Kenwood KR-4010 (late 70's vintage) with signal to IF amp but no output
When I obtained the unit, the ouput protection relays chattered for the first couple of seconds after power up and then the output cut-out completely. Now there is no output at power on. With a scope I see the RF signal at the input to IC1 for both channels and see the signal at the left channel output of IC1( pin 6) but the right channel output of IC1 (pin 10) is sitting at -34 Vdc. I am looking for ideas on best actions to take to determine the problem and work to recovery. Thanks for any help offered.
Rich dzfam@att.net
  • 2 more comments
  • Rich172 Feb 03, 2008
    Thanks to Coldcut for a very prompt reply and for the direction from his experience with my specific problem. I have inserted an image of the schematic with this comment along and have a couple more questions. Coldcut recommended replacing the outputs - are they the IC2 and IC3 (the STK-0040AT) amplifiers? And he recommended wiring across the relays - by just jumping across the contacts or should I do more? Thanks again.
  • Rich172 Feb 04, 2008
    I do know how to check out the transistors for shorted condition and yes the STK's are the external transistors right before the switch and then to the speakers. You have have confirmed the recommendation without the schematic so unless I run into further problems, I won't upload on imageshack at this time. I will check out the transitors and replace as necessary. Thanks again.
    Thanks for the detailed tip on the DC offset. I'll check that out and do the replacements. Thanks for sharing your high level of expertise.
  • Rich172 Feb 05, 2008
    I see now the check won't be that direct as the STK-0040AT output transistors each are a pair of darlingtons, an NPN and a PNP. I do have an analog meter and I'll only be able to tell if I have shorted through pairs of junctions.
    By the way, I received an e-mail indicating a tech buddy request came from you. I did not respond to the tech buddy request because I do not know what it entails or requires and I could not find any info about it. Can you tell me where I can find out more? Thanks for your help.
  • 1,512 Answers
Don't bypass the relay contacts. They serve to disconnect the amp stages from the speaker if a DC condition is present, and in doing that, save your speakers form damage. Check for a DC offset condition on the junction of the emmitter stabilizer resistors to the STK0040 on each channel. They will be 0.47 ohm power resistors(2 per STK) connected to pins 3 and 8 of the STK. Anything substantially greater that 100mv here generally indicates a blown STK. Don't bother to change both, but just the one that is faulty. Another common problem for this age of amp. The high silver content in the legs of the transistors allows for "growth" between legs and internal connections of the transistor. Check for "black death" on the legs of transistors driving the STK. . . I tend to replace them if in doubt. If you need expert advice, comment me back. I am an audio specialist.
Posted on Feb 03, 2008
  • Graeme Ross
    Graeme Ross Feb 05, 2008
    Its very hard to check darlingtons with just a junction barrier potential check(using a resistance meter or diode checker) because not all the junctions are available at the external pins. If in doubt, just replace the STK module. They are not the expensive, and readily available, and a common cause of failure in amps that use them. Discrete components still has the edge over thick film hybrids for reliability, Just cheaper to make a chip that use individual parts.
Pleace schematic kenwood kr4010
chile
eventos_amper@hotmail.com
Posted on Jun 18, 2008
    Genius:
  • 1,554 Answers
In those days I found that it was best to bypass the relays as they caused a lot of output transistors and speakers to blow.
it was some stupid hot idea back then.
I am still running 2 marantz amps since 78 today that are wired across the relays.
the normal issue with these amps is usually always that the outputs transistors or output amps if IC are blown because of this . replace outputs and try again.
use headphones while troubleshooting.
If you want me to I will look at the schematic if you have one. I sold all of mine and threw a bunch away 10 years ago.
if you know of one online send me a link
  • 1 more comment
  • Karl Whisenand
    Karl Whisenand Feb 03, 2008
    Jumping across the contact but from under the relay is the way.
    as for the schematic its too small .
    stick a larger one on imageshack.
    I can only guess as to the external transistors after the IC.
    but if those transistors are connected through the switch to the coupling capacitor and speakers they are the usual culprits.
    do you know how to measure resistance in a transistor to test if shorted.?
  • Karl Whisenand
    Karl Whisenand Feb 04, 2008
    set your meter Rx1 , Just remove them and check for 20 ohm
    in one directions and open when you reverse the conection base to
    emitter, collector to base ,
    and should show open colllector to emitter
    if you see any leakage between these readings replace the xistor.
    an old analog meter is best when testing xistors.
    As for jumping the relay ,your choise, I always do and haven't lost any
    speakers or any more blown transistors since I have fixed over a
    hundred of these 30 years ago. a lot of the units are still in service
    including my own. when you power on the unit you have at least 5 sec to
    turn it off/down before it blows as you will hear the issue. with the
    relays working you can blow the speakers as they engage if the vol is
    way up . or blow out your windows as I did. I cracked 4 double paned
    windows in my old house. Lol . hurt more than my pocket book on
    that one.
    I had verrry large speakers.
  • Karl Whisenand
    Karl Whisenand Feb 05, 2008
    Tech buddy allows a private chat with a long wait it seems. but that way you can exchange emails or messenger id.
