Question about Sony LocationFree Player Pak LF-PK1 broadcaster / TV tuner Television
Sony location free player LF-PK1 problem
Power LED blinks red. I can watch TV at home but can't enter unto BASESTATION SETUP-- comuter doesn't recognize device  LF doesn't show up in my wireless network list while on network
Slinteriors
  • 8617 Answers
SOURCE: TV turned off by itself and now blinks red led 6 times
6 blinks means a low B error. Which is no DD 6volt output on G1 board . This will cause no picture and no sound. To fix this yourself you would need the manual to get the correct sequence to test and proper part to order. You can get a service manual for 10.99 at the following link and they will ask if you'd like it emailed to you after purchase. Here is the link,
http://servicemanuals.vstore.ca/
Posted on Feb 01, 2008
ctf1800
  • 4402 Answers
SOURCE: Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Posted on Feb 26, 2008
mistersony
  • 320 Answers
SOURCE: Sony KDF- 42WE655 Blinks 5 times No picture or sound
5 flashes, bad lamp and/or lamp driver
4 flashes, bad or stuck fan
Posted on Oct 18, 2008
  • 239 Answers
SOURCE: Sony KDS-60A2000 projection TV: power led blinks 4 times
the projector bulb has gone out you need to replace it.
hope this helped
please rate well
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Posted on Mar 04, 2009
  • 178 Answers
SOURCE: KDS-R60XBR2 power led blinks 4 times,
There are three fans the one that usually fails is located on top of the optical block and cannot be reached by the owner unless you take the set apart yourself. What is happening is that one of the fans are not spinning fast enough or has stopped altogether. The best solution is to replace all three fans cleaning may not be enough to get a slow fan up to speed, and the tech should blow out the dust in the duct work. This is what the tech coming out will (or should) be doing. Also some fans will have an intermittent startup, and cause this intermittently, so it is a good idea just to replace the fans instead of just cleaning them.
Posted on Sep 02, 2009
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Televison & Video
Need the set up for a samsung tv
These are the setup codes for Samsung 0030, 0060, 0178, 0702, 0812
Manual located at http://www.oneforall.com/uploads/support/8210f6981b8d184d890a27645d6c32df.pdf
PROGRAMMING DEVICE CONTROL:
1. Turn on a desired device
2. On the remote control,press a device key once (i.e., VCR/PVR,
DVD,CBL/SAT,or TV).
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer's Codes (starting on page 36) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
5. Aimthe remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY.
6. Repeat steps 1 through 5 for each device you want to control.
May 04, 2011 | One For All URC4220 Remote Control
I need help to get a code for my sanyo tv and how to set it up.
Hi
Configuring codes:
1.Turn on a desired device (VCR or DVD player)
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCR once. After programming a VCR Combo device, you will be able to control channel selection,volume, and VCR functions.
To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once. After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
then release SET.
4. Use the Manufacturer’s Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn’t work, try Searching For Your Code on next page
Auto Code Scan:
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly press POWER button.Stop when the TV turns off
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 to 5, but substitute the appropriate device key for the device you are searching for.
Code for sanyo tv is 0154
Thank You
Sep 13, 2010 | One For All URC-3021 Remote Control
I need to program the one for all URC-3021B00 to my sony tv
Configuring codes:
CBL/SAT or TV).
then release SET.
Auto Code Scan:
blink twice.
Code for sony tv are 0000, 1100, 0810
Thank You
Im trying to program a remote the tv is a zenith
Configuring codes:
CBL/SAT or TV).
then release SET.
Auto Code Scan:
blink twice.
Thanx
Aug 06, 2010 | One For All URC4110 Remote Control
Hello. I have a model # URC-4640Boo and am trying to set it up to work an a Sony dvd-vcr combo model # SLV-D300P and can't seem to find out how. Can you help me?
Configuring codes:
CBL/SAT or TV).
then release SET.
Auto Code Scan:
blink twice.
Thanx
Jul 17, 2010 | One For All URC-4605 Remote Control
I need the codes and procedure to program a one for all urc3220 to my Zeinth tv.
016,017,092,000,[COMBO--000,037] are the codes
for your Zenith TV. Follow these instructions
carefully. These are as close as i can get you
to getting you operations...the rest is up to
you. GOOD LUCK!
  1. PRESS the button for the device you want to program,(TV,VCR,CABLE,etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER the 3 digit code for your brand.
  4. You should receive 2 quick flashes after entering your code.
  5. PRESS the POWER button to test the code.
If you have tried all of the set-up codes for your brand of equipment, or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
  1. PRESS the button for device you want to program,(TV,VCR,CABLE,etc.), then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE(TV,VCR,CABLE,etc.) button until your device turns off.(On VCR,LD,and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
Blinking Back the Code:
  1. PRESS the device,(TV,VCR,CABLE,etc.), button - RELEASE
  3. PRESS 9 - 9 - 0.
  4. PRESS 1, carefully COUNT the number of blinks. (1st digit)
  5. PRESS 2, carefully COUNT the number of blinks. (2nd digit)
  6. PRESS 3, carefully COUNT the number of blinks. (3rd digit)
If the remote DOES NOT blink it means the number is 0.
This is your 3-digit setup code.
Sep 04, 2009 | Televison & Video
I need codes for urc 3220 on a ge tv
GE
002 006 007 018 107 114 310 312 502 601 704 719 803 806 810 901 911
you. GOOD LUCK!
  3. PRESS 9 - 9 - 0.
Jun 24, 2009 | GE 27GT271 TV
How to watch a DVD
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Jul 19, 2008 | RCA Universal Remote Control
Programming the jensen jr400 universal remote
1) Turn on the Proton TV;
2) Press the "TV" button on the JR400;
3) After releasing the button, the red LED indicator should blink twice;
4) Press and hold the SETUP button until the LED blinks twice;
5) Release;
6) Enter 9-9-1 on the numeric pad. Red LED blinks twice;
7) Press POWER;
8) If TV doesn't turn off, press TV again;
9) Repeat #4, #5, #6, and #7. If TV doesn't turn off, go back to #4, until the TV responds.
10) Go on to the next device, i.e. DVD, VCR, etc.
Feb 17, 2008 | Jensen JR400 Remote Control
Sony LocationFree Player Pak LF-PK1 broadcaster / TV tuner Television Logo
124 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
