Question about Samsung HCN653W 65" Rear Projection Television
Moving tv In order to get my tv downstairs where I need it to go I need to lay it on is back and slide it where I am removing a rail. Would putting the tv on its back for that short of time damage anything?
  • mike23mp Feb 04, 2008
    Thank you for the info on ho to take apart the two sections. This will help me out big time
    Master:
    Sergeant:
  • 440 Answers
Just be very caefully ive done it before in a truck but was super carfully just watch it close they say not too just like my 50 in plmasa but only way to get it home and out wa sto go on side no other option and it was just fine long as u take it super carefullly
Posted on Feb 10, 2008
  • 1,512 Answers
You should always ship and move a projection tv in an upright position. They only have chassis strength in this(upright) position. I would not advise sliding it on its back.
Posted on Feb 03, 2008
  • Graeme Ross
    Graeme Ross Feb 03, 2008
    Concerned about what you are trying to do. Just thought I would pass on a snip from the appendix of your user manual for your TV.
    http://downloadcenter.samsung.com/conten...
    Cleaning and Maintaining
    With proper care, your TV unit will give you
    guidelines to get the maximum performance
    Placement
    • Do not place the TV near extremely hot,
    • Do not place the TV near appliances with
    such as vacuum cleaners.
    • Keep the ventilation openings clear; do not
    cloth or paper.
    • Place the TV in a vertical position only.
    Did you read this thread. http://www.fixya.com/support/t138189-sam...
    I have personally moved more than 50 large projection sets and YOU SHOULD NEVER LAY THEM THEM DOWN!!
  • Graeme Ross
    Graeme Ross Feb 09, 2008
    hey mike... since my solution worked out for you, how bout a vote of FixYa for helping you out.
    regards
    Graeme
    Genius:
  • 1,067 Answers
No u will be ok only on plamasa tvs will this effect it sumtimes
Does anyone have assembly instructions for Pottery Barn Valencia Sleigh Bed?
Baby beds are tricky, assemble the 2 sides to the stationary rail first. then the springs, then do the sliding rail last then lay mattress on there. if ya ever move it Note: if you ever move it leave the sliding side be and fold the ends inward after removing the stationary side and springs. -pop
Dec 30, 2016 | Baby Gear
I cannot figure out how to install the left had rail for the Ice drawer on my Sub zero #632 refrigerator
you have to remove both screws in both rails, and pull the whole carriage and rail out as an assembly. then replace the rail, put the whole assembly back in, making sure to line up the hooks on the back of the rail with the screws way back in the back that aren't removed. then slide the ice bucket carriage back all the way in and put back in the 2 screws in each rail. good luck!
Dec 10, 2013 | Sub-Zero Refrigerators
Renault trafic stuck in second gear
There is one of 2 problems that will give this indication. The first is the gear lever end in the shift rail has moved out of the slot and is behind the slot and not moving it . This can be checked by removing the lever mount from the top of the box and physically moving the shift rail back into the neutral position then replacing the gear lever back into the selector gate and moving the rail again.. The second possible fault is that the selector fork has come loose on the rail and is not moving the gear (just sliding on the rail) If that is the case the box will have to come out unless you can see the selector fork and the lock screws from the top of the box when the lever mount is removed.. If you can move the selector rod forward and tightening up the lock screw then pulling it back to neutral. Repeat until the fork is back in neutral position and lock it up. Most lock screws have a hole and there is wire tied around the shaft to prevent the screw coming loose. If the box has been reconditioned at some time then it is possible that the person doing the job neglected the wire bit.
Nov 28, 2013 | 1993 Mazda 323
I have a Sony Wega KP-FX432M91 Prjection TV. I am moving house and I want to know if I can lay the TV flat on it's back to move as it's too tall to stand upright in our vehicle
Please do not lay tv on its back because of its internal design, things are mounted inside vertically and screws are holding them in place. Laying tv on back will put force on screws that might came off or get loose and you will end up with a distorted picture on tv screen.
Move tv in stand upright position, it is safe.
Hope this will help.
Thanks.
Mar 25, 2011 | Sony KP-FX532M91 TV
I have a 50'' RCA TV but the volume just stop working after been moved from upstairs do downstairs. what should i do. pls help
Look at the rear of the set by the antenna input for a small black slide switch. That is for internal or external speakers. I bet you bumped it to external. Slide it back to Internal.
