Question about Ruud Handler Air Conditioner
I have an ac unit that the heat strips come on with the ac.
I have an central unit the the heat stripps are coming on with the ac.
  • Gary Davd
    Gary Davd May 11, 2010
    see other POST
    Problem Solver:
  • 8 Answers
(1)Chek defective control switch
(1)Check if wiring is cross at some point
Posted on Mar 30, 2008
Fan doesn't work in heat mode it works on all other functions. Heat does come out but fan doesn't kick in. Outside unit is operating
AC inside fan doesn't come on AUTO - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 21, 2004 - The inside FAN doesn't run when in AUTO mode. If I leave ... Is the thermostat not working correctly or something in the AC unit causing it to do this? Thanx ... The unit is electric central air-conditioning(heat and cool). It made ... Carrier A/C condenser fan not working
Jul 27, 2012
Heater Fan Doesn't Work on AUTO
Jan 23, 2006
Blower doesn't work in ON position after repair
Mar 25, 2005
Central AC/Heat, Blower Doesn't work on Auto
Nov 30, 2004
More results from www.doityourself.com
Nov 01, 2015 | Heating & Cooling
New heat strip does not come on with themo in heat position.
you cant use that thermostat for a heat strip,your thermostat only gives 9 volts to tell the heat pump to come on,a heat strip needs 220 volts to run,DO NOT PLAY WITH ELECTRIC HEATERS!!you do not know what you are doing and can burn your house down or hurt someone!!
May 22, 2015 | Heating & Cooling
New heat stripp will not heat up
sequencer not working to provide power to strip.
Jan 05, 2014 | Goodman CLQ36AR49 Air Conditioner
Goodman package unit heat strips will not turn on
Put meter probes at in put terminal of the element if you read 220volts that mean your relay is good. if you got it there use amp meter on one leg of that element. You should read some amp draw there but if there is no amp draw it mean the element broke.
Nov 29, 2013 | Goodman Manufacturing Goodman GPH1530M41...
My corona air conditioner inverter does not produce hot air
these are all in one units, some of them are made like smaller central units and some of these are separate ac and heat units. the heat in the separate ones is run off of a heat strip in the unit it's self the ones that are made like a central unit reverse the flow of the freon in the system to draw the heat from outside. this is not something you can repair very easily yourself. most places require because of the freon that you have a certified HVAC technician to work on them.
Feb 22, 2013 | Heating & Cooling
My heat unit will not blow hot air unless we go outside and hit a button on the back bottom of the unit. Once we do that it will blow hot air for that cycle. when it is time for it to come on it is cold...
If it does not have a furnace or heating elements for heating, then it is a heat pump, which is rare for a central AC system, but makes sense of the fact that it blows warm air when you reset the pressure switch, which may indicates freon pressure charge problem if your AC system has a reverse valve and uses freon to for heating (heat Pump).
Do you get heating when outside unit runs? if you do, check freon pressure levels and top up to required pressures. The button you depress is a pressure reset switch ... that is if your AC system is a heat pump ... which, as pointed above, it is not common for central ACs.
Nov 07, 2009 | Ruud Central System Air Conditioner
When we turn on the central air there is a strong burning smell...like burnt toast but way stronger. IS it safe to remian in the house?
Is your central air furnace or electric heat. Electric furnace sometimes have electric strip sequencer stick in the closed positions leaving on one strip of the electric heat. Get a service tech as soon as possible to check this out. Any smells from a central unit need to be teken care of promptly. TURN OFF unit you have it checked for your safety. Rus
Jun 28, 2009 | Coleman Heating & Cooling
When I turn the air on the heat strips comes on at the same time
Is this a central heat? From the size i assume it is.
You say air conditioning on part of your question then use heat pump on another part. So it is important for us both be on the same page.
With all due respect some people think they have a heat pump and it is just AC and electric heat also but is not a heat pump.
. If you have the outdoor AC unit running with your thermostat set for heat and the air coming off the out door unit is cold, or you see it "steam up outdoors" off the out door unit at times (we call this mode defrost).
If you actually have a Heat pump system some times it is wired to have the strips come on at the same time the heat pump comes on especially if you experience a lot of weather below 40' occasionally and have an emergency heat setting on your thermostat you most likely have a heat pump.
If you have a heat pump for sure now the heaters can come on with the outdoor section if
1 they are wired to do so or
2 the thermostat has 2 stage heating and the second stage is telling the elements to come on, or
3 the outdoor thermostat (if so equipped) is telling the elements to come on.
Any 1 or combination of these 3 items can cause the elements to come on wit the out door unit.
Mar 12, 2009 | Coleman Heating & Cooling
Furnace runs on heat, air conditioner does not
If you have a Gas furnace in the Attic then the answer is yes. The outside condenser will not run if in fact you have a gas furnace.
Feb 11, 2009 | Ruud Central System Air Conditioner
RUUD HVAC UNIT - HEAT STRIPS COME ON WITH THE A/C
What you are talking about I think are the strip heaters in the Air Handler this must be a Heat Pump system right??? If so please check your thermostat and make sure it is not in EMRGY HEAT mode.. One other note there is a 2 stage bulb system inside the stat if it is too cold outside and the heatpump on its own cant keep up with the call for heat the 2nd bulb closes and turns on the heater as a supplumnetal heat also these will come on or should come on when the unit goes into defrost.. plz let me know what it is you are trying to test and i can walk you thru it.. Also need a model # off the A/H to get a Wiring diagram
Feb 03, 2008 | Ruud Handler Air Conditioner
Heating & Cooling Logo
193 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
