Question about Toshiba Satellite P35-S611 Notebook
3 quick beeps when powering up
I recently took apart and cleaned the heat sink on my Toshiba Satellite. This was the second time I did this, and it went well the first time. this time when powering back up, all I got was three quick beeps and then nothing. I have taken the notebook back alll the way down to the main board to make sure I didnt miss anything but the problem continues. From my old DOS days, I suppect that this is an indication of a bad memory module, but since I was careful about taking it out and putting it back in I am not sure this is the problem. Before I plunk down 75-100 bucks for a new module I am looking for if anyone else has had this problem and should I look elsewhere
    President:
  • 2,351 Answers
3 short beeps point to memory. Base 64K RAM failure. Clean the copper leads on the memory with a lint free clean cloth & lightly dampend with Alcohol. With the help of a strong flashlight & even a magnifer look into the dimm slots & check the connectors within are not bent. Clean with a cotton swap & Alcohol (not dripping). Blow out with canned air to dry.
Re-seat again. If all fails, download this free memory tester here: http://www.memtest.org/
Scroll down till you see, ** Memtest86+ V1.70 (01/14/2007) ** all typed in red. Pick your preferance. Either a .zip or an ISO. One will creat a bootable CD & one will creat a bootable floppy. This program will test your memory. Please post back if you need more help. Luck!
please vote..
Posted on Feb 03, 2008
Thanks!! that did it!! turns out some lint had gotten in the dimm slots
6ya staff
SOURCE:
Laptop freezes beeps
Is it up on a table on in your lap?
There are vents on the sides and bottom that need to be kept clear so the unit can cool itself, you can visually inspect those to make sure no dust/dirt are clogging them up and use compressed air to clean.
If you are snuggling in bed with it or have papers close to side of vents, or using in lap covering those holes, you should feel the heat, heat destroys laptops and if you continue to use it in that manner, if that is the issue, you will have a failed unit shortly.
It is most likely beeping and shutting down from excessive heat.
Oct 29, 2013 | Toshiba Computers & Internet
Toshiba Satellite M30 Problem
Power adapters fail because of power spikes. You can do a preliminary test of your system's adapter by plugging it into your notebook and checking to see if the computer indicates that its battery is charging. Usually there's an LED (light-emitting diode) that flashes when the battery is charging. If you can't test the power supply using this method, take your notebook computer to a technician who can test the adapter.
Feb 16, 2008 | Toshiba Satellite M30 Notebook
I have a IBM Server X225 model 8647 4dx. I recently took it apart to clean it and I made sure that I put everything back together the way it was before. However, when I turn it on now, it comes on for...
Did you disassemble the heat-sink and processor? If you did, did you replace the thermal paste before putting back the heat-sink? did you make sure that the heat-sink touches and locks properly with the processor?
These are the things you need to check if it shuts down within 2 sec without any beep codes. This is a system built-in protection for the processor to avoid being burnt from overheat.
You might also want to check for any non-functioning fans and anything that can relate to "heat problems".
Hope this helps.
Apr 18, 2011 | IBM X225 (86463bx) Server
Problem for Toshiba Satellite® X205-S9349 PC Notebook: i get power to the laptop, harddrive flashes a few times, then nothing. No beep sequence. took out ram strips, cleaned them, and reset them...
I have just recently experienced this same issue. My fix was easy. I removed the video card. removed the heat sync. Using a heat gun about 2" away from the backside of the video chip (bga) for about 30 seconds. Then immediately with a doubled up piece of cardboard, press down on the chip for 30 seconds. Let cool, then reassemble. I did this a month ago and still going.
Feb 01, 2010 | Toshiba Satellite X205-S9349 Notebook
Suddenly shutting off power sometime beeping
there was a problem with notebook overheating and it would be fixed by cleaning the cooling component ,check the heat sink and the fan. The notebook processor produces a lot of heat when the notebook is turned on you check
If the fan working fine, then check if the heatsink is clogged. In some cases you can clean the heat sink with compressed air,
Thanks,
Dec 23, 2009 | Toshiba Satellite M35X-S349 Notebook
Nothing on powerup.
Open it up again and find the wire you blew off.
Oct 25, 2009 | Toshiba Satellite X205-SLI1 Notebook
Toshiba wont turn on, has beeping after i press power
i had a similar problem with my satellite notebook. the problem was that it was overheating. what i did was pull the processor and heat sink out, it was covered in dust and not allowing air to go through the heatsink. i just cleaned it up and it stopped overheating.
Apr 28, 2009 | Toshiba Satellite X205-SLI1 Notebook
One long beep on startup, then switches off
i can if you didn't hook something back up... be that as it may... remove the memory... then plug the memory back in... power it up and see how it goes.
Feb 24, 2009 | Toshiba Satellite A60 Notebook
Toshiba Satellite P35-S611 Notebook Logo
120 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