Dec 04, 2010 | Televison & Video
Where is the water pump located on the Whirlpool top load washer mod LSR6332KQQO
There's only one pump in this machine and it is the drain pump which is located under the tub and directly coupled to the rear spline of the drive motor. It can be accessed by removing the console then the cabinet.
Start with the removal of the screws securing the console to the rear of the machine as shown. Pull forward and up on the console and lay it back on the hinges.
Disconnect the lid switch harness connector by pressing on the tab located in the middle and pulling it up.
The cabinet is attached to the rear of the washer by two brass-colored retaining clips. Insert a flat blade screwdriver into the turned-up edge of the clip, located on both sides, and then pry back to release the clip from the slot in the cabinet.
Open and hold the lid while grabbing the cabinet front opening then tilt the top of the cabinet toward you by pulling the cabinet away from the base. This releases the front and back slots of the cabinet from the tabs in the front and back of the base. Using the side of your leg and/or body as a support for the front of the cabinet, carefully lift up and set the cabinet aside.
With the cabinet removed, pry the clips securing the pump to the motor off and remove the pump.
Compress the spring clamps holding the pump inlet and outlet hoses then move it away from the pump when the pump needs to be replaced. Remove the hoses and install the new pump in reverse order of the removal steps.
Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the base of the machine then lay down the cabinet into position. Make sure the slots in the cabinet sit into the tabs at the base of machine.
Reconnect the lid switch harness then push the retaining clips back down into position to secure the cabinet to the rear of the machine. Reinstall and secure the console to complete the repair.
Aug 16, 2010 | Whirlpool LSR6332K Top Load Washer
After removing the fuel injectors and rail to remove the manifold, how do you reinstall the fuel injectors?
the same way you took it apart. put a little grease around the rubber seals so they will slide in easier. just tap on the fuel rail while lightly tapping it into place.
Mar 28, 2010 | 2002 Honda Passport
Trying to take my cd drive out and put in a new one but the old one will not slide out and I do not see any screw that need to be removed
If it is a normal PC, there should be 2 screws on either side of the drive that have to be removed before the drive can come out. Many times you have to remove both sides of the computer case to get to these.
This can vary however from manufacturer to manufacturer. Some put the drives on what are called rails where, if you release the rail it will simply slide out, other times only one side has screws.
If it is a mass manufactured PC (DELL, Gateway, HP, etc.) you should be able to find a manual on their site that would help.
Sep 21, 2008 | Acer Computers & Internet
Upper rack travel sticks and jams.....
you have a bad bearing retainer. you will need to call an asko parts dealer and order 8 upper rack ball bearings, and two ball bearing guides (they are grey plastic and break over time, causing the rack to jam. To replace tham, you must take the upper rack out by turning the plastic retainers on the front of both rails 90 degrees towards the outside of the machine. The slide the whole basket out. Now look at the back of the rails inside the dishwasher. there shoul be 2 more grey plastic retainers with bumpers on them in the rear. These must be pried out wiht a screwdriver (be careful, have cut myself several times on this job till i figured out the best way to do it. cover the bottom hole in the dishwasher with a rag, as you are likely to drop the old bearings when you slide the rails out. Slide out both the rails. Put your new (or old if youve got all 8) ball bearings into the ball bearing holders, then put the holders into the rail thats attached to the dishwasher. slide the rails back in, andthen put all your retainers back in and your rack. you may have to slide the rack in and out a few times before it will center the bearings and work smoothly. Should cost you about $12 in parts. Good Luck!
Apr 17, 2007 | Asko D1716 Built-in Dishwasher
VS 50605 screen replaced
first of all wally heres what to look for. remove speaker grill not sure of your model. speaker grill should pop off. then you will see screws holding the large plastic screen assembly. noww if you look there might be a group of wires going up to screen,they will be atatched to small plugs unplug them, remove small screws on bottom of screen assembly, entire plastic screen assembly will first slide up then pull away put assembly flat on floor (don't scratch screen put on carpit or sort surface ) screen side down. all around plastic screen you will see brackets with screws holding them on remove top,bottom,side bracket carefully put screen back in making sure the front side of screen is down replace brackets if plastic is not damaged should screen in place.reverse order of removal. remember alittle up then screen will slide down in groves doc
Aug 13, 2006 | Mitsubishi VS-50605 50" Rear Projection...
Samsung HCN653W 65" Rear Projection Television Logo
127 people viewed this question
Jerry Greenberg
Jerry Greenberg
