Question about Kicker Solo-Baric L5 Car Subwoofer
Which Jl Audio 12 Has No Writing On The BAck
I got this old set of jls that sound great but one of them ripped. I only wanna replace one but I cant figure out What Model it is. It Has No Markings on the back except for the barcode number. Has the white JL Sign on front. Dual Voice Coil.
You could allways go to jlaudio.com and compair it to the subwoofers of the same size its pretty easy to tell
Posted on Nov 10, 2008
    Problem Solver:
  • 7 Answers
Probably JL12W0
Posted on Feb 12, 2008
    New Friend:
  • 101 Answers
Http://www.simplyspeakers.com/speakerrepairinstructions.htm
go with the repair .those r good subs,very expensive. i repaired a pokl 12" sub cone and surround foam. never had a problem. save me 300 bucks.the cone you can fix by using the same material that it is made off.if paper use rubbeer glue. if plastic ,i used a 2 part epoxy,airplane glue.didn't look pretty but did the job.rating please
Posted on Feb 09, 2008
I have a 12 w7 it damage from shipping all the surface is rip can it be fixed
yes call jl audio and tell then the number is 954 443 1100 they should replace the sub for you
Oct 09, 2010 | Jl Audio 12W7 Car Subwoofer
I have 2 12 inch jlw6's and need a amp but dont know what would be better, if i get 2 jl 500/1 or 1 jl 1000/1, or if other amps out there would be good for a reasonal price, any advice would help...
yea the jl either setup will be good for those woofers but for the money an to get the power i would try a hifonics 2000 or the 2600 brutis or mtx or2 poweraqustic 4000 planet audio they will work great or give me a call there are a lot of amps to choose for the money an the power
Jul 08, 2010 | Jl Audio 1000/1 Car Audio Amplifier
JL Amp isn't powering subs and speakers
silly as it sounds, you may want to check your EQ settings on your headunit. Things like sub volume, SLA, loudness and balance. When they replaced your battery, those old settings were lost.
Mar 26, 2010 | Jl Audio 500/1 Car Audio Amplifier
My Jl Audio 500/1, power light comes on but no power to subs
maybe it dont have enough to push it ,,did you try it before you buy it?
Mar 01, 2010 | Jl Audio 500/1 Car Audio Amplifier
Jl audio 12w3v2 sounds like its blowing air out of box
if you cant see a physical cut or **** in the rubber surround or anywere else you can try to check the wires going from the plug to the actualy speaker itself on the back of the speaker if those are fine then its probably blown if its not that old you can try and contact jl and see if they will replace them i know kicker has some kind of replacement system in play not sure of jl
Feb 28, 2010 | Jl Audio 12W3 Car Subwoofer
Trouble with jl amp
well start with. turn your hi pass completely off. Turn your bass boost completely off. Turn your input gain copletely down. and turn your cd player to about 3/4 of what you listen to it at. Then turn your input up until it starts to sound a little dirty(distortion) then turn it down a notch. set it at a 80 herz filter so it allows nothing over 80 herz to come through. I just installed one of these jl amps a week ago. 1400.1 and it made two kicker cvt's sound amazing just have to set it just exactly like i told you. it will hit tight as hell and loud and it will hit all frequencies way better.
Jun 09, 2009 | Jl Audio 1000/1 Car Audio Amplifier
JL 500/1 Problem
You need the old transistor. Knowing it's brown is not enough; you need to know its resistance value. It sounds like the resistor you replaced with has too low a resistance value, causing the "cuts" in sound. Find the old resistor and then use this site to find out what you need:
http://www.dannyg.com/examples/res2/resistor.htm
Jan 13, 2009 | Jl Audio 500/1 Car Audio Amplifier
Problem when hooking two 12 inch subs to one amp
the amp is no where near strong enough that sound you hear is called hard clipping and it will destroy your subs in minutes. depending on what model JL subs you have I can sell you a better amp.
Dec 30, 2008 | Planet Audio VX602 Car Audio Amplifier
System not playing
Sounds like the output transistors on the amp are blown. Were you slammin when it stopped or how did you find out it stopped working. It could be the sub failed then caused the ap to go which is why you get a little something from the JL.
Feb 11, 2008 | Car Audio & Video
How to connect it
bridge the amp and wire the JLs in parallel..then put some earplugs on ..lol
Dec 23, 2007 | Jl Audio 1000/1 Car Audio Amplifier
Kicker Solo-Baric L5 Car Subwoofer Logo
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
