Question about Canon PIXMA iP1800 InkJet Photo Printer
New INK cartridges will not reset
Hello I am having problems with re setting my INK cartridges on my Canon iP1800. I install new ones when I ran out of the first set and they read as low, I also can not find where to reset and tell the printer there are new ones,,Whats going on? I purchased re-manufactured ink from INK JETS 4 Less could this be the problem?
  • Mikehimself Mar 11, 2008
    The software does not allow a manual reset.
    Probably a ploy by Canon to ensure that only Original replacements work satisfactorily.
    I would like to refill my cartridges.
    Does anyone have a solution?
The westank almost full
Posted on Apr 17, 2009
Download this software http://www.mediafire.com/?31yfdujziy0, it's a reseter of canon ink level
zouaier
Posted on Mar 25, 2008
Error occurred 6000
It's an ink level indication.
If you are using re-filled ink cartridges, try this.
To solve the ink level error in canon Pixma iP1800/Canon Pixma iP1880. This problem usually appear after refilled the cartridge on the canon printer and ink level indicator showing the ink cartridge is empty although you have filled a cc Ink into the cartridge. And if the problem occur you cannot using your printer to print. The solution you must reset ink level on the printer if you want your computer work again.
If you have a problem like that you ca follow this tutorial to solve your printer problem, here how:
Turn of the printer and Disconnect the power cable to the printer.
Press power button on the printer. While pressing the button connect the power cable to the power source (the power indicator will light in green)
While still holding power button press resume button twice - orange blink and return to green.
Release the power button, then the PC will recognize new cartridge installed (If the power indicator on the printer steady in green you continue to Steps 5)
Run the IPtools software, please await after this software detect your printer correctly or you can set the printer model on "Change Model" section.
Click "reset black and reset color" button to reset the ink level and Click "reset main and reset platen" to reset waste ink counter. After clicked the button you will see ink level of the cartridge on in the IPTol info has 100% and WP and WM has set to 0. Click Exit on IPTool
Turn off the printer and turn on again.
On the reset procedure above usually the problem found on steps 1-4 to make the printer steady light in green. On my experiment if steps 1-4 does not work on your printer, you can use manual reset method for canon iP1700 before continue to steps 5.
Good luck
If this helps you resolve your problem, please
consider giving a good rating and a quick thanks
or good job.It will help me as well Thank you.
Oct 26, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
How to install ip1980 ink cartridge
did you mean that even the cartridge place was new, no ink came out of its printhead? maybe the ink cartridge is defective. if it says that your CL-41 has run out, press reset/paperfeed button for 5-10 seconds to reset the cartridge. hope to be of help.
Nov 14, 2009 | Canon PIXMA iP1800 InkJet Printer
Canon iP1800
Make sure you removed the protective film on the cartridges.I've seen this alot on new installs.Next clean the print catridge contacts with a clean moist (very little) cloth ,then dry cloth.It may work, Good Luck.
Sep 08, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Ink cartridge cannot be recognized
You can try a new cartridge, or look down on the front edge of the carriage with a mirror and see if one or more of the gold pins are bent.
Jul 25, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
New ink cartridge. Canon ip1800 series print is pale
check the settings to insure your aren't printing in "Draft" mode
Jul 23, 2009 | Canon PIXMA iP1800 InkJet Printer
My Canon IP 1800 cannot recognized the Black ink
It sounds like the electrics on the back of the cartridge have failed, replace with a new cartridge, and away you go.
Jun 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon ip 1880 - colour cartridge problem
no if ur filling the catridge more times the printer going to damage
May 27, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon printer pixma ip1800 not recognizing new cartridges installed
If the cartridge is new, probably the connector between head and cartridge is dirt. clean it using dry tissue and never touch by hand the metal plate
Mar 10, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon iP1800 printer,flashing orange light under the green 'on'
First off, How many times does it flash organge before it goes to green?
two: out of paper
three: paper jam
four: Ink has run out
Five: FINE cartridge cannot be found
Seven: FINE Cart. not installed in correct position
Eight: Ink absorber almost full
Count how many times it flashes. Then get back to me
Feb 05, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon PIXMA iP1800 InkJet Photo Printer Logo
324 people viewed this question
old marine
old marine
