Question about Philips 42PF7320 42 in. EDTV-Ready Plasma Television
No picture through hd/dvi?
Playing my ps3 in hd through the dvi input.worked fine for 3 weeks,but now get no picture but my upscaled dvd player plays ok through same input in sd?
  • 476 Answers
Change the output of the PS3 to 480p as this is allthe TV supports.
Posted on Feb 08, 2008
Our ps3 quit recognizing dvd's It sill plays games and bluerays
Try setting your resolution to 480i/p and see if you can play one then.
I've also heard of turning off dvd upscaling, although your ps3 should be able to upscale your dvds.
Feb 24, 2010 | Sony Playstation 3 (PS3) Console
Sony rdr vx410 dvd player playing some dvds in black and white
  • DVD's are standard definition video sources. Number of lines output is 576 lines, whereas your HD TV set has 720 or 1080 lines. This difference may result in a poorer image. However some DVD players are able to “upscale” picture to obtain a very good picture. Check if your DVD player has the following connectors: YUV, DVI or HDMI. For more information, refer to the instruction manual of your DVD player.
  • Some HDMI or DVI featured DVD players also have an internal processor that can upscale pictures from a DVD to 720 or 1080 lines to provide an excellent picture from a standard definition disc to your HD TV set. Those settings are available from the setup menu of your DVD player. Please refer to the instruction manual of your DVD player.
  • If your DVD player does not have those connectors and only has a SCART connector, or S-VIDEO, or composite, there is not much to do to improve the picture quality. Just make sure that you are not using the cheapest cables and that the picture settings of your TV set are correctly adjusted.
  • Some high end TV sets have a picture improvement engine that can soften a noisy image. Make sure that it is activated from the setup menu of your TV set. Please refer to the instruction manual of your TV set.
  • If people and objects have weird white outlines around them. This may suggest that your TV sharpness is set too high. Make the correct sharpness adjustments from the setup menu of your TV set.
  • Make sure you use good quality cables and that your cables are not too long (less than 5 meters long).
Jun 15, 2009 | Sony RDR-VX420 DVD Recorder/VCR
Wharfedale DS-A243 HDMI Upscaler wont play HD DVD
Hi, sorry to have break it to you but your self diagnosis was correct! It is a 'normal' DVD player that upscales and will NOT play HD discs.
Nov 12, 2008 | Wharfedale DVD-M3 DVD Player
Display resolution through dvi input HELP!
For the record I have a playstation 3 running to tx100 through hdmi to dvi adapter. It does all resolution no probs, including 720p,1080i and 1080p (which tx100 does do smoothly through dvi). My denon upscaling dvd player works fine too. In fact the tx100 looks totally awsome with PS3 games and Blu-ray.
Maybe your dvi lead is the wrong type (i think there are 2 types) or perhaps you could test with a differrent piece of DVI kit in case it's your pioneer causing probs? Hope this helps.
Jan 14, 2008 | Hitachi PJTX100 Multimedia Projector
No sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Dell w3000 & PS3
This may not be DVI issue.
I connected DVD player HDMI ----> DVI ( Dell W3000) LCD TV.
Later I found that Dell TV version of DVI does not support HDCP protocol ( High Definition Content Protection protocol). So I could not play HDMI to DVI movies from my DVD player instead I use Y Pb Pr -- this works ok.
Hope this helps... I am not use PS3 enforces HDCP - I assume Sony linked with Sony Pictures would enforce HDCP on HDMI cable.
Dec 27, 2007 | Dell W3000 30 in. HD-Ready LCD Television
Hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Dec 27, 2007 | Onkyo HT-S790S System
LG DVX9900H Playing HD
This is not a HD player ,it only upscales
Dec 25, 2007 | Televison & Video
Sd 370e
i have found out that the sd370e is not for playing hd's, it upscales normal dvd's only
Oct 16, 2007 | Toshiba SD370E DVD Player
PHILIPS DVP 5960 DVD PLAYER
password of dvd player pohilips 5061
Oct 13, 2007 | Philips DVP5960
Philips 42PF7320 42 in. EDTV-Ready Plasma Television Logo
104 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
