Question about Samsung CLP 300 Laser Printer
Won't complete cycle
When I turn on the printer, it attempts to cycle normally. It only gets halfway through the cycle, making all the usual noises, then just stops. The red light on the top stays lit. Opening and closing all doors, trays, etc. doesn't change anything. It's only a few months old, and has been working normally until recently. Without replacing the cartridge, I'm at a loss. Any ideas or suggestions appreciated.
We have Samsung color printer, model CLP-500, not working. Please suggest Samsung service centre in India.
Posted on Feb 05, 2008
My trton t90z makes a loud noise 15 secs after its turned off. Its the thermal switch. Should I get it replaced. Its 2 days old.
What makes u think its the thermal switch? normally the noise at beginning or end of cycle is caused by the compressor with bad springs, groumets, or not sure how to explain this but the freon sits in a round bowl like orifice and when its low there is usually a loud noise at end of and beginning of cycle. other words when goes off and comes on? ( this is usually due to moving the fridge on it side and not waiting long enough for oil to settle before turning on?
Apr 02, 2015 | Refrigerators
Electrolux ESI 6180
I was shown how to clear your dishwasher and keep it running much longer. however, be careful when doing this. start with an empty dishwasher. pour 12 cups of cold water to the bottom area of tub and wearing latex, or rubber gloves, measre and por in exackly 2 cups of ammonia. let that solution sit there either all day, or overnight, at least a few hours, then run it through your machine, do not add anything else. do not do this with small children around. if you prefer buy the largest jug od vinegar (white) and pour it full strength into tub of your macine. let stand sevral hours, then put through a light or regulsr cycle. if you encountet that same problem empty, press drain cycle. retry usingrinse cycle instead. let me know if his resolnves your problem.
Nov 15, 2013 | Electrolux Dishwashers
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
Whenever its time to take photos, the camera makes a wierd noise and the focus lens do not shoot out as normal,what should i do???
When a camera makes a noise that isn't normal, usually it's a mechanical failure of the lens.
Remove the battery for a few minutes and turn the camera on and attempt to take a picture again.
If it doesn't work, I can venture to guess that the camera's lens mechanism is defective.
Mar 05, 2011 | Samsung S760 Digital Camera
Cda cw 494 - dishwasher makes beeping noises and stops halfway through cycle . will restart if turned off but will not complete . doesnt seem to be filling properly .now and then does complete cycle and...
Greetings,
usually, open and close door..then start counting the flashes. these will give you your fault code. The code then tells us where to go from there. off hand, i would say you have a heater problem.. Either, the water is not getting hot enough because of a faulty heater, or faulty thermostat. The button above the green light that flashes try and hold that down for a minute to reset....let me know about the flashes
Nov 16, 2010 | Whirlpool Dishwashers
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
When I turn on the power to the printer, the print carriage cycles to the right as normal then carriage sticks and begins to continually chatter.....at the same time the light bar on the scanner trys to...
There is usually a sensor on one side or the other of the carriage. When you power up the machine, the carriage will be moved to that end, setting off the sensor. Then it will move back and forth to test carriage motion. If the end sensor is faulty, the carriage will still attempt to move until it triggers the sensor, but when it gets to the extreme end, the motor will continue to attempt to move it, causing the chatter. After a time, it will stop with an error message.
Look at the carriage where the cartridges are, and you should see some kind of tab or ear on it. If it's broken, then you may get the symptoms I mentioned above. Also if you can see the sensor, make sure that it's not broken or moved out of place.
Mar 15, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Makes grinding sounds & usually prints blank
Try new toner cartridge, or even the old one if you still have it. Check if the grinding noises go away.
Jul 06, 2007 | Brother MFC 6800 All-In-One Laser Printer
Samsung CLP 300 Laser Printer Logo
107 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
