Question about Yamaha HTR-5830 Receiver
Video routinely "hiccups" when run through the receiver.
When I run my cable box and DVD player through the reciever, the video blacks out for a second every couple of minutes. this has only happened when running video through the receiver. to fix, my cable box component video goes straight to the TV (hitachi plasma) and i can successfully run the audio through the stereo this way. The DVD gets hooked up through the secondary video input on the TV. It would be nice to be able to run the whole thing through the receiver though. It's done this since it came out of the box, but I've never addressed the problem. any ideas?
  • FOR3D Mar 27, 2008
    IT SEEMS AS THOUGH YOUR DVD HAS SOME HARDWARE IN IT THAT PICKS UP THE ANTI COPYING SIGNAL THE PICTURE GOING OFF AT REGULAR INTERVALS IS AN ANTI PIRATING DEVICE . BECAUSE YOUR DVD WORKS FINE THE OTHER WAY DOESNT IT?
LOOKS LIKE THE ANTI PIRATING HARDWARE IN YOUR DVD WORKS
Posted on Mar 27, 2008
No audio when watching HDTV and the home theatre receiver is set to cab/sat. HDMI cable is run from the receiver to the TV. Cable is run from the cable box to the receiver. Tried using "y" audio...
If your TV has HDMI in and digital optical out, run your HDMI cable via HDMI out on box to, HDMI in on TV then, run digital optical ouyt from TV to digital optical in on reciever. Your reciever has video pass through but, not the best option. Video components should run to TV then out to reciever. If you do not have digital optical out on TV, you may be able to use RCA.
Jun 24, 2011 | Insignia Audio Players & Recorders
I was hooking up my sisters surround reciever for her and used an optical cable to the reciever from the TV. Her TV gets signal from the cable box via coax and uses HDMI from DVD player. I am stumped that...
srry but the tv is not capable of sending hdmi audio through its outputs the dvd player audio must be run through rca red and white or black if you have digital audio out to the back of the receiver on its own channel
Jan 11, 2011 | Audio Players & Recorders
I am trying to hook up my Pioneer vsx-455 to a LG LED LCD TV. I am not sure on how to do this and I can not find a manual anywhere. Can you help me?
your reciever does not have hdmi, so the audio is not going to be true DD+ or DTS for broadcast tv.
if your dvd/blue ray player has digital optical spdif, this can be used to transfer the encoded DD+/DTS digital audio.
the besat way to run your tv audio through the reciever is to hook up the dvd/blue ray player up with (perferrably) digital optical spdif, composite spdif or (least favorably) through the stereo stereo analog inputs on the reciever for "dvd" audio in and hook the video from the dvd/blue ray up to the corresponding "dvd" video component input on the reciever.
this way is only going to get your dvd/blue ray sound, next you need to hook up your cable box to the reciever so that you can get broadcast tv sound. hook up the cable box audio to the "tv" stereo analog audio ins, and hook the video to the corresponding "tv" video component inputs.
the component video inputs have separate jacks for red, green and blue ( labeled "Y" "Pb" and "Pr") and are capable of carrying a 1080p full hd signal. use the component video outputs on the reciever to output the video signal to a component video input on the tv, using the receiver's input selector to change the video source.
Nov 25, 2010 | Pioneer VSX-455 Receiver
I have direct satalite tv VR 6050 kenwood surround sound tuner vizio tv, dvd player, and a vcr, Im confused on how its hook up and what order should it go something like sat in to sat box to kewood...
that reciever is not going to carry a hi definition video signal, it doesnt have either hdmi or component video inputs.
you can still use it, but if you run the picture through the reciever, it will have poor quality.
heres how you are supposed to hook it up:
find the single,m yellow video jack on your sattelite box, and hook that up to the "tv" video input, then hook the laft and right audio outputs from the cable box into the "tv" audio left and right inputs on the receiver. hook up the dvd player and vcr in the same manner, using "dvd" and "VCR" (if labeled as such) inputs on the reciever.
finally, send the tv video and audio outputs to the composite video in and left/right audio inputs on the tv. the video will be running through the reciever, and when you use the reciever to switch the sound source, the video will also be changed. you could get better picture quality if you ran the video directly to the tv using component (seperate green, red and blue) outputs/inputs, and bypassing the reciever on the video end, but then you would have to change inputs on the tv AND reciever to change from your cable box to your dvd player.
