PANASONIC FA-A505 ERROR MESSAGE U14, DON'T HAVE MANUAL BELONGS TO MY CHURCH, HELP!
  • ramofe Feb 04, 2008
    thanx so much that did it, washing the bottle cleared it, I thought it was a false error cause it was empty, but it wasn't clean
  • Kressie Mar 28, 2008
    I've cleaned it but it still will not read that the box is empty . What else can i do?
  • 168 Answers
FA-A505 is the Automatic Doc Feeder number and not the copier model number. Without knowning the machine model number, This is just a general code for 95% of the Panasonic Copiers that use this code. If the U14 is flashing on machine, then check your waste container bottle for the toner. (Not the toner bottle, there should be a waste container that needed to be changed or at leasted emptied and then washed out with COLD water) Be warned.. washing the bottle out will make a mess out of your sink, so it is suggested to do in in a basement tub/sink.
If you do not have another waste container, then empty as much of the used toner in a plastic bag, and then rinse the bottle out. The bottle does not have to be completely dry when you re install it. Just shake as much of the water out as possible. If the U14 goes away, you are good to go. If the U14 is still showing, open the door and remove the bottle and see if you can close the door WITHOUT the bottle. If the U14 goes away, then the bottle is not clean enough. DO NOT RUN THE MACHINE WITHOUT THE BOTTLE, or you will have a mess in your machine. (some models will let you close the door without the bottle, and some wont).
Your best bet, is to replace it with a replacement container if your church has one and order some spares to keep on hand.
Hope this helps.
Good luck
Posted on Feb 03, 2008
PANASONIC-na-f70B2 drains as it fills to begin wash cycle. Error code U14
You water drain line needs to be curved above top of tank Water finds its on level The water level is stuck on the full position shake the washer lightly with water inside to release it. It works almost as a toilet tank.
Feb 15, 2015 | Washing Machines
I have a panasonic 52"
The tv projection lamp timer must be reset,read ur ower manual how to do that or call panasonic customers service for the help with the prosedure,sorry i don't remember how to do it anymore.The problems with the HDMI 2 setting all the time.Tries tv unplug,replug the tv back about an hour later for the tv to do a resetting itself back to the factory setting.Than go into the tv Menu changes to all the manually setting and turn off all of the auto functions of the HDMI hubs setting should solved this problems.
May 09, 2011 | Panasonic PT-52DL10 52" Rear Projection...
Lanier 6720 U14 error on screen
U14 is a user code for waste toner full.
Open front cover and you will see a clear plastic bottle at the bottom of the machine; lift this out and dispose carefully of waste toner (do not reuse). When fitting back into machine, make sure that inside of bottle is clean as the detection sensor looks through the bottle to see if it is empty and if toner is covering inside of bottle, the message will remain.
Apr 20, 2010 | Lanier 5235 Printer
My panasonic copier is displaying U14
Your waste toner bottle is full. You can replace this bottle but what I would do is just empty the bottle and make sure it is clean then re-install. Just dump it into a trash bag being careful not to make a mess.
Jan 08, 2010 | Panasonic FP-7735 Black and White Copier
Me marca el problema u14
La botella de desperdicio de toner esta llena, hay que vaciarla y limpiar bien.
Sep 27, 2009 | Panasonic Workio DP-1820P Laser Printer
My panasonic copier is displaying U14. what does
You need to replace the waste toner bottle or empty it and wash it out
Sep 19, 2009 | Office Equipment & Supplies
471 people viewed this question
jasbo
jasbo
