Question about Magellan RoadMate 700 GPS Receiver
Magellan roadmate 700
I got an error on power up on a sub-zero night a couple of days ago. Something about unit being to cold.
Since this error happened it powers up from default location I assume is San Fransisco Calif. and takes much longer to show current location of Chicago.
Sound is missing, no clicks or voice. Strange thing is sound/voice is coming from units built in tutorials.
It has also lost all previously entered locations and will not save any that I input now.
I have opened up the unit and found a battery soldered on a pcb that only measures 0.7 volts.
I have the thought that this battery has something to do with all my problems.Does anyone know what this battery should measure in volts.
Roadmate 700 v4.32
Thanks in advance for any help
The battery looks like a Lithium battery and it should be 3 volts or close.
I to loaded new maps and am not autherised to use them. What a joke! Looks like a case of to much security to protect Magellian's already to high of a profit!
Posted on Feb 22, 2008
How do i reset to factory settings?
www.magellangps.com/assets/.../magellan_roadmate_series_en.pdf
http://support.magellangps.com/support/
manual and help site
May 21, 2010 | Magellan RoadMate 700 GPS Receiver
All navigation units are GPS Receivers - that is - they receive satellite signals. So, no there is no difference.
Apr 19, 2008 | Magellan RoadMate 700 GPS Receiver
Magellan roadmate 700 "powerup problem"
I had a Roadmate 700 with the same problem as yours, and the solution was simple: the hard drive inside had come loose!
All I did was open up the unit (4 screws on the back and a small snap-together clip on the end), and plugged the hard drive back into the cable. The cable has 2 black posts that fit into the hard drive, so you can't misalign the pins. On mine, the hard drive label was facing UP.
Once the hard drive was plugged in, I powered up, and could hear the hard drive spin up (which I hadn't heard before). The unit booted from the "Magellan" screen right into the menu almost immediately!
Hope this helps someone!!
Apr 01, 2008 | Magellan RoadMate 700 GPS Receiver
Power wont come on
get a new unit like any magellan mastreo series 4000 or higher or roadmate 800 or higher,i had a 700 they start having alot of problems after i did my research on here.i have the mastreo 4000 and the roadmate 800 both work great.
Feb 23, 2008 | Magellan RoadMate 700 GPS Receiver
Magellan roadmate 700....can't find satellites
I understand how you feel dude but I believe that there is a newer version than you r model, right?
I suggest that you go to this website and search this support..
www.driveragent.com
hope, this will helps!!
Jan 23, 2008 | Magellan RoadMate 700 GPS Receiver
Road mate 700
The flash card hole is supposed to be empty - all you need should be on the hard disk BUT the first Roadmate 700 I purchased was empty i.e. no software loaded. The second failed due to bad power connection, the third worked but was factory refurbished! what a crass organisation Magellan is!!!
Try fiddling with the power connection that goes into the cradle that the unit sits on. The power connection is ultra sensitive. BUT, if you've only just bought the unit then you are in luck - return it and get your money - back Magellan Support is extremely poor.
I am binning my Roadmate and getting a Tomtom720 Go series with maps and cameras preloaded - it auto updates when it is on its cradle attached to my PC/internet.
Bin the Magella - 4 years of problems!!!!
Oct 24, 2007 | Magellan RoadMate 700 GPS Receiver
Keeps seeking but no GPS positioning
get a new unit like any magellan mastreo series or roadmate 800 ,i had a 700 they start having alot of problems after i did my research on here.
Sep 06, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 700
Yes, get a new car connector. -Daniel
Apr 23, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 700 freezes up
Try resetting user data. At user menu, press "-" zoom out and repeat button at same time. select reset user data, it will reboot automatically, then check to see if it is any better. If not, hopefully the software came with your unit and you can re-install it. Good luck and let me know if you need help with the installation. Daniel
Mar 03, 2007 | Magellan RoadMate 700 GPS Receiver
RoadMate 700 GPS is not working..
Does the initial Magellan screen appear? If it doesn't display anything and it's just blue... :( Normally means that something on the main board is your problem. Which, means your out of luck. What happened to it? It just suddenly stopped working? Let me know. R/
Sep 17, 2006 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 700 GPS Receiver Logo
100 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