    I don't even remember doing it at all.
How to troubleshoot a kenwood kr 5600
These older tuner/amps have protection relays that when latching, are distinctly audible. Does the relay engage after approx. 10 seconds after turn-on? If not, check your speaker wires and/or speakers for issues. With all speakers (and wires) disconnected, the relay should still latch after turn-on. If not then you have an internal problem...likely a older pre-drive transistor that's bias is incorrect, which in turn causes bigger problems downstream.
Jun 01, 2014 | Kenwood Audio Players & Recorders
How can i repair amp
Looks like the amplifier output transistors have blown (hence the pop). Quite expensive too repair - I would have a look on eBay for a cheap used but working Kenwood receiver, it would probably work out cheaper.
May 10, 2014 | Kenwood Audio-video Stereo Receiver Kr...
When i turn on my kenwood kr-v990d it powers up for about 2min then shuts down
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be with your output drivers. Please check for short on the outputs fitted for both the channels. Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise which can be a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board. Maybe the protect circuit by itself is shutting off due to a faulty bias or there is a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the amplifier comes out of the protect mode then check for short on the speakers.
Oct 23, 2011 | Kenwood KR-V990D Receiver
Kenwood kr-v888d after "ON", through 3sec.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
May 18, 2011 | Kenwood KR-V5580
Kenwood eXcelon radio problem I have 2 subs in my civic that work perfectly fine but i recently tried to add another amp to run my front door speakers seperately. I spliced the remote wire between the two...
Cut the remote wire from the radio.
install a relay in line
the relay will have 4 or 5 terminals
connect terminal 87 to battery power and fuse it at 3amps
connect terminal 86 to the remote output from the head unit
connect terminal 85 to ground
connect terminal 30 to your amp turn on wires
this allows the turn on load to run thru the relay and not directly off the radio remote output
Nov 25, 2017 | Kenwood Kdc-x494 Car CD/ MP3 Player
My kenwood amplifier suddenly off when i turn the volume high?
You need to make sure you ohms are correct if there too low this will happen to protect the amp.
Dec 03, 2008 | Kenwood KR-V7080 Receiver
Kenwood Receiver KR-a5020 receiver won't come out of standby
The unit is in what is commonly known as "protect" mode. This means that a problem has been detected in the final output stage of the amp and the outputs are shutdown to prevent further damage to either the receiver or speakers. This should not be a difficult repair for a service shop. Expect a parts cost in the $25-$40 range. Add in the local labor rate for the total repair cost.
Dan
Nov 28, 2008 | Audio Players & Recorders
Vintage Stereo Connection ???
Hi spanky
Where to start :) I am excited thinking about them :p You got 2 totally cool pieces of classic vintage gear there in the C2 and the Marantz. I have a C2 preamp myself (gathering dust but wont sell it cos its excellent) and the marantz would be totally cool to have(but then I am a little biased towards 70's vintage marantz). They ruled the roost in HiFi amps throughout that decade.
Because they are both integrated amps, you could use them as standalone systems with a pair of speakers, and just plug your favourite gear into them. If you just wanted to run up a nice sounding HiFi, I would sell the kenwood gear and just keep the Marantz. The Kenwood kr1100 has the edge in power, so if it is grunt you are looking for use that. Because vintage sound is all about stereo, you only really need an integrated amp to get great results.
the specs are
# Kenwood Model Eleven G (KR-11000G) Receiver
120W per channel min RMS, both channels driven, at 8 ohms from 20 to 20.000 Hz with no more than 0.03% total harmonic distortion.
Dynamic power output 440W at 4 ohms
Power bandwidth 5 Hz to 70.000 HZ
Frequency response 5 Hz to 100.000 HZ -1.5dB
Signal to noise ratio 115dB
The marantz is a little lower in power at 75rms a channel, but will have the sonic edge in vintage sound over the kr1100. Look them up on ebay and you will find that they do have some value to collectors and people seeking nice tone. There is an 1152 for sale here for AU$900
Best bet is to fire up the 2 integrated amps,and see how they are going. Run them for several hours to be sure there is no strange noises and crackles. Then decide if you want power or finesse.
You could also run both amps from the C2 preamp by connecting to the Amp in connections to the rear of the integrated amps.
happy to talk to you more about it, hit me with a Fixya if my advice was helpful to you. I would keep the marantz, use that and sell the rest and buy some nice speakers:)
regards
robotek
Jul 20, 2008 | Audio Players & Recorders
Item does not work
This unit is most likely in protect mode. This occurs when the receiveer detects a problem with the output amplifier section and that section is disabled. The most common failure parts are the output transistors. Expect a parts cost between $15-$40, Add in the local labor rate for the total repair cost.
Dan
May 28, 2008 | Kenwood Audio Players & Recorders
System protect
I would suspect the protection circuit is bad (bad cap). It worked before??
Find what is driving the speaker protection relay. Replace the small electrolytic caps in that section. Small caps are used so that when the power is removed the relay releases quickly. Or DC is present on one or more of the amps before the relay.
Nov 02, 2007 | Audio Players & Recorders
1,729 people viewed this question
 Grubhead
Grubhead
