Question about Linksys Wireless-G WRT54G Router
HELP ME GET MY WII CONNECTED!
I enter my wep code and the Wii gives me an error. I have no idea on the routers settings. Help me
Check...IP address..and the LAN configuration....
Posted on Feb 05, 2008
I can't get connected to Netflix.All that pops up is error code 51031
This is a Wii we're talking about, right? The code is a Nintendo error code. Look at this link for more info. You may not be configured correctly for your wireless network. A common problem is most routers today use WPA2 encyption and most Wii consoles default to WEP. Many routers don't support WEP anymore.
Nintendo Customer Service Nintendo Wi Fi Connection Error Code Results
Dec 30, 2014 | Netflix
Tip
Nintendo Wii Error Code 51330 usually indicates that the WEP/WPA key you set on...
<span><span style="font-weight: bold;">Nintendo Wii Error Code 51330</span> usually indicates that the <span style="font-weight: bold;">WEP/WPA</span> key you set on your Wii is not the correct one to gain access to your <a href="/../support/t9472672-39_t_connect_wii_netflix_ger_error#"><span>router</span></a>. <br /><br />When you setup a router for wireless internet, you usually set a WEP key or by default one is set. This is basically a <a href="/../support/t9472672-39_t_connect_wii_netflix_ger_error#"><span>security</span></a> key(<span style="font-weight: bold;">password</span>) that you set so any device that wants to use your <a href="/../support/t9472672-39_t_connect_wii_netflix_ger_error#"><span>internet</span></a> has to enter correctly in order to gain access.<br /><br />If you know your router security key, go into your <span style="font-weight: bold;">Wii network settings</span> and make sure it is entered correctly. Click <a href="/../support/r9198848-connect_nintendo_wii_internet">here</a> to read my tech article on how to configure your Wii's network settings. <br /><br />If you do not know the security key of your router, then read my other article by clicking <a href="/../support/r9359087-find_wep_key_router_router_security">here</a>. This article will go over <span style="font-weight: bold;">how to find the router security key</span> or if need be, set one.<br /><br />Be sure to check out my other <span style="font-weight: bold;">Tips</span> by clicking on my profile name and then clicking "<span style="font-weight: bold;">Tips</span>" at the top left. <br /><br />Regards,<br />G33k<br /><br /><br /><br /><br /><br /><br /><span>Keywords</span><br style="font-weight: bold;" /></span><span style="font-weight: bold;">Nintendo Wii Error Code 51330, error </span><span style="font-weight: bold;">51330, Wii </span><span style="font-weight: bold;">51330, Wii error </span><span style="font-weight: bold;">51330, Wii network settings, can't connect Wii to netflix, Wii netflix, Nintendo error code </span><span style="font-weight: bold;">51330, Wii code </span><span style="font-weight: bold;">51330</span>
on Jun 14, 2011 | Nintendo Wii Console
THE WII IS FINDING MY WIFI ROUTER BUT WHEN I DO A CONNECTION TEST IT GIVES ME THE ERROR CODE 51330
Unable to connect to your wireless network error code. I got these instructions from the nintendo site.
Likely cause: It appears that the password (also known as a WPA or WEP key) entered into the Wii console is not the same as what your wireless router is set to allow.
How to fix: Make sure the password is entered into the Wii exactly as it appears in your router's settings. Security keys are case sensitive.
Jun 27, 2011 | Nintendo Wii Console
My wii will not update gives me eror 32002
If you get an error code of 32002 or 52030 on you Wii console, this indicates a problem with your Wii communicating with your wireless router. There are a couple things you can try/check to help fix this problem.
1 - Try using a different channel on your router and update your Wii to take to the router on that channel.
2 - If your router is using WEP (encryption), make sure your Wii is set to the same encryption.
3 - Make sure the MTU values on your router match those entered on your Wii.
Also note that if you make changes to your wireless router and you have a computer that uses that router too, you'll need to update your computer to match the new settings on your router.
Mar 16, 2011 | Video Game Consoles & Games
We cant connect our wii to the internet.. Error code 51330 keeps coming on please help
It appears that the security settings entered into the Wii console are not the same as what your wireless router is set to allow.
Make sure the security key and security type are entered into the Wii exactly as they appear in your router's settings.
Once you have entered the correct WEP or WPA key into your system, try the connection test again. If the problem persists, keep reading this page.
  • Security keys are case-sensitive.
  • WEP keys contain numbers 0 through 9, and only letters A through F.
Jan 16, 2011 | Computers & Internet
I can't get my wii on line it keeps coming up with error code 50300 or 50200
Error Code: 50300 The Wii console's internet connection settings are not correct. This could include your network name (SSID), WEP or WPA keys, or any manual settings you may have entered.
