Question about Kenmore 62642 / 62644 / 62649 Microwave Oven
Turntable doesn't turn
Just installed this microwave, and everything works except the turntable. I took the motor out and it works fine when you apply power. My multimeter showed no power at all going to the lines.
Tried it with turntable 'on' and turntable 'off'.
Tried switching out the door closed sensor switch with the one for the lights (which work) no luck.
Any ideas? The wiring seems to be secure...
  • kaanestad Feb 05, 2008
    Thanks for the input, I was afraid when the motor checked out that this would not be an easy problem!
    Unfortunately, I bought the unit "NIB" from a contractor who had a couple extras after doing a new subdivision - great price, but now I'm unable to use a warranty I believe.
    It looks like replacing the whole circuit board is about $150-175, which is more than I paid for it! Any chance I can try replacing just the relay on the board? Its a Kenmore, model 8162.
    Thanks again!
    Scholar:
  • 43 Answers
If you have a Touchpad Switch for Turntable On, Turntable Off . Then either the Touchpad Switch is defective, or the Turntable Power Relay is defective. Both are part of the Control Panel.No easy fix, Just replacement.
Posted on Feb 03, 2008
  • Totalwreck Feb 05, 2008
    Get with the "Contractor". Perhaps he will exchange the unit, or set up a "Warranty" repair.
    Possability of you repairing the Control Panel, unless you have extensive Electronic, Printed Circuit Knowledge, is Remote.
    Good Luck!
  • 23 Answers
If you just purchased and Installed the microwave, I would call Sears and tell them what is happening, generally, it would still be under warranty if less than a year old. If its a countertop model, you may have to take it in, otherwise they should come to the home for the repair. I would also NOT indicate that you have looked at it as that would void your warranty.
Otherwise, it seems like the problem could be, a) touchpad , b) a relay or c) the main control board
I have a Cuisinart cmw-100 microwave everything works except for the turntable. any suggestions?
Order a new turntable motor. Turn the microwave upside down and you can see the little door in the center where you can install it. Pretty easy, really.
Apr 18, 2017 | Cuisinart Microwave Ovens
Microwave lights, clock, and everything works except when you press start, it just counts down like its cooking, but the microwave is actually not on. No hum as usual or plate rotating. It just counts...
Hi, one of the most common reasons why the turntable won't rotate is that the microwave isn't clean. The turntable guide and carousel can get sticky, preventing the turntable from properly moving. If you have built-on food particles or liquids, fill a bowl with 2 or 3 cups of water and 1 tsp. of liquid detergent and lemon. Run the microwave for about 3 minutes. Clean the microwave with a cloth, including the base of the turntable, guide, carousel grooves and microwave base. Your microwave turntable won't rotate if the grooves on the base of the turntable do not sit right on the carousel. Also, check the position of the turntable guide. Place the guide directly under the turntable. Remove the turntable, and then reposition it into the carousel grooves.
Motor The carousel motor is located beneath the base plate of the microwave. If the carousel isn't turning at all, check the motor. Disconnect the microwave from the power source, and remove the turntable, guide and base plate. Try turning the motor to see if it's just stuck. If it doesn't turn freely after a few seconds, examine the motor to see if it's burned out or corroded. Use an ohmmeter to see if the motor has continuity. If not, you must replace the motor.
Bushings The drive bushings are plastic components that sit underneath the cooking plate. Remove the plate, and examine the bushings. Use a magnifying glass if necessary to see if any debris is caught in the plastic. Clean the bushings, and reinsert the plate. Turn the microwave on to see if it rotates. If the bushings are extremely worn or if some of the plastic is broken off, you need to replace it, which is a complicated repair for consumers. Contact a service technician for assistance.
May 07, 2011 | Amana Radarange Microwave Oven
Turntable won't turn in the microwave
look for supply to turntable motor if supply is coming on motor and it is not moving it means motor is faulty
Jun 23, 2010 | Danby DMW1146SS Microwave Oven
Everything works except turntable and does not heat up
you have a bad turn table motor or broken coupling.remove the dish does it turn?if yes motor is stripped ,make sure plastic coupling does not pull out .You can access the motor from underneath unit 6-8 screws and the panel swings down for easy access (common problem)Please rate my answer :)
Dec 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave turntable doesn't turn. Everything else
The turntable system typically consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can find links to helpful exploded view diagrams and part ordering help here.
But if you've recently had trouble with the cooktop lights, then the control board may be damaged.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Nov 28, 2009 | Frigidaire Microwave Ovens
My turntable stopped rotating on my GEJVM1490 for no reason. everything else works fine, any suggestions?
There is a small motor underneath the microwave which turns the plate or turntable around.
If this is faulty then you will need a service agent to repair it.
Jun 17, 2009 | GE JVM1440 Microwave Oven
Em-s3577s uk 2 wont turn
Remove the turntable plate and check the motor coupling gears underneath, if motor coupling is fine, then replace the turntable motor.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 19, 2009 | Sanyo Microwave Ovens
Maytag Microwave 1150 Help
Check first the motor coupling under the turntable, if that is not the problem , then test and eventually replace the turntable motor.
Click here and select model to get parts and diagrams.
Apr 05, 2009 | Maytag MMV4205 Microwave Oven
Kenmore 62642 / 62644 / 62649 Microwave Oven Logo
181 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
