Question about Dryers
Replacing thermal fuse on dryer
I received an e-mail from your site about probably needing to replace the thermal fuse. Can you possibly tell me where to look on the dryer for the fuse, and what it should look like? Thanks a million.
  • 240 Answers
Would need to know what type of unit you have and a model number. On most Kenmore and Whirlpool models they are mounted on the heater box itself. Depending on the type it could be inside the rear panel, or mounted on the floor of the unit. On Frigidaire and other models it mounts to the element case in the rear. Maytags also mount to the element box on the top left inside. Most of the time they have a couple of different looks. On Whirlpool and Kenmore, they have 2 wires running to them, and usually sit away from the thermostat. If its inside the rear panel of these units, it will be towards the top by itself, and could be white or black depending on the age, round or sqaure. On GE, Frigidaire, and their look a likes, it will be small and round, with two wires going to them as well. Most of the time these are metallic in color. Maytags can be black or mettalic, and sit on the sides of the boxes. If this doest help you, please get me the model number and make of unit, and will tell you right where its at. Good Luck!!!!!
Posted on Feb 03, 2008
Dryer stopped heating...what to do?
Hello there
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Dec 08, 2010 | Dryers
My maytag electric dryer wont heat up
Apr 28, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
My dryer does not heat. Fuse, thermostats, heat element all have continuity, power chord is good, 240v at plugin... stumped. It is a model # LER4634BQ1 Whirlpool SN# ME4471484
Feb 06, 2010 | Whirlpool LER4634J Electric Dryer
My dryer will run, but will not heat.
Hello there
Heating Element
Thermal Fuse
Thermostat
Timer motor
Jan 25, 2010 | Speed Queen AES28AWF Electric Dryer
Dryer will not heat up when running. Was told to check the thermo fuse, ignitor and/or coil. Is that right? How do I check those things.
hello there
Please follow this procedure I have provided below and it will tell you how to test each one ok
Hope this is very helpful
Proper Voltage
Jan 24, 2010 | Kenmore Dryers
DRyer is turning just not drying clothes Maytag
Hello there:
Proper Voltage
Jan 19, 2010 | Dryers
The dryer quit running and became extremely hot
Hello DickandKendra! You've already done the difficult part, which was to find and locate the faulty thermal fuse (switch). Now you should be able to get a new one and replace it pretty easily, just be sure to unplug the dryer before you start taking it apart, etc., but you already knew that.
If you need to determine what the replacement part number is for your particular dryer is, please go to www.searspartsdirect.com, since you didn't post your model number, I can't provide you with the part number directly. No problem, you can find it by entering in your Dryer model number and then click on the links that show up to locate the thermal switch. There will also be a line drawing of your Dryer, so you can search by the picture, etc.
I think that possibly that the dryer motor has failed and that is why the thermal fuse went out, but you should probably just replace the fuse 1st to see if that's the only issue. When you replace the fuse, just run a drying cycle without heat, (only air fluff, etc.) so you can see if the motor starts and runs. If it does, then the thermal fuse was the problem, if the motor doesn't run, you've got a faulty motor and it'll need replacement.
Of course, if you're comfortable with doing a temporary bypass of the thermal fuse, you can also check the motor function before you order and replace the thermal fuse, to determine if the motor is faulty. The temporary bypass is ONLY to be used to diagnois if the motor is good or bad - DO NOT leave the thermal fuse bypassed, as it's purpose is to prevent a dangerous overheating problem that can cause a fire. This is only to be done as a temporary measure to determine what caused the thermal fuse to blow!
This will allow you to determine if you want to spend the money and time needed to replace the motor and thermal fuse, or weigh those costs against purchasing a new dryer - your option. However, if the dryer is still in good condition, it will cost much less than buying a new one, even with the cost of these couple of parts.
I hope you find this Very Helpful and best regards!
Nov 25, 2009 | Kenmore Dryers
Electric dryer wont start
Just replace the thermal fuse for now. You have gotten good use from this machine. But, this is also may be the beginning of the end. Thermal fuses are not expensive either. These things just go out at no uncertain times.
Feb 01, 2009 | Whirlpool LER5636P Electric Dryer
GE DVLR223 Not Heating--Is there a reset?
There is no reset. What he did was probably replace the thermal fuse. Why did he not clean it out for ya? Anyway when the thermal fuse goes bad either the whole dryer or the heat won't work. If you can open the dryer up by removing the front panel, you can test your thermal fuse for continuity. If none replace it. While you have the front off undo your belt and remove the 3 screws that secure the rear of the drum (inside drum in middle at back) pull drum out and make sure heat element is not broken. Here is a site for your dryer check it out. www.repairclinic.com/Appliance-Parts?s=t-dvlr223-%3d%3d&z=100 Good Luck
Jan 11, 2009 | GE DVLR223 Dryers
Thermal fuse change on Kemore 970.c85042-00
First you need to know your dryer over heated and the thermal fuse tripped for a reason.
You will need to replace the thermal fuse, thermal fuses are there to protect the dryer. When you have the dryer apart clean all the venting and vacuum out the dryer. Look online for a parts supplier in your area, you will need your model and serial number to order the thermal fuse they are about ten dollars.
how long is the venting, does it exceed 20 feet, how many elbows. Make sure the outside hood is clean
May 05, 2008 | Kenmore 63942 Dryer
Dryers Logo
465 people viewed this question
Top Dryers Experts
Marvin
Marvin
