Question about Maytag MGR5751AD Gas Kitchen Range
Keypad locked out
My maytag gas range is non functional. the only button on the keypad to respond at all is the cancel button. I cannot access ANY other functions on my keypad.
  • 2 more comments
  • bobpease Feb 03, 2008
    after removing power for several minutes the unit returned to normal.
  • peaches2004 Feb 11, 2008
    We have the same problem, after receiving the F1 code. Ours is a Magic Chef cgr3740adw. The beeping has stopped and the f1 code is gone, but the keypad is still locked. It is however still keeping time! Do we need to replace the circuit board? We have checked the oven sensor and it seems to be reading in the proper range. What is the difference between the touch pad membrane and the ERC?
  • Anonymous Jun 14, 2008
    myoven will not function at all. The range part works. I have shut off the power but it will not work all that shows maytag oven is 5ab bath. pleASE ADVISE
  • Gary Davd
    Gary Davd May 11, 2010
    Sounds like the Key pad is shorted any codes??
    Sergeant:
    Champion:
  • 338 Answers
Consult your owners manuel for turning off the sabbath mode feature.
try to remember the whole f1 code. if it was f1-1 it could be a temperature problem
if it is f1-4 is could be a shorted keypad
the control pad could be locked out as well. try holding the cancel key for 3-5 sec to see if it unlocks the control
Posted on Nov 26, 2008
I have a Maytag super capacity oven and my broiler is staying on even after I push the off button
do you it beep when pressed if so keypad good next test best to have oven pulled out next time this happens while pulled out unplug I know the ignitor will stop glowing what I need to know does the gas valve shut off may take a few seconds if so then relay is stuck on control board
Feb 13, 2015 | Maytag Kitchen Ranges
Microwave does not work nothing on the control pad work the pad just says se
Hello
Check the power supply. Make sure the microwave is firmly plugged into a working electrical outlet and that your wall outlet is active if your home uses outlets controlled by a wall switch. Check your home's fuses or circuit breakers to ensure they have not been tripped. Without power the microwave will not respond to any input.
Make sure the parental lock is inactive. Some ovens, like the one shown in the image above, feature a keypad lock to prevent children playing with the controls. Most keypad locks can be cancelled by holding down a button or combination of buttons for a few seconds.
Make sure the door is firmly closed. Some microwave ovens will not allow any control panel input if the door is open.
Remove the microwave from the power, wait 10 seconds, then plug it back in. This will reset the microwave oven if there is a temporary problem with the software.
Press the "Stop/Cancel" button several times to cancel the current operation and return the microwave to standby mode. Re-enter your cooking instructions using the keypad as usual.
Oct 04, 2011 | Maytag Microwave Ovens
Have GE spectra range model JB960. The F0 button came on. Followed troubleshooting but no success. Do I replace keypad? If so, how? Where do I get one?
The "F0" fault code implies the Clear/OFF pad is shorted or a touch pad failure. If the code cannot be cancelled, unplug or disconnect the power supply from the range and then disconnect the keypad and then power it up. If "F0" ceases, replace the keypad/glass assembly; if "F0" is still present, replace the main oven control.
I added an image below with instructions how to access the control and glass panel. NOTE: Disconnect the range from the power supply before servicing.
Aug 11, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Why I get code F1-6
Hello, Thank You for using FixYa. I will be helping you today. F1-6 is a key pad error chances are you have to replace the keypad which is part of the erc(clock) The lower oven cancel button is f1-6 error code.
F1:-6 Keypad Cancel Lower Check keypad, replace if necessary
Thank You and please rate my answer if it was helpful..
Jun 24, 2011 | Maytag MER6772BAS Gemini Electric Kitchen...
How do I set the clock on a Maytag gas range, I
If your range is the same model as you posted this question under, the time is set by pressing the "CLOCK" button. The word "TIME" will begin to flash on the display. Using the keypad, press the corresponding numbers of the current time.
NOTE: If the oven has been programmed, or is in use, you cannot change the time. Cancel all other functions before attempting to set the clock.
If the model number is not correct, please post back with your correct information so that I may be able to provide you with better assistance.
Nov 01, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Oven electronic oven control will not adjust, up and down arrow pads not work - stuck at 350. Is not locked out.
That sounds like a keypad problem. Try this: See if the control responds to each button ... press the button, hear a beep, hit cancel. Check if UP/DOWN work in any of the clock setting modes. If a specific group of buttons always do not register, it is likely to be the keypad. Sometimes the keypad connection gets oxidized and causes somes keys to go dead. We put a procedure to clean this connection on our website, link below. You have to open up the oven to do this, so you may want to hire a tech for this.
http://fixyourboard.com/techzone.html
- see under "ovens" section
Oct 12, 2009 | Whirlpool Gold GW399LXU Gas Range
Maytag single electric built in with a display saying sab bath
It is in Sabbath mode, used for Jewish holidays. Anyway, hold the cancel button for 3-5 seconds and it should revert back to normal operating mode. It will still bake in Sabbath mode but will not display anything due to the laws regarding observation of the Sabbath
Jun 16, 2009 | Maytag MEW6527DDS Electric Single Oven
The lock is on, cant get it off
http://www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/service_info/150.pdf this will give you the service manual. press the function lock button the function lock will illuminate. when setting the lock during combustion only the on / off button responds. when ceasing operation the off button does not respond. the lock button should be pressed for approximately 2 seconds when cancelling.
May 31, 2009 | Rinnai Heating & Cooling
F1-6 Fault Code
This code is in responce to a fault/failure in the lower keypad assembly. It is possible the keypad was bumped.
Maytag Gemini fault codes.
Fault code Suspect area Fault code Suspect area
F0 - 0 None
F1 - 1 Runaway cook upper oven
F1 - 2 Runaway cook lower oven
F1 - 3 Runaway clean upper oven
F1 - 4 Runaway clean lower oven
F1 - 5 Keypad cancel upper
F1 - 6 Keypad cancel lower
F1 - 7 Keypad disconnected
F1 - 8 Keypad shorted
F1 - 9 Slave
Dec 29, 2007 | Maytag MER6769 Gemini Electric Kitchen...
Range lock issue
rollover, press and hold the stop time and cancel keypads together for 5 seconds. See if it comes back to life...Catriver..post back.
Apr 21, 2007 | Maytag PER5510 Performa Electric Kitchen...
Maytag MGR5751AD Gas Kitchen Range Logo
217 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
