Question about Sony Handycam DCR-TRV250 Digital Camcorder
Recording from a vcr
Cannot get the camera to record direct from tape in the vcr have tried s video and the av leads have followed the manual but nothing happens screen remains blue made sure the screen was set to LCD as per manual.Have made sure I connected the leads to OUT on the vcr so think I have covered all the obvious things. Can anyone help ? thanks
    Brigadier General:
  • 6,966 Answers
Based on your post/description, your concern is transferring a VHS tape movie to your Sony TRV250.
Just to review:
1. You are using the Sony supplied A/V cable;
2. The yellow RCA is connected to the Video OUT of the VCR, the white/red to the Audio OUT of the VCR;
3. The other end of the cable is connected to the Audio/Video IN of the Sony;
4. You have followed the manual and switched the camera to VCR;
5. You press the REC and PAUSE on the cam;
6. You press the PLAY on the VCR; but
7. The movie in the VCR tape is not displayed in the cam's screen/LCD display.
If the above is accurate, then pls try changing step # 4. Instead of switching the Sony cam to VCR, switch it to CAMERA and see if you can now view the movie from the VCR.
If this does not work, pls try with S-Video cable and again switch cam to CAMERA.
Hope this be of help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Feb 03, 2008
  • Julie Dole
    Julie Dole Jan 16, 2014
    Thank you! Even though it's 2014, here I am looking for the answer to this same question, since I had to transfer a friend's VHS for her editing reel - thanks again!
Check a/v imput on camera settings, make shure that u have audio alsso conected, tried to use diferent output (DVD), make shure is playing .,
Can I transfer video tapes onto CD's
A lot depends on what type of video tape you use and where do you want to play the DVDs (CDs are for audio recording only). If tape is compact VHS then you can buy a simple DVD Recorder VHS VCR combo player and transfer across easily provided you have the compact VHS cassette module.
http://www.gumtree.com.au/s-ad/reservoir/tv-dvd-players/lg-v271-vcr-dvd-player-combo-recorder-6-head-hi-fi-stereo/1073556241
For other type of video camera tapes you will have to try other methods like connect camera with tape to a DVD recorder and directly burn the DVDs. You can buy attachments and software for PC but I have found these very cumbersome to work with.
Mar 16, 2015 | Video Cameras
HOW DO I RECORD WITH A SONY SLV-N77 MANUAL DOES NOT HAVE ANY DIRECTIONS
Looks like a great brand with good features for the price.
  1. Connect Video & Audio Cables to a video signal source
  2. Connect Power Cable
  3. Turn on VCR.
  4. Insert a blank tape in the VCR.
  5. Note - A Broken Tab on the back of tape will prevent recording. This is called Write Protection.
  6. Cover the tab hole if you want to record over old video.
  7. Press RECORD on the VCR remote control.
  8. After a minute, press Stop, then PLAY to see recording.
  9. Cheers
Aug 18, 2014 | Sony SLV-N750 VHS/S-VHS playback VCR
I can't record a DVD from VCR. I tried hooking straight to front av jacks,no luck. I have dish network it's set on channel 25,video 1 on the tv. No problem recording from dish,just can't get it to record...
You need to select front AV as you video source on the DVD recorder if using the front AV phono connectors. Make sure the lead you use from the VCR is working y connecting the AV leads directly to your TV if possible.
Mar 03, 2011 | Philips Magnavox MWR10D6 DVD Recorder
Can a Go Video 3140 make a dvd disk copy from vcr tapes
Yes,read ur manual intructional book how to hook up the tv, VCR/DVD sides togother so it all link up.Play a VCR tape one side and record a DVD disc another side.
Nov 08, 2010 | GoVideo Go Video DVD/VCR Combo
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Need to transfer order VCR-C tapes to DVD How
You will need to borrow or buy a DVD-Recorder, either way it's best to follow the manuals instructions on how to connect your camcorder (external device) to the DVD Recorder for Recording to DVD. Most camcorders come with a set of AV (audio/video) Cables for this purpose. On your camcorder you will find a little rubber door that houses the terminals to connect your cables to. Depending on how old your camcorder is you will find a Yellow (video) and a White (audio) and on the newer ones that have stereo capabilities...you will have a Red (audio), all these connections are video and audio Out-Inputs and should be connected to the Video and Audio "In" terminals on the back of the DVD Recorder. Now make sure your battery is fully charged (It's best here to use an AC Adapter for your power supply instead of your battery, which also usually comes with your camcorder if bought new.) and that your VCR-C tape is loaded and completely re-wound. Now if you want to watch this on your TV while you are recording to DVD...you'll need another set of AV Cables that come with a new DVD-Recorder, and hook these cables on the Out-terminals on the back of the DVD- Recorder and the other end of the cables to your TV's Video/Audio-IN terminals on the back of the set. Finally...Set your camcorder switch for Playback, turn on the DVD Recorder, And turn on your TV. Now you can go ahead and record all your VCR-C tapes to DVD! Any other questions? Contact me directly at over4dy@yahoo.com
Jul 29, 2009 | Video Cameras
VHS to Canon MV450i transfer or direct to Mac
The MV450i has an AV input. So get a lead to go from the AV out from the VCR to the AV input at the front RHS of the lens (3 pin stereo jack socket behind grey cover - the lead was supplied with the camera). Go to the buttons behind the screen - press the line in button - camera goes to pause. Se the VCR playing - press the play / focus button to start recording to the tape.. Import to imovie as you normally do.
Alan
Dec 22, 2008 | Canon MV450i Mini DV Digital Camcorder
How to record from a VCR onto a canon mv530i
OK get a set of cord that can be used, on the back of most VCR's there is RCA Sockets for Video & Audio out... generally Red & White & Yellow these go to the corresponding inputs on the camera's Video & Audio inputs, OR Correct adapter. The camera must have the correct A/V INPUT selected. Then start the VCR to "Play" the tape, and set the Camera to "Record" this will/should then record the output from the VCR to the memory in the Camera.
Aug 21, 2007 | Canon MV530i Mini DV Digital Camcorder
Cannot tape a video
Please connect video out and audio out of your TV to video in and audio in of your vcr respectively.Switch on the TV and the VCR.Put the VCR on camera or AV mode.Press the record key on VCR.The VCR will record the programme being shown on your TV.Thanks.
Jan 16, 2007 | Sansui VRDVD4001 DVD Player/VCR
Recording From An External Device
The following Models can be used as a recorder to record from a VCR, TV or another Camcorder. 2004 - SC-D107 2003 - SC-D5000, SC-D27 2002 - SC-D180 Recording In Player Mode 1. Connect the camcorder to the VCR or TV with the AUDIO/VIDEO cable (provided) (to the A/V Outputs on External Device) 2. Set the power switch of the camcorder to PLAYER mode. 3. Turn on the VCR or TV. 4. Insert the blank tape with protection tab closed into the camcorder. If you want to record from a connected VCR, insert a recorded VHS tape into the VCR. 5. Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. 6. Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. "AV IN" and picture appears on the LCD monitor. OUT : Releases the INPUT mode. 7. Press the START/STOP button to set the camcorder to REC PAUSE mode. "PAUSE" appears on the LCD monitor. 8. Select the TV program or playback the VHS tape. 9. Press START/STOP button to start recording. If you want to pause recording for a while, press the START/STOP button again. 10. To stop recording, press the (STOP) button. Notes: * Recording from an analog VCR to the camcorder is only possible when the VCR is playing back at normal speed. * If you want to see the camcorder picture with a TV, set AV IN/OUT in the menu to OUT.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Sony Handycam DCR-TRV250 Digital Camcorder Logo
146 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
