Question about Canon MX300 Office All-In-One Printer
Paper feed problem
MX300 will not feed blank paper into the machine to be printed. Rubber rollers which are supposed to grab one sheet of paper and feed it iinto the machine do grab one sheet move it about one third of an inch--cause the paper to be wrinkled where they grab it but never feed it into the machine. Then I get an error message to ad paper and restart printing. I have tried adjusting the paper thickness lever. Any help would be appreciated
  • 1 more comment
  • Anonymous Jun 24, 2008
    The paper is being pulled into the machine only on the right side.  I tried putting an envelop in the right side and move the paper size bar over to the right  and this copied the envelop.  I know that there is a plastic lever below for either 8 1/2 x 11 or envelop and I have tried to move it back and forth without any change.  This all started when the copier reported that the black ink cart. was low.  I have replaced the black ink cart.  I have also unplugged the power cord and the computer cable.
  • Anonymous Jul 21, 2008
  • Anonymous Jan 29, 2009
    I have the same problem
I disconnected turned upside down and started shaking it and believe it or not the roller starting working it prints fine!
Posted on May 11, 2008
The upside down shaking (and beating on the bottom) worked perfectly!
Posted on Oct 31, 2008
I initially looked at this solution and thought there was no way turning the printer upside and shaking it would make any difference. However, I had a similar scenario, as that posted above, where I had just replaced the black ink cartridge and the printer feed started failing, so I gave it a shot. Amazingly, this seems to have fixed the printer feed problem.
Posted on Nov 04, 2008
I was slightly skeptical of the shaking/beating solution, but in this particular case carefully meted violence was, in fact, the answer to the problem of the paper feed. Just be sure to restrain yourself; the rollers respond to minimal shaking/beating, so this isn't an excuse to go Office Space on your printer : )
Posted on Jun 09, 2011
  • 23 Answers
Hey, By any chance did you unplug the printer at anytime when it was about to print that would cause the rollers to get off track to form the paper to go to one side and wrinkle i have had the same problom well still do with the same printer. your best bet that it is so cheap to buy a new one because its crap .,,,
signed
djkb
Posted on Feb 21, 2008
Epson Stylus CX4800 prints blank pages
Alex_Garton:
I'm not familiar with the Epson Stylus printers, but I'm going to hazard a guess. If the paper does not move at all, the paper pickup feed mechanism is at fault. One of two methods is used to pick up the sheet. Either the front lower portion of the tray is lifted up to force the top sheet into the feed roller, or the feed roller is connected to a drop-swivel to drop the feed roller onto the top sheet of paper. You'll need to look carefully at the feed mechanism to determine if a gear or clutch is failing. If the paper moves into the machine about 1/2 inch and then stops, either the first paper feed roller past the pickup roller may be at fault. Also check to see if the paper sensor between the paper pickup roller and the first feed roller is working properly.
Sep 22, 2012 | Epson Stylus CX4800 All-In-One InkJet...
I removed a jammed sheet of paper through the front opening, Had to pull real hard. Since then, when printing or copying, printer feeds up to 4 extra sheet with each printed page. I suspect some piece of...
Please see this solution from Canon. It is recommended you check your manual for the proper procedure for clearing paper jams. Incorrectly removing jams could damage your printer. Trust the following helps resolve your current issue.
If you do not have a manual it can be downloaded from here:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx300#BrochuresAndManuals
Issue: More than one sheet of paper feeds while printing
Solution: Clean the paper feed rollers using the MX300 operator panel
sikaku.gif Cleaning the Paper Feed Roller (Roller Cleaning) Clean the paper feed roller if paper is not fed properly. Cleaning the paper feed roller will wear the roller, so perform this only when necessary.
1. Make sure that the machine is turned on, and then remove any paper from the Rear Tray.
2. Clean the paper feed roller.
(1) Press the Menu button repeatedly until MAINTENANCE appears.
(2) Press the l_mark_s.jpg or r_mark_s.jpg button to select ROLLER CLEANING, then press the OK button.
The paper feed roller will rotate as it is cleaned.
3. Repeat step 2 twice.
4. Open the Paper Output Tray.
(1)Put your finger in the rounded indent beside the Paper Output Tray and open it gently.
(2) Open up and set the Output Tray Extension completely by pressing down the hollow on its front side.
5. Make sure that the paper feed roller stops rotating, then load three or more sheets of A4 or Letter-sized plain paper in portrait orientation in the Rear Tray.
Set the Paper Thickness Lever to the left.
6. Repeat step 2 three times.
The paper cleans the paper feed roller as it feeds through the machine.
If the problem is not resolved, wipe the paper feed roller (A) located on the right side inside the Rear Tray with a moistened cotton swab or the like. Rotate the roller (A) manually as you clean it. Do not touch the roller with your fingers; rotate it with the cotton swab.
Dec 25, 2010 | Canon MX300 Office All-In-One Printer
My D7460 will not feed paper The screen says load paper face down in main tray.
Usually this occurs when a printer has had fairly excessive use. This causes the rubber paper feed rollers to become shiny and then they are unable to grab the paper, or it grabs several sheets at the same time. Newer laser printers have now have grooved belt tracks to help prevent this problem.
