Question about Refrigerators
Frig how to change lights
  • 2 more comments
  • Anonymous Jun 16, 2008
    I can not get the old folesent bulb out. I am affraid I am going to break it.
  • jasent Sep 28, 2008
    I changed the 4 light bulbs but the light is not on! ???
  • Anonymous Oct 21, 2008
    I have put in two new light bulbs, but the light still doesn't work.
  • Gary Davd
    Gary Davd May 11, 2010
    Need a model#
  • 958 Answers
Just like replacing a house light bulb. if it has a plastic cover, remove first the plastic cover and unscrew the old bulb and replaced it with a new one. unplugged it first before doing the bulb replacement. for safety...
Posted on Feb 05, 2008
Kenmore Coldspot 106 Refrigerator
It's 12 years old it's gone ,they don't last forever ! Compressor !
Aug 18, 2015 | Refrigerators
Domestic Dm2652 will not work on AC without DC power is this correct. We have been camping for a week plugged into 30amp power. Refrigerator worked fine then check light came on and refrigerator...
This is an RV frig correct? It SHOULD work either/or. AC or DC. If your plugged into AC then often the frig will work with that alone. DC is for when you have no AC so you can power your appliances of the battery. Maybe you have a converter (AC to DC which most RV's do) that somehow is not getting the DC to the frig.
Oct 11, 2013 | Dometic RM2652 Refrigerator
Kenmore 795 continually blowing cold air into frig
If the control will not change and the lock is lit, first try unlocking it. Press and hold the lock tab for 3 seconds. If nothing happens, try unplugging the power cord for 30 seconds and reconnect it. This will reset the board.
Nov 02, 2012 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Frig LED settings and bulb do not work
u might have unpluged something
Feb 13, 2010 | Refrigerators
Lights out..White box is clicking in back base of frig
sounds like the relay box on compressor . . you can repl the relay . it's not a hard job .. and its lso a very common problem on many frig's . ****
Jan 04, 2010 | Refrigerators
Bulbs burning and causing frig to get hot.
I need the model number you may have a short and lights are reaming on while door is closed. This sounds like a recall or fire hazard Unplug let the area cool remove the bulbs or risk property damage until confirmed what model you have Sea Breeze
Dec 13, 2009 | GE Refrigerators
Frig stopped cooling. Bad condensor Fan Motor.
sounds like a bad thermostat,that tells unit when to kick on and off.
May 15, 2009 | Maytag Refrigerator Light Switch -...
Changed bulb in frig and light still not on. Frig is older whirlpool. est age is 15 years. i thought bulb was just burnt out. everything else still working. replaced old bulb 15 w with an "appliance" bulb...
I would stick with an appliance bulb. The glass in those is more resistant to extreme temperature changes.
Your problem sounds like it could be that the door switch has burned/corroded contacts.
If you have a continuity meter you can remove the switch and test it to see if it's working.
BUT, FIRST, TURN OFF THE BREAKER TO THE FRIDGE!!!!
If you don't get continuity thru it, soak it in rubbing alcohol for about an hour. Let it dry for about an hour, and test it. If it's still not working, replace it.
If you need help with the continuity testing, let me know.
Apr 30, 2009 | Whirlpool ET8MHK Top Freezer Refrigerator
Went to put groceries in frig and found it not on
yoor lights should be on at the very least, i would check the outlet , plug in a hair dryer or something, no internal lights means you have no incoming power supply
Dec 17, 2008 | Maytag MCD2257HES Side by Side...
Refrigerators Logo
179 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
