Question about Nikon D40x Digital Camera
About the spots on photos..
I have few grey spots on all my photos..especcialy on the blue ,light gray or white..and deep blue ones
I have the camera for 8 days now..and I keep having this problem toghether with a non Attached lens eror....is this a problem who ..normally can be solved..by chaging your camera?I mean..I really dont know how this works...the spot problems is not a thing to be solved on this camera ....must be changed...right?
  • 2 more comments
  • andi n.
    andi n. Feb 03, 2008
    yes...new in the box...last week...Im affraid it is  a ccd failure...not just  a simple dust problem...
  • andi n.
    andi n. Feb 04, 2008
    I got it back today in order to be sent to nikon to check this problem..Thanks a lot man..really helped;)
  • andi n.
    andi n. Feb 25, 2008
    I sent the camera to nikon..I got it back...well..hopefully it was just a dirty sensor..however ..well..same error with the non atached lense..strange...who knows...
    bye
  • Anonymous May 11, 2010
    Spots would indicate a dirty CCD sensor, did you buy this new?
  • 667 Answers
I recommend returning it. Nikon's QC may be lacking these days
Posted on Feb 03, 2008
6ya staff
SOURCE:
Why is the white background not white?
This is a common problem. The metering and light balance are the reasons that you are having problems achieving good results with your photos.
All cameras on the auto cycle are calibrated for 18% gray. Another words a photo of all white results in 18% gray. A photo of black results in 18% gray. The camera adjusts the shutter speed and aperture to achieve an average light level of 18%. That is why photos of snow always appear gray. To compensate for this characteristic of the cameras an 18 % gray panel is held in front of the camera and than the settings are set.manually. The metering in the camera is now locked and using the same light levels objects will be in their natural level.
A second problem is the white balance. Using flash avoids some of these problems. Adjusting the camera for source lighting type will help the most. The light balance is the cause of discoloration of the objects in the photo. Usually the camera white balance can be set for auto, incandescent, fluorescent, outdoor or flash,
Use a manual setting if it is available on you camera, You need to adjust the settings until you get acceptable results. If the photo is dark add light by reducing the aperture number to a lower number allowing more light. After the aperture is open wide(lowest number) increase the exposure to longer time. With very low light levels a tripod may be necessary.. After doing this once record the numbers for next time.
Nov 15, 2015 | Nikon COOLPIX L100 Digital Camera
Grey spot on photo
NOISY PICTURES One of the major difference between a consumer digital camera and a digital Single Lens Reflex (DSLR) is that the former produces images with a lot of noise when using high ISOs and long exposure times, and the latter is practically noise-free (though high ISO performance varies depending on camera manufacturer and model). Noise is apparent by the presence of color speckles where there should be none. For example, instead of a blue sky, you notice faint pink, purple and other color speckles amongst the otherwise blue sky.
read AT http://www.photoxels.com/tutorial_noise.html
Apr 03, 2012 | Panasonic Lumix FX48 Digital Camera
Hi, im searching for the stereo wiring chart for my mitsubishi lancer 2002 GLXI. i have searched for it but the colours are completely different to what i have. For example the colours i have are - Blue/...
This is all I could find. Hope it helps.
WIRE COLOR POLARITY LOCATION
Battery RED/BLACK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination GREEN/WHITE (+) RADIO HARNESS
Power Antenna YELLOW (+) RADIO HARNESS
LF Speaker (+) WHITE/BLUE
LF Speaker (-) BLACK/BLUE
RF Speaker (+) WHITE/RED
RF Speaker (-) BLACK/RED
LR Speaker (+) YELLOW/BLUE
LR Speaker (-) GRAY/BLUE
RR Speaker (+) YELLOW/RED
RR Speaker (-) GRAY/RED
Apr 14, 2011 | 2002 Mitsubishi Lancer
Spots in the same place
Sounds like dirt on the sensor. Google the words "cleaning a DSLR sensor" and you will find sites explaining the procedure and places to obtain supplies. It's very easy to do yourself.