Nov 25, 2010 | Kenwood VR-6050 Receiver
I'm trying to hook up my reciever up to my new flat screen any help as far as what cables I need, I will also be putting a dvd player on as well. I have comcast cable also, I've been told I need to get a...
This is posted under the Sony STR-DE685 heading, so I assume that's what you have. (If not, your receiver may have other hookup options available.) It might help if you download the manual if you need a copy from Sony's site here. It details all the rear panel connections.
This receiver doesn't have HDMI connections, so you'll need to make your connections using RCA cables It doesn't pay you to get an HD cable box if you're planning on connecting it through the receiver.
Output to the TV is very simple. Use a component video cable to go from the component monitor output on the receiver to the TV's component input. Then switch the TV to that input, turn off its speakers and listen to the sound through the receiver. Only one cable going to the TV that way.
Inputs will need separate audio and video connections since there are no HDMI connectors. Use the component video connection for your DVD player for the best video quality. The DVD/LD input offers those jacks. You can connect your cable box to the VIDEO 2 input using component video connections (if the box has those outputs) or composite video. Then the video and audio from the box will run through the receiver as well.
If you want to get a new HD cable box, you'll need to run a cable from its HDMI output to an input on the TV, and switch the TV to that input to watch the box. You can still run the audio signal through the receiver though. That will add one more cable to your hookup, and you'll have to remember to switch inputs.
Hope this helps. Thanks for using Fixya!
Jan 26, 2010 | Sony STR-DE685 Receiver
No surround sound from Kenwood VR-5090
please select the 5.1 option in the audio menu of the reciever.
Jan 10, 2010 | Kenwood VR-5090 5.1 Channels Receiver
I have a vr-405 5.1 channels reciever, I have it hooked to nanlog out on tv per tv manual,tv speaker r off,there is a dvd/vcr hooked into video 1 and it works on tv speaker, where do i hook into the...
try to be a little more clear on what you are trying to do.do you have it connected to hdtv and cable box if so run hdmi cable from cable box to tv and then run optical cable from reciever to cable box you then must turn reciever to cd/dvd to listen to it leave reciever in auto mode go into cable box menu under audio and select dolby digital
Feb 21, 2009 | Kenwood VR-405 Receiver
I am trying to set up a SA-TX50 A/V receiver, SH-300 processor, DVD player to my Philips LCD. I also have a digital cable box, seeking assistance. Mike
1. cable box video out to video 1 in on the lcd , audio out to reciever input 1 ( tv, vcr , or what you want it on )
2. dvd s-video output to lcd video 2 s-video input , dvd audio out to reciever dvd/cd audio input , and add the optical or coax cable digital audio for dolby digital surround sound
electech
Nov 26, 2008 | Technics SA-TX50 Receiver
Onkyo TX SR 702 AV Receiver
don't run you video from the projector to the reciever. just run it to the dvd and run the sound from the dvd through the reciever
Jun 01, 2008 | Onkyo TX-SR702 Receiver
Panasonic legacy connection
s-video is a legacy connection. legacy means obsolete and this will impare your image.
what you should do is connect the cable box and blue ray directly to tv with hdmi cable, then run audio cables back to the reciever from these devices. the vcr and regular dvd player would be routed through the reciever the conventional way. you would have to change the inputs on the tv between the cable box, and blue ray if u have one, and a seperate single tv imput for components running thru the stereo. you would have to use the reciever to select between audio sources, and the video sources between the vcr and dvd only.
Nov 04, 2007 | Panasonic TH-50PHD8UK 50 in. Plasma...
Yamaha HTR-5830 Receiver Logo
49 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
