in to check on the laundry to find all lights flashing. Tried everything in the book to reset it. Unplugged for 15 minutes, the spin/drain solution. When we restart the washer, the locked door light and add a garment lights come on. Nothing happens. It makes a noise like it is trying to run. We checked the filters and hoses and everything is fine. We have only had the washer for 17 months. This is very discouraging and hope someone has some answers. We can't afford a repair bill. The was pretty expensive and should last longer than this.
Thanks for any advise.
busy mom
  • busy mom 2 Feb 12, 2008
    We finally had a repair guy out and the problem was the detergent. Be sure to use the HE detergent. We had a sudslock. Regular detergent suds way to much. It caused the machine to shut down. The repair guy showed us what to do should we go back to regular detergent. He also suggested thinning the fabric softner. The machine is very sensitive. He also recommended running a empty load on hot water using cascade dishwasher powder once a month to clean out everything thoroughly. Good luck to the rest of you.
  • busy mom 2 Feb 17, 2008
    Frustrated Kenmore Owner,
    He took the front bottom panel off. If you have a base on your washer, it is the one above it at the bottom of the washer. You will need a screw driver for this. There is a large drain pipe on the right that you will unscrew. Get a bucket and clean it out some, there is a filter there as well. With that open and the bucket in place, push the rinse/spin button and start it for a moment. Alot of dirty smell water comes out. It is running fine now. The problem is called a suds lock. The repair center should be able to take you through it as well. Before you do any laundry, do the cascaed load with hot water. I hope this helps you. Good Luck. We also signed up for the maintenance plan while the repair guy was here. I feel it is worth it just in case anything else happens.
    Busy Mom
Hello Busy Mom,
I am having this same problem, what exactly did you do to fix the issue? Has the problem gone away?
Thanks,
Posted on Feb 14, 2008
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Feb 08, 2008
Kenmore HE2 Won't Turn On
1) test the power cord for open 2) test the outlet box, see for blown fuse or c.breaker put some desk lamp and see if work 3) test inside of the control board if there fuse blown or c.breaker tripped 4( test the lid switch is closed, can be faulty or open replace 5) test the input voltage 115 if there are the control board faulty.
Jul 18, 2012 | Kenmore HE2 Plus Front Load Washer
Very loud spinning cycle
was the shipping bolts removed when it was delivered there are four in the back
Mar 29, 2009 | Kenmore HE2 Plus Front Load Washer
I have an elite he2 plus frontloading kenmore washing machine and no water is coming in the washer.... the temperature has been low here, but i have taken every precaution to ensure that my pipes aren't...
Only if your temperature in your area goes below 35 degreesF.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 16, 2009 | Kenmore 46462 Front Load Washer
Water pouring out of detergent dispenser drawer
There is a rubber hose that connects dispenser housing to outer tub of washer. Disconnect hose at outer tub and fish out article of clothing that has wedged itself in there cuasing water to back up and pour out of dispenser. In the future use a linen bag for small articles of clothing such as underwear and socks.
Dec 31, 2008 | Kenmore 46462 Front Load Washer
Water coming out from detergent dispensor drawer
Is this an HE2 washer? if it is, open door gently tug at bellows top left hand corner you should see a small piece of clothing stuck between tub and dispenser inlet to the tub.
Kenmore HE2 flashing lights
had an old pressure switch that I thought was the problem I had from something else a year ago
That was the washer not starting, all kinds of lights
I took the back and top off and reconnected all the plugs.
Had a loose connection somewhere, it worked after that.
I blew into it and put it back on.
The rattleing quit in the pump after it pumped out, while the drum was spinning slow.
Now working ok
Nov 24, 2008 | Kenmore 46462 Front Load Washer
My washer won't get any water in and all lights are flashing.
possibly water inlet valve has failed this is the valve where the water supply hose screws onto on the back of the machine
Jun 11, 2008 | Kenmore 46462 Front Load Washer
Kenmore HE2 Dryer makes three beeps but wont start
Check your door closer switch. Mine was doing the same and it turned out to be as easy as changing the switch.
Mar 23, 2008 | Kenmore 62602 Electric Dryer
Kenmore HE2 Front Loading Washer
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Feb 24, 2008 | Kenmore 46462 Front Load Washer
Kenmore he2
Press and hold the "end of cycle" button for over 3 seconds, it will reset. You will hear a beep.
Dec 25, 2007 | Kenmore 46462 Front Load Washer
Kenmore 46462 Front Load Washer Logo
154 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
