Question about LG WM1812C Front Load Washer
Crazy Washer!!! I have a LG wm1812c front loading washer. My problem is that during the final rinse and spin, the machine will shut off and still have standing water. After removing the water by bucket, you can start the machine again. Its wierd because, if I put it on quick cycle it will usually wash all the way through. It has started shutting down in this mode also. Any help would be helpful. Thanks
    Problem Solver:
  • 9 Answers
Any error message? You're drain pump could be on the fritz. It'll work sometimes and not others. You can manually drain it through a small hose that is tucked away in the front bottom left corner. If you've never noticed it, beware of thick yucky sludge that may be clogging it up. There is also a filter next to it that is bigger. It'll drain quicker and all over your floor so use prudence. Best of Luck!
Posted on Feb 05, 2008
    Genius:
  • 1,554 Answers
Have you checked the filter for debris ?
unplug unit , remove bottom panel ( 3 screws on bottom front lip)
open the filter access in center, there will be water to catch.
Posted on Feb 02, 2008
Wash down
Since down comforters are very light in weight, they confuse energy efficient front loader washing machines in how much water to add. Therefore, very little water is used, which results in a semi-damp comforter at the end of a wash. Pre-soaking the comforter beforehand would help, however, now the comforter weighs a ton, and the machine will vibrate like crazy during a spin cycle. It may be better to have the comforter dry cleaned.
Apr 28, 2014 | LG WM1812C Front Load Washer
My washer seems not to spin properly during the rinse cycle and will not spin now i get what i assume is an error message ue when its time for the spin cycle to begin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 18, 2011 | LG WM2455 Front Load Washer
The washer isn't draining and spinning. Washer has message coming up- OE and it stops working. We were thinking it was the water pump? Please help.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Oct 12, 2010 | LG WM1812C Front Load Washer
My LG TROMM model # WM1812CW has a burning rubber smell when it's on the last high speed cycle. Can you help me locate the problem?
I just ran into this same situation. The problem was that the basket has been rubbing against the tub/door gasket. In this specific case it finally wore through the tub and was a hole through it. It si looking to be approx a $600 repair.
Sep 03, 2010 | LG WM1812C Front Load Washer
Drum nakes noise when spinning
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Aug 23, 2010 | LG WM1812C Front Load Washer
The washer will not drain the water. A code O E keeps flashing...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 24, 2010 | LG WM1812C Front Load Washer
My Whirlpool GHW9250ML is having problems spinning
My Whirlpool Front Load Wasehr Model# GHW9250ML is having problems spinning on the final rinse cycle. The machine shuts down and the letter F appears on the digital read out.
Mar 06, 2010 | Whirlpool GHW9250M Front Load Washer
Lg front load washing machine does not seem to get the clothes clean. I think it is because it uses so little water??? How can it get clothes clean with just a few cupfulls of water? All controls and...
I have run into this problem several times with LG washers. On one job LG had us replace every electronic componet that had anything to do with the water fill and the problem still was not resolved. The electronic control determines how much water to fill depending on the load size, so smaller loads give you less water, with the same amount of soap. Leaving clothes in the washer overnight, and leaving the door closed does contribute to mold and fungi growth in the washer. The customer tried different brands of soaps and different amounts of soap. He left the door open after usage to allow the unit to dry out, and tried different cleaners, to clean out the sludge build up. We determined that there just is not enough water to thoroughly clean the clothes. The sales store had to replace the washer with another brand. There is an ongoing class action lawsuit against Lg for this problem. Do an online Search for lg washer lawsuit. By the way, we don't have a problem with clothes not getting clean with the Whirlpool Super Capacity Duet Front-Loading Washers. Good Luck, Appliance Specialists
Jan 04, 2010 | LG WM1812C Front Load Washer
Washing machine shuts off before cycle is finished now it will not last one min. on before it shuts off...what to do?
We have a front-loading LG washer. Today, I took a look at it when it was beginning the spin cycle because it sounded a bit different. I noticed that it was beginning to spin and would stop because [I believe] it was detecting a strong off-balance. It would then try to spin in the opposite direction and the same happened. After two more attempts, it automatically shut off with no warning nor error. We set the washer to wash and spin again and I began to work on balancing it. After adjusting the feet and waiting for the spin cycle again, it continued successfully because of the reduced off-balance. I'm not sure if there are other reasons that would cause the washer to turn off. This is the only one I have come across so far.
Oct 22, 2009 | LG WM1812C Front Load Washer
Help
You could have a blockage in the drain spigot, that is where the drain hose connects to the plumbing under the sink/tub, or the drain pump may be jammed. Check the spigot and if clear remove the drum to pump hose from the pump. Check inside the pump and the hose for any foreign matter. Try to turn the pump impeller by hand . If the impeller doesn't turn freely and all is clear, replace the drain pump. Always switch the machine off and pull the plug out of the socket before doing any work.
Oct 30, 2007 | LG WM1812C Front Load Washer
LG WM1812C Front Load Washer Logo
97 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
