Question about QuietLine WD-9900 Front Load Washer / Dryer
Soap dispenser water does not wash out the soap from the main dispenser. I use the prewash dispenser ok
  • Jessica Williams Jul 14, 2013
    Where do you put the soap I just moved in to an apartment complex that has one of these and I don't know how to use it! Please help?
  • 126 Answers
If you use a program without prewash, the machine will not flush the prewash chamber in the drawer.
Posted on Feb 06, 2008
Bleach stays in dispenser
Only works on the prewash cycle of a prewash plus main wash cycle.
Jul 31, 2016 | Washing Machines
A small hinged part came loose from behind soap dispensing drawer. It Looks like a flap to close the main soap channel during prewash. How and where do I put this back?
To the rear and top of the drawar there should be a mechanism to release the drawer, it will need to be depressed, pushed down....then you should be able to pull drawer out in order to check how the flap should go back
Jun 11, 2015 | Miele W4840 Front Load Washer
Which of the 3 dispensers does the soap powder and rinse go in for the Bosch WFD2473
You can read the manual here.
In short page 15 describes the chambers as follows:
  • The chamber marked "I" is the prewash detergent.
  • The chamber marked "II" is the main wash detergent.
  • The chamber marked with a flower like icon is the fabric softener.
Page 14 describes how to prepare for your first wash by running it without clothes for the very first time to remove water left inside from the factory during testing. Do not skip this important step! You only have to do this once.
I hope this helps & good luck! Please rate my reply. Thank you.
Apr 06, 2011 | Washing Machines
Dishwasher soap still in door after wash cycle, so dishes are not very clean. Soap dispenser cover is sprung open but soap (on both sides, wash and prewash) is still mostly where it was poured, only now...
Check for the right amount of water in tub. In this unit close to the lip of the tub after fill. If water fill is correct check movement of lower spray arm. Other possibilities delayed action of dispenser from defective wax motor. Most probable is wash motor. Start unit after fill and when was starts, open door and see if water is being pushed to the top rack and dripping from the top of tub. Motor is easy to install.
Oct 12, 2010 | Maytag MDB7100AWB Dishwasher
FQ106D1 Main washsoap dispenser always has soap in
remove dispenser drawer and give it a good clean.adrian,,,,
Jun 14, 2010 | Washing Machines
P801front load washer
put on prewash cycle. note which tray water enters and that is the prewash tray.
put on wash cycle which has no prewash. note which tray water enters and that is main wash tray. remaining tray is rinse
Sep 06, 2008 | Samsung WF337AA Front Load Washer
My soap dispenser does not open properly and soap streaks on my door and detergent is always left over in tub no dishes are cleaned any suggestions?
ck water level ..i assume you mean diswasher water should be almost to bottom of float..if water ok are you sure main wash motor working
Aug 04, 2008 | Maytag Washing Machines
WFR 2460 Front loader
We went through the whole "clean the soap dispenser" deal and results were the same. Exploratory surgery revealed that the Prewash hose (for lack of better term), which connects from the top of the drum housing to the right side of the dispenser drawer (facing the machine)was completely clogged with gunk. Especially strange since we don't prewash hardly anything, ever. The hose that connects the bottom of the detergent dispenser with the side of the drum housing did have a lot of buildup, but I do not believe it was the cause because this was only happening on the rinse cycle. I also found the flow meter was frozen up.
Jun 27, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Which compartment is for the laundary soap
According to my information the dispenser drawer has four separate compartments for adding laundry products to the wash load. These compartments are:
1. Prewash Detergent Compartment
2. Main Wash Detergent Compartment
3. Bleach Compartment
4. Fabric Softener Compartment
Laundry products are diluted and dispensed automatically
at the proper time during the wash cycle. The separator in the Prewash and Main Wash Detergent Compartment can be moved to accommodate either liquid or powdered detergents.
Jan 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dishwasher soap dispenser sticks
Your soap is clotting because there isn't enough water being sprayed around inside.  The water spray washes the soap out of the dish, if all is working well.  My machine had the same problem.  I had sufficient water level, but the spray head wasn't spinning very well.  I found the end-most hole in the spray bar to be plugged.  It is the end hole that provides a jet that makes the head spin.  I cleaned a bunch of debris out of the hole and the mchine started working and cleaning like it was new.  That was quite an axccomplishment since the machine is 15 years old.
Dec 28, 2007 | GE Nautilus 24" Built-in Dishwasher
QuietLine WD-9900 Front Load Washer / Dryer Logo
126 people viewed this question
Top QuietLine Washing Machines Experts
Are you a QuietLine Washing Machine Expert? Answer questions, earn points and help others