Apr 03, 2010 | Canon EOS 30D Body Only Digital Camera
Wiring diagram for a Clarion CZ109
Clarion uses the industry standard wiring colors. Not every unit will have all of the listed wires
SPEAKERS:
White = Left Front +
White/Black = Left Front –
Gray = Right Front +
Gray/Black = Right Front –
Green = Left Rear +
Green/Black = Left Rear-
Violet = Right Rear +
Violet/Black = Right Rear –
POWER/ACCESSORY:
Yellow 14ga = Battery Main/Memory
Yellow 18ga = Battery CeNET Power/Memory
Red = Accessory (ignition on)
Black = Ground
Blue = Antenna Turn On +
Blue/White = Remote Turn On (amps) +
Orange/White = Dimmer
Brown = Phone Mute
Orange or Mint Green= Parking Brake Video Lockout
White/Red = CCD (camera) input instant on +
RCA Cables:
Gray = Front Output
Black = Rear Output
Purple = Non-Fade or Subwoofer Output
Aug 29, 2009 | Clarion CZ109 Car CD Player
Need a wiring diagram for a clarion db185mp
SPEAKERS:
Green = Left Rear +
POWER/ACCESSORY:
Black = Ground
Brown = Phone Mute
RCA Cables:
Gray = Front Output
Black = Rear Output
Dec 27, 2008 | Clarion DB185MP Car CD/ MP3 Player
Grey cable in dash
Hi again,
Appreciate the update and additional information. If I understand it right, your vehicle then has two connectors at the back: 1 big black/red/gray plug:
  • Yellow/light Green - always ON B+12;
  • Yellow/Black stripe - ACC B+12 goes to the IGN switch;
  • Black - chassis/ground;
  • Blue - remote trigger for add-on amplifier (if connected);
  • Blue/Red stripe - illumination (can go to parklight switch).
and the 2nd smaller gray 8pin plug:
  • White/Red Stripe Right Front +
  • Brown right front -
  • Green Left Front +
  • White/Orange Stripe Left Front -
  • Light Blue/Black Stripe Left Rear +
  • Yellow Left Rear -
  • White/Blue Stripe Right Rear +
  • Light Blue Right Rear -
Cheers.
Aug 28, 2008 | 1994 Ford Explorer Limited
1998 ford el xr6, need stereo wiring harness colours
You did not specify if you wanted the wiring diagram for the Expedition or the Explorer, so I got you both. Good Luck
1998 Ford Expedition Stereo Wiring
Constant 12V+ White/Purple Switched 12V+ Black/Pink Ground Black/Green Illumination Blue/Black Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 6" x 8" Doors Left Front (+) Light Blue/White Left Front (-) Orange/Light Green Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 6" x 8" Rear Doors Left Rear (+) Tan/Yellow Left Rear (-) Gray/Light Blue Right Rear (+) Brown/Pink Right Rear (-) Orange/Red
1998 Ford Explorer Stereo Wiring Constant 12V+ Light Green Switched 12V+ Yellow/Black Ground Black Illumination Light Blue/Red Dimmer n/a Antenna Trigger Orange/Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 5" x 7" Rear Door Left Rear (+) Gray/Light Blue Left Rear (-) Tan/Yellow Right Rear (+) Orange/Red Right Rear (-) Brown/Pink
Feb 22, 2008 | Car Audio & Video
Undo White Balance Sony F707
If you have Photoshop: Layer>New adjustment Layer>Levels Use the middle eyedropper tool and click on something in your photo that should be gray/dark gray. Or: Use the white eyedropper (far right eye dropper) and click on something in the photo that you know is (or should be) white. You can try the gray first, then the white.
Sep 12, 2005 | Sony Cyber-Shot DSC-F707 Digital Camera
White spots
In addition, flash lighting dust doesn't make a white spot, but a fuzzy whitish circle (out of focus). The image underneath is still visible, but distorted. These are definitely not flash reflecting on dust.
Sep 07, 2005 | Panasonic Lumix DMC-FZ5 Digital Camera
Nikon D40x Digital Camera Logo
207 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
