Question about Atari 2600 Console
ATARI 400 CORD THE ONE THAT PLUGS IN THAT LOOKS LIKE A COMPUTER ABOUT 1 TO 1 AND 1 HALF INCHES IN LENGTS [ DO YOU KNOW IF IT CONTROLS THE MACHINE ] I BOUGHT ONE THE 400 MACHINE AND IT HAD EVERY T
HOW TO GET THAT CORD AND DOES IT PLUG INTO THE TV
  • 667 Answers
Check eBay, there are many Atari items usually available
Posted on Feb 02, 2008
Will 51 cubic foot of foam insulation, cover 400 square feet of a wall?
That depends upon how thick the foam insulation is. That is the only way to compute from cubic feet to square feet.
To simplify, assume the foam is 1 foot wide by 1 foot thick by 51 feet long. That is 51 cubic feet of foam. If you slice the block lengthwise at 1 inch intervals, you get 12 slices, each 1 foot wide by 51 feet long by 1 inch thick. This is 51 square feet of coverage at 1 inch. You would be able to cover 51x12, or 612 square feet.
Increase the thickness of the slice to 1-1/2 inches, you only get 8 slices, or coverage for 408 square feet.
Any thicker than that, and you won't get enough coverage for 400 square feet.
Aug 05, 2016 | Cars & Trucks
What is the spacing size between pins on the electric cord
Measure the pins center to center. There are three common spacings.
1/2 inch, 11/16 inch and 1 1/16 inch..
Appliance cords are available at most hardware stores including Lowes, Home Depot, Menards and even in the electrical departments of many other stores. If you have your old cord it is easy to compare the plugs. There is a 3/8 inch difference between the 11/16" plug and the 1 1/16" so it is easy to see the difference.
Aug 03, 2014 | Faberware 12-55 Cup Coffee Urn
Hooking atari flashback to the tv/
White is sound yellow is picture.
look for three rca jacks red white yellow. connect and set tv to see whatever input you connected to. white can go either white or red but yellow must match.
Dec 24, 2013 | Atari Flashback 2 Console
I need a power supply for atari 7800
the Sega Genesis model 1 power cord is the same voltage and amps as a 7800, if you know how to solder you can change the power port and use that power cord. or you can just hard wire a power cord on here is the site for that . http://saundby.com/atari7800mod/7800_powermod.html
Apr 14, 2012 | Atari 7800 Console
Missing on off / tv type color bl-wh switch, it's the 1 1/2 inch long metal looking part that stick out so you can move to on- off/ tv type color bl-wh
Well you will need to buy a new piece for your atari 2600 console on what you are
talking about then. Radio shack might have this part then.
Feb 08, 2011 | Atari 2600 Console
I have the Thompson model PW-400 walking foot sewing machine and when I plug it in it immediately starts running. (sewing)
I have the Thompson PW400. I know this sounds like too simple of a solution, but it actually happened to us. We accidentally plugged the machine cord into the wall outlet. Are you plugging the cord attached to the machine directly into a wall outlet or extension cord? The second part of the cord has two plugs on it, one for a light and the other for the motor. If you aren't plugging the machine cord directly into the plug marked "motor" the machine will start up immediately running at top speed. Hope that solves your problem.
Aug 31, 2010 | Sailrite Ultrafeed LS-1 Deluxe Mechanical...
Kenmore 400 washer, model 110-29422 801: How do I get at the attachments for the electrical power cord - my puppy chewed it in half, and I must replace it. Do I remove the top, or the back, and how,...
Use a putty knife at the base of the control console about 2 inches in from the right and left sides.
Lay the putty knife flat on the top of the washer and push it in under the front corner of the control console to depress the clips on the right and left side.
Then fold the control console panel towards the rear of the washer.
Then you can see the cord and how it attaches.
The cord part number is 285800 and cost about $30.00.
Aug 08, 2010 | Kenmore Washing Machines
Atari 2600 problem with left control plug on console
Well maybe the controller ports need to be resoldered then try soldering then with a solder iron.
Nov 21, 2009 | Atari 2600 Console
I need the electric plug in cord for the large 7 qt. G.E. electric skillet. I do not have the model number anymore
I have a used eletric cord and a glass top for a G.E. skillet not sure what size my skillet was. It has model stc-1 and pr02 on the back.It has a dial with the range of warm to 400 and the cord is 32 inches long.Please let me know if you still need one, leg broke on skillet but still have cord.
BILL
Mar 29, 2009 | Rival S160
Atari 2600 jr. console + paddle controls = Don´t work !!!
get a refund for the item
then buy a new console
Sorry but thats the only way your gunna get this to work :(
pls rate.
Dec 17, 2008 | Atari 2600 Console
Atari 2600 Console Logo
87 people viewed this question
Top Atari Video Game Consoles & Games Experts
Reggie brown
MegaByteMe
MegaByteMe
Nikki  Mclean
Nikki Mclean
Are you an Atari Video Game Console and Game Expert? Answer questions, earn points and help others
