Question about Apex Digital GT2715DV 27 in. TV/DVD Combo
Apex GT2715 TV, burned resistor
APEX TV GT2711S MARCH 2002 CHAS:E106527 SRF-C 94V-0
Power on problems, took apart found R-502 burned up. Is a circular stand up
resistor, would like to know what this resistor is so I can replace it.
PWVANSMITH@BELLSOUTH.NET
THANKS,
Parris
  • 979 Answers
Wire wound 190 ohm 10 watt should do the trick if that's all that's wrong with the set...accordianman
Posted on Mar 21, 2008
Need codes for remote model number uk1a if it will work for converter box digical stream model number dtx9950
Your remote is only able to control TVs and DVD players. It will not control your DTV Converter Box.
Here is the remote (Apex UK1A) manual:
http://remotes.com/remotes/documents/Apex/UK1A.pdf
Here is your DTV Converter Box (Digital Stream DTX9950) manual:
http://cbsdallas.files.wordpress.com/2011/01/radio-shack-digitalstream-dtx9950.pdf
Jan 06, 2014 | Apex Digital GT2715 27" TV
Apex Gt2715 wont turn on
that was mean their is a problem either in the power supply section or at the main board. which need a proper trouble shooting and repair. which can be hand held by a trained tv repairman. just let me know if you will be the one to do the repair so i can give further solution.
Dec 07, 2012 | Apex Digital GT2715 27" TV
Apex LD4088 no picture
The inverter is the usual suspect with that symptom. It may be hard to find a replacement inverter for an apex model. But you might be able to get one from www.tvrepairworld.com
Oct 29, 2012 | Apex Digital LD4088 LCD TV
Need to get the circuit diagram for board e106527 srf-c 94v found on TV Digistar Model CR_20SS01D
quick way with location number for the part (a cap?) will be marked on the board---call the maker or Google the model number with the location number.
Oct 15, 2012 | Prima Televison & Video
How do i reset an apex tv set with model number gt2715?
Hello
You are locked out I thinks. Try the following to override the locking.
Apex TVs use a four digit code to control the v-chip. The override code for many models is 6688. Other sets may not have one, or may have a default code of 1225 instead of an override code.
  1. To use the override code:
  2. Hit the MENU key to get to the menus
  3. Go down to the SYSTEM menu and hit the right arrow on the remote control.
  4. Once in the SYSTEM menu, go to PARENTAL GUIDE. It will ask for your code.
  5. Enter the override code listed above. From here, you can turn on and off different rating restrictions, as well as set a new code.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired
OK.
Dec 02, 2010 | Apex Digital GT2715 27" TV
The red lock button is in the bottom left corner of my GT2711S tv how do i get it unlocked
check your remote for a simular looking button with the lock symbol by it.
Oct 24, 2009 | Apex Digital GT2715 27" TV
Apex Digital GT2715DV 27 in. TV/DVD Combo Logo
338 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