  • It's possible something has changed since you last connected online with your Wii console. Try setting up a new connection file, using your router's settings. Click here for help.
  • While "Search for an Access Point" is the easiest and recommended connection type, your network may require you to use the "Manual Setup" option. Click here for help.
  • If the problem persists, try our general troubleshooting for tips.
If you are still getting this error code, please call 1-800-255-3700 for further assistance.
Error Code: 50200 Specific Error Code Not Found - General Troubleshooting
  • Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available).
  • Check your router's broadcast settings to find out if it is set to "G", "B", or "Mixed." Mixed typically works best, but try all three to see if it improves the network connection to the Wii console.
  • Make sure that any other interfering devices, such as microwaves and cordless phones, are turned off. Wireless keyboards and mice may also cause interference.
If you are still receiving this error code, please click here for assistance.
Aug 10, 2010 | Nintendo Wii Console
Cant get online through sky broadband
Wii Error Code 51331 means there is a problem with wireless security.
Make sure your router’s WEP/WPA (one or the other not both)key matches the WEP/WPA Key you entered in the Wii.
If you double checked the WEP/WPA key with the router and the Wii and they match, but you still receive the Wii Error Code 51331, then MAC filtering may be enabled in the router. You will have to add your Wii’s MAC address to the router’s allowed list. You can do this by logging into your router and going to the “access control, access list, or network filter” settings.
If you still have trouble with Wii Error Code 51331, try changing the wireless router’s channel to 1 or 11.
Jul 24, 2010 | Nintendo Wii Console
EROR CODE 52031 ON NINTENDO WII
Hi,If you’re using WEP or WPA for your router’s security, log into your router by typing its IP address in your internet browser and make sure your WEP or WPA key entered in the Wii matches the key in the wireless router. The WEP Key can only use characters 0-9 and A-F. If your router allows more than one WEP Key to be entered, make sure the key in slot #1 is the active key. The Wii can only use the key in slot 1.If you entered the correct key, then check to see if MAC filtering is enabled in the “access control, access list, or network filter” section of the wireless router. If MAC filtering is enabled, you will need to enter the Wii’s MAC address into the “allowed” list for MAC addresses.
If none of these were the problem and your connection used to work, try power cycling both the router and modem by unplugging both from the wall. Wait a couple of minutes before plugging the modem back in. Wait another couple of minutes for the modem to initialize, then plug the router back in and wait until the router initializes.
Ensure that your wireless router has the latest firmware installed. You will need to go the router manufacturer’s website to download the firmware.
If Wii Error Code 52031 is still a problem, try changing the broadcast channel of the wireless router to 1 or 11. This can help increase download speed.
You an also try manually entering the Wii’s internet settings. You will need to first get the network configurations from your PC.
On your PC, click “Start” and then “Run.”
Type “CMD” into the field that appears to open a new window.
Type “IPCONFIG/ALL” and press “Enter” to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Good luck
Jun 10, 2010 | Video Game Consoles & Games
Error Code 51331
Make sure your router’s WEP key matches the WEP Key you entered in the Wii.
If your router is using 64-bit encryption, the WEP Key must be 10 characters.
For 128-bit encryption, the WEP Key must be 26 characters.
WEP Keys can only use the characters 0-9 and A-F.
If your router allows more than one WEP key to be entered at a time, make sure the key you’re using is on slot one.
If you double checked the WEP or WPA key with the router and the Wii and they match, but you still receive the Wii Error Code 51331, then MAC filtering may be enabled in the router. You will have to add your Wii’s MAC address to the router’s allowed list. You can do this by logging into your router and going to the “access control, access list, or network filter” settings.
If you still have trouble with Wii Error Code 51331, try changing the wireless router’s channel to 1 or 11. This may increase download speed.
Check Nintendo’s router page for special notes on your router if available. Follow the instructions of the special notes.
Your wireless router must broadcast in mixed or b/g mode and cannot be set to “g” only mode.
If you still encounter the Wii Error Code 51331, try doing manually setting up the Wii’s internet connection. You can find your network information to enter into the Wii by doing this:
Power cycle the wireless router and modem by unplugging both from the wall. After waiting a minute, plug the modem back in and wait another couple of minutes for the modem to initialize. Plug the router in and wait for the router to initialize. Now try reconnecting the Wii to Nintendo WiFi Connection.
Hope this helps a little
Sep 10, 2008 | Nintendo Wii Console
Error code:51331
Jul 02, 2008 | Video Game Consoles & Games
Linksys Wireless-G WRT54G Router Logo
61 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
