Question about Dishwashers
My kenmore built in dishwasher is leaking out the front
I have a kenmore diswasher, about 7 years old. Build in, electronic controls, has model 665158 12992 stamped on the inside door. It is leaking out the front between the door and the access panel, on the right hand side. It does it with plain water and soapy water.
  • 2 more comments
  • Anonymous Feb 26, 2008
    Ours is leaking out the bottom between the acces panel andthe door and also under the dials on the top.
  • Anonymous Apr 06, 2008
    WATER LEAKING BETWEEN DOOR AND ACCESS PANEL
  • Anonymous Jun 07, 2008
    our water is coming out of the middle of lower seal on door
  • denny270 Jun 29, 2008
    MY Kenmore dishwasher is leaking water out the bottom of the door . This happens as soon as the wash cycle starts. Model number 66515829000.
My kenmore dishwasher is leaking in the front, it is 8 years old...any ideas?
Posted on Nov 30, 2008
  • 625 Answers
Change the door gasket. also check to see if the wall hasn't "sprung out" of position this will always cause leaks if the side walls aren't supported.
Posted on Feb 03, 2008
Kenmore dishwasher 13749 needs a new electronic control panel
order sears on line / model & ser needed also instruction manual can be ordered .. not a hard job ..1/2 to 3/4 hr .. one wire or plug at a time new board is the same . hope this helps mm ..
Dec 07, 2009 | Kenmore 13742 / 13744 / 13749 Built-in...
Diswasher leaks sometimes
check in side when leaking is there foalm bubbles inside could be getting liquid soap in it if prewashing dishes and not rinseing good kill foalm with large amount of table salt
Jul 01, 2009 | Tappan 18 in. MDR251RE Built-in Dishwasher
The dishwasher won't start, the clean light flashes green 7 times
I have the same problem with ours Stock #17039 Type #575-0 Model # 665.17039401
Apr 14, 2009 | Kenmore 24 in. 16029 Built-in Dishwasher
Dishwasher is leaking
Gasket probably became dislodged, replace door gaskets, at 4 years old I would replace the gaskets, they are not expensive.
Feb 17, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Kenmore diswasher was runing fine till i found leak in disposal
Took plug out of new garbage disosal.Reading installation pages afer installation can be costly?Thanx
Jan 10, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
Kenmore built in dishwasher~2001 model year ,noisey when running.
HI remove the spray tube. remove top cover. look inside that could be a broken piece. this patr can break with pieces of glass going through it. thanks
Oct 13, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Leaking from the front ?
Hello Kathy J...
It sounds as if you want reassurance that you should replace your dishwasher.. The costs associated with replacing the racks themselves and the gasket on the door ( depending on who does it) might justify the purchase of a replacement model.. Plus newer models are more energy efficient that the older ones.. 7 years of use is a fairly long time so you've gotten your money out of it... I always use this litmus test to validate the purchase.. if the cost to repair is close to or exceeds the cost to replace, then replacement makes sense.. Very subjective indeed.. hope you make the right choice.. :-)
Sep 22, 2008 | GE Nautilus 24" Built-in Dishwasher
Water leak
Mine also started leaking. Element also too hot. Mine has a 20 year warrenty on the tub (which I was NOT aware of) Repairman came today and the whole tub unit and element will be fixed for free! Look in your whirlpool instruction book to see if yours is warrentied. BTW, my dishwasher is only three years old.
Aug 21, 2007 | Whirlpool 24 in. DU1100XTP Built-in...
My Kenmore diswasher gets stuck between the quick rinse and drying cycle
I am having the same issue as described above. I think it is either the timer, thermostat (temp assure), or thermostat (temp boost) that needs replacing. The dial gets stucks in both the wash temp boost cycle and rinse temp boost cycle. However, I don't have a picture of the temp assure or boost part. Does anyone know how to fix this? Thanks. -Bill
Aug 31, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
1,108 people viewed this question
Top Dishwashers Experts
