Question about Brother HL-2070N Laser Printer
HL-2070N Network configured setup questions.
I've set up my printer connected through my router from my Vista machine. It seems to all work. I assume that to use it with other computers on my home network that I would have to load the drivers on the other machine(s). When I try to load the drivers on my xp machine from the cd I get a "this OS is not supported" The printer is suppose to work with XP so I'm baffled.
  • wakewatcher Feb 02, 2008
    Doh! I was using the wrong installation Disk. Thanks.
    Genius:
  • 3,422 Answers
The printer software u got is for vista machines only and can't be installed on the xp machines.to install it on xp machines u need xp supported software.
Click here to download the xp software of printer and then install it on ur xp machine and ur problem will be solved..
Goodluck,
Don't forget to rate me as fixya..
Posted on Feb 02, 2008
6ya staff
SOURCE:
Does the linksys-G support WPS or AOSS?
Good question, I have the same router & Brother HL-2280DW and ran the printer setup CD from Windows XP SP3 via temporary USB connection & it seemed to work. The WAN report on the printer itself says OK, however the computer can't seem to find the printer "No devices could be found on the network." I let setup make changes to Windows Firewall, not sure about Microsoft Security Essentials however. This seems like a nice printer/copier at a nice price but this setup is frustrating! PS If it's a security issue I'd like to say thanks to all the hackers for ruining technology for everyone, your junk is responsible for slowing down & complicating computers & technology in the world. Someone please do everyone a favor & start making antibodies that *kill* viruses & spyware & spam and clean & speed things up for a change! All these villians - Where are the cyber super heroes????
Jan 14, 2012 | Linksys Wireless-G WRT54G Router
Just replaced Netgear WebSafe router with Linksys WRT400N. Now, can't "see" printer in network nor can access it to change settings (or print). Have tried with ethernet cable straight to router and through...
Reset printer to factory settings according to manual. Plugged in ethernet cable directly to router. Ran BRAdmin which recognized printer and saw that IP address had been automatically set within new router range. Changed setting to STATIC. Deleted old printer definition from printer list and added updated definition using Printer Setup Utility. Printed test page from BRAdmin. Also printed file from Documents folder wirelessly. Changed printer settings in another laptop & was able to print wirelessly from there as well.
Jan 07, 2010 | Brother HL-2070N Laser Printer
Network issue with Brother 2070N Laser printer
Check if you have disconnect the USB Cable. Get IP from the printer in the menus. If you can´t get it. Use a Program like MarkVision Professional. You probably have no DHCP in your network. you should enable it and check IP in the router.
Jun 22, 2009 | Brother HL-2070N Laser Printer
Ip address for brother 2040
Up to 20 pages per minute
• HQ1200 resolution (up to 2400x600dpi)
• HL-2040: 8MB memory standard
HL-2070N: 16MB memory standard
• 250-sheet input capacity
• USB 2.0 and Parallel interfaces1
• Built-in Ethernet Network Interface1 (HL-2070N)
The 2070 has networking not the 2040, according to the borchure, you would not be able to network this one, only usb and parrallel port. You could do it if you wanted to use a computer as your network printer server. In that case just use your router to select an ip address for that machine and either run it in DMZ if you have a linksys . If you just enable shared printer it should work on all your machines on the network. That's how I did it prior to a 4in1 wireless.
http://www.brother-usa.com/VirData/Content/Printers/ModelBrochures/Brochures_HL2040.pdf
Mar 19, 2009 | Office Equipment & Supplies
Can't reinstall my brother hl-2070n
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came withthe printer. When the software program asks you to connect theprinter to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 29, 2008 | Brother HL-2070N Laser Printer
I am trying to connect to new acer laptop to my wireless network, but my acer empowering technology toolbar, located above my keyboard, does not seem to be working to allow me to connect to my wireless...
Hey
for this you gotta now the following:
1. ssid : this is the name of your access point (router)
2. key/passphrase: this is the network security key you configure your router with (if your router has a default configuration (the one that came with the device right out of the box which is not recommended) your key may be a blank key ... you simply don't have one set up.
3. the encryptation method: wep, wpa, wpa2. this goes again to how you have your router configured and if your don't have anything configured with your router in regards to encriptions (not recommeded) you may simply not have any encryptation that you need to select here.
important:
make sure your wireless adapter is working and is on:
your laptop may have a switch on the front to turn your wireless adapter on (i don't know what model of laptop you have so you may want to check the user manual that came with laptop to find the switch) or you may have to turn it within windows. (also check the user manual of your laptop)
now that you have the info needed and your adapter is on there are 2 ways to do this:
1. using your beloved acer empowering technology:
I found this that may guide you through the process of setting up your wireless connection
ftp://ftp.support.acer-euro.com/notebook/empowering_technology/acer_enet_management.pdf
look under the title: SETUP A NEW PROFILE and follow the instructions..
now if acer empowering does not work... you can try to setup your wireless connection with windows,
2. Using windows vista to setup your wireless connections:
I'm assuming you're using vista so here's a set of instructions with pictures you may want to take a loot at and follow
http://www.home-network-help.com/vista-to-connect-wireless-network.html
let me know how it went!
if problems.. post what you see and we'll try to give you hand. (please give as many details as possible)
Oct 03, 2008 | Computers & Internet
Brother HL-2070N Will Not Print
Hi tom8972
try to reinstall the driver of it.
hope this helpful for you,
thanks,
Hamedo
Sep 13, 2008 | Brother HL-2070N Laser Printer
Connect to wireless network
plug an ethernet cable into one of the ethernet jacks on the router and the other end into the printer. run driver installation setup on your computer that is connected to the wireless network and choose peer-to-peer networking. let your computer search for the network printer. follow installation instructions to complete.
you can download the driver here
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=hl2070n_all
Jul 29, 2008 | Brother HL-2070N Laser Printer
Brother laser printer HL 2070N
Hello rustyred, i tried to answer your live chat but my server or the fixya connection was causing issues. Trully sorry. can i still help? I am assuming you upgraded to vista from xp and you are missing the above options, might i suggest visiting brother web site and seeing if they have an updated driver for your printer compatable with windows vista, this may give you the options you want.
Mar 12, 2008 | Brother HL-2070N Laser Printer
Brother HL-2070N Laser Printer Logo
109 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