The easiest way I have found is to BUFF the shiny tracks... Here´s how... Using a ladies nail file (sand paper type) Press the paper feed button to cause the rollers to slowly rotate and buff the rubber as it turns. Making sure no sand enters the rollers. If several sheets of paper feed at the same time. Pull them out and a trick to stop this happening is... to fan the paper before loading into the paper tray. The trapped air will allow the sheets to glide easier.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
John P Bradley
Tinteiros (Ebay)
Oct 28, 2009 | HP Photosmart D7460 Printer
My printer won't feed the paper through. the spindle rolls but won't grab the paper in the paper feeder
One common cause of paper feed issues is a build up of dust on the printer's rear paper feed roller. This roller consists of a plastic axle white roller. This is located in the automatic sheet feeder and is referred to as the "Pick Roller." As dust builds up on the rubber rollers, they become less tacky and therefore unable to grab a single sheet of paper.
To prevent and/or cure this type of paper feed problem, these rubber rollers should be cleaned.
Unplug the printer's power cord and remove the paper from the automatic sheet feeder. Please remove the paper access door from back of the printer and clean the white rollers inside with a cloth dampened with warm water (be sure there is no excess water on the cloth as it may drip into the machine). After these are free of any dust, close the paper access door. Reload the paper and plug the power cord back in. The paper should then feed normally.
Next, try this printer self-test by following the steps given below:
1. Turn the printer ON.
2. Press the down arrow button till the screen displays “Maintenance". .
3. Press the "Check" button.
4. Press the "Down arrow" button till the screen displays “Print Test Page.”
5. Press the "Check" button.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed.  If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed by itself. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Oct 02, 2009 | Lexmark X7550 InkJet Printer
Hi, i have a lexmark x4550. The pick up roller (the roller that grabs the paper and feeds it into the printer to get printed on), is not working, at least one of them isnt (there are two i think,,, but on...
Try the following: take an A4 sheet of paper and glue a 2 - inch strip of sanding paper onto the top of the sheet (full width of the page). sanding paper should be about 120 grain.
Now feed the page with the sand paper first (rough surface on top) into the paper inlet. grab and hold the paper, then press paper feed or send a print job. The printer tries to feed you special sheet, but you won't let go. This will sand off the gunk from you feed rollers and give a bit of rough surface to the rubber. Repeat if needed, it should cure the problem.
This works if the problem is the roller surface, it will not fix a problem with misalignment or a missing/broken spring in the feed roller mechanism.
regards, the perfessa
Aug 23, 2009 | Lexmark X4550 Multifunction Wireless Color...
Paper jam in Panasonic KX-
Your document feed is separate from your received and report prints so that's why your reports are printing ok and the document feeder jams. When you open up the doc feeder and look inside the machine you will see a roller and above it on the cover that opens you will see a rubber pad. Clean both the roller and pad (in fact anything in there that is rubber) with a rubber cleaner, alcohol, or even soap and water on a cloth without it been dripping wet. You will probablt find that they are very dirty. The roller feeds the document in so that needs to be clean and the pad helps to keep all the other docs from feeding in at the same time and that should be very clean so it produces good friction.
Jul 07, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
Lexmark X2350 won't pull paper to print.
One common cause of paper feed issues is a build up of dust on the printer's rear paper feed roller. This roller consists of a plastic axle with one rubber roller on each side. This is located in the automatic sheet feeder and is referred to as the "Pick Roller." As dust builds up on the rubber rollers, they become less tacky and therefore unable to grab a single sheet of paper.
To prevent and/or cure this type of paper feed problem, these rubber rollers should be cleaned. Unplug the printer's power cord and remove the paper from the automatic sheet feeder. Locate the pick roller and clean the rubber wheels on the left and right with a cloth dampened with warm water (be sure there is no excess water on the cloth as it may drip into the machine). After these are free of any dust or ink build up, reload the paper and plug the power cord back in. The paper should then feed normally.
1. Press the "Power" button to turn the printer power off.
2. Press and hold the "Copy" button.
3. Press the "Power" button one time and release it(keep holding the copy button).
4. Let go of the "Copy" button after the power LED flashes once.
5. The self-test will produce 1 page. The test is not continuous.
The self-test should print out a set of black and color bars.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
Apr 11, 2009 | Lexmark X2350 All-In-One InkJet Printer
Magicolor 2400w won't feed paper
CLICK HERE for the manual
See page 55 for cleaning the media roller.
Jan 26, 2009 | Minolta magicolor 2400W Laser Printer
Brother 2820 paper feeding problem
An easy fix would be to try to clean the paper feed rollers in the paper pick up area with a gentle cleaner like soap and water or simple green. Do not use alcohol as this will break down the rubber over time. If this doesn't work, you may have drive problem and will need to refer to a professional to resolve.
Mar 06, 2008 | Brother IntelliFax-2820 Laser Fax
Canon MX300 Office All-In-One Printer Logo
1,106 people viewed this question
old marine
old marine
