Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Hoover Windtunnel Mach 3.8 Model# U5465-900
I have a bad cord on my vacumm. I cannot seem to get to the motor were the power is junctioned to the motor. Is there a mannual somewhere that has a exploded view of this model and how to get to it????
Thanks
Jack
  • 3 more comments
  • Steve Larson Feb 16, 2008
    I also have a windtunnel with a bad cord. I hate to take the whole thing apart, but it looks as though that's what I'll have to do!
  • Rosebudd831 Aug 21, 2008
    How do you get to the on -off button? the switch isn't working and would like to take it apart
  • jcookieee Sep 02, 2008
    Need to replace the power cord. I'd like some guidance in what parts to remove to gain the needed access.
  • robert hess Sep 12, 2008
    I bought a replacement power cord on-line from Hoover for a Windtunnel Vacuum model U5755-900. How do I get to the location where the wires are attached to the motor to install the new power cord?
  • Anonymous May 02, 2009
    Brush not rotating
    Scholar:
  • 103 Answers
There are some phillips screws on the bottom that allow access to the belt. Under that may get you where you need to go.
Please remember to rate this answer.
Thanks, and good luck!
Posted on Feb 04, 2008
Remove the screws in back of handle to expose wiring.
Posted on Jan 08, 2009
Replace power cord on Hoover windtunnel vacumm
There are many different models of Hoover Windtunnel so I can't be specific to your model, you will need to determine where the cord enters the unit and how to gain access to the internal wiring. Disconnect the old cord and attach the new cord using the proper connectors.
Apr 02, 2017 | Hoover Vacuums
How do I replace a severed power cord on hoover windtunnel upright bagless model U5280900?
Hi there! We recommend taking your vacuum to a Hoover authorized service center to have your cord repaired. Follow the link to locate the nearest service center to you. Thanks! Service Center Locator
Oct 13, 2014 | Hoover Windtunnel Supreme U5280-900...
Wiring diagram
Are the wires still bundled or loose?
If bundled, there are 3 connections to the motor and they make an L shape (sort of). place the motor in front of you so that 2 connectors are on the left and the last is at bottom right. The thermocoupler attaches to the bottom right, usually black or orange wire with the metal device on it. The upper left is usually a 2 white wires clipped together from the power cord and the short junction to the light bulb. The lower left is for connecting the short wire for the bulb to the black wires in the light bulb harness. Just go counter clockwise: Power, light, thermocoupler and you should be in good shape.
Nov 06, 2013 | Hoover U6616-900 WindTunnel Bagless...
Hoover UH70120 WindTunnel TSeries problems with the cord. im a tech savy guy and have been trying to fix a cord after it was pulled to far out and now wont auto retract, but just cant find a way to pull...
You will probably have to replace the cord winding mechanism. I have never had any luck trying to repair one. Cord retracters are great when they work but it seems like they always go bad before too long. On many units you can't even replace the cord if you get a bad spot in it, you have to buy a new cord reel which can get expensive.
Jul 21, 2010 | Hoover UH70120 WindTunnel TSeries Rewind...
Replacing power cord
I replace one on my U6439-900. I took the back cover off and had to cut the wires and put new wire nuts on. Then I secured them really well with electricians tape. Might help to even put on a zip tie around the wiring. Hope that helps.
Jul 18, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover S3630 WindTunnel
Broken wire reconnected and power was restored.
Jul 13, 2008 | Hoover S3630 WindTunnel Bagged Canister...
How to replace power cord on Hoover WindTunnel upright vacuum
The aforementioned solutions probably never even attempted this fix on this model. The handle does NOT need to come off. but the 5 screws on the front housing DO: 2 above the light and 3 below it. Then to get the colored housing off you need to access 2 screws on the underside that are beneath the agitator roller. To do that, obviously the 4 screws holding the bottom plate need to come off too. Here's a link to a schematic that might help as you attempt to do this, (assuming that you still do!) http://www.elkypro.com/hoops2005/vacuum_parts/hoover/U5461-900.html
Once you have the main body housing cover off, then you can access the 2 screws atop of each trunnion cover that holds the motor assembly cover halves together. If you've made it this far, then gently pry apart the motor halves keeping even as yo do. Now you can see all the wiring necessary to cut and splice. Happy cord replacing! As for me, I am headed for the store, as I am not so sure I can remember how to get the darn thing put back together. But it was fun taking it apart!
Apr 15, 2008 | Hoover U6616-900 WindTunnel Bagless...
Hoover WindTunnel Canister: Roller brush motor not turning
These motors have a fuse incorporated in the field winding and it sounds like that blew. These motors sometimes overheat at the front bearing and the bearing will melt into the plastic housing. This will cause the fuse to blow. It sounds like that's your problem. You can remove the motor by removing the three screws on the bottom of the powerhead and then check the front bearing for any bubbling or blistering in the plastic housing. The shaft of the motor should turn easily.
Jan 26, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Replacing a fraayed and twisted power cord on a Hoover windtunnel upright
ok so I took this vaccum apart completely except for the electrical and motor systems. It seems to me that without dismantling both of these systems on the vaccum you can't replace the power cord. And I wouldn't recommend taking them apart unless you know what you are doing since replacing the power cord seems to require cutting the old power cord and soldering the new one onto the old terminals. All in all its probably easier to get a new vaccum altogether.
Dec 13, 2007 | Hoover U6616-900 WindTunnel Bagless...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
2,712 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
