Question about Refrigerators
My refridgerator is not staying cold in the freezer compartment...
I think it is the defrost thermostat or the defrost heater from everything I've read. I know that I'll have to get in behind the back wall of the freezer but I can't figure out how to get the walls of the freezer out. It is a Magic Chef Model RB214R and I don't have a manual. I found one on Magic Chefs site but they did a crappy job scanning it in and every other page you can only read half of the page. Any help would be appreciated
Thanks,
Kelly
  • Gary Davd
    Gary Davd May 11, 2010
    THE coil on your unit is in between the ref and frez section remove the bottom of the freezer panel it is not on the back wall
    Problem Solver:
  • 19 Answers
You have to loosen hinge screws as well as screws on opposit side. Then pry up plastic floor at front the two corners are a little difficult then slide it out.Backing up a little though none of this shoul be nessesary if you could come up with an amp probe as you can check amps to see if heater is comming on. Rember the amp probe only goes around one of the line wires to read meaning you would have to split wire about 6 inches.Heater should pull about 3 to 5 amps. If your heater is not comming on it could be the limit control or you are getting alittle short on freon. The limit control is at the end of the line on the magic chef frig. I hope i have helped to diagnose your problem. Fxit
Posted on Feb 04, 2008
REFRIDGERATOR SIDE DONT KEEP COLD, BUT THE FREEZER DOES? WHY?
This symptom can be caused by many different failures, defrost system failure,( defrost heater,timer,thermostat), something blocking air transfer path to the fresh food section such as: ice build up, damper door not operating, main thermostat, check all these or have tech come in and check.
Good luck !
Mar 17, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The refridgerator is not staying cold. The
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others. You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
Mar 06, 2010 | Refrigerators
Why isn't our refrigerator staying cold? It is staying around 50 degrees and no lower.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge won't stay cold
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
OR
Sep 08, 2009 | Refrigerators
Kenmore Coldspot EM5119829. The Freezer works
or..
Sep 03, 2009 | Refrigerators
Kenmore Fridge, freezer compartment is cold according to thermometer, but ice wont freeze & frozen foods thawing out, weird. Fridge part is about 65 degrees. What could it be?
Should be around 10 degrees.
Aug 30, 2009 | Refrigerators
Zanussi fridge compartment has stopped cooling but freezer is ok
OR.
Aug 24, 2009 | Zanussi ZI918 / 12K Bottom Freezer...
I have a Kenmore Refridgerator appx 5years old, everything runs properly but does not get cold. It also runs all the time.
is the freezer at temp, meaning is everything in the freezer frozen? if so, it sounds like you have a defrost problem. is there heavy frost and ice one the back wall of the freezer? if so its a defrost problem. bad defrost thermostat, timer, or heater
Jan 02, 2009 | Refrigerators
Refrigerators Logo
287 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
