Question about Technics SL-1210 Turntable
Warped record sound?!?!?!
Sounds like most  records are slightly warpped, but when I took them back, they played fine on ALL other tables.  It is very annoying.   My best description is that it sounds like phasing issues but I don't think that is possible.  Also, the pitch goes up and down in rapid succession over and over, making everything sound warbly(warped).  My tables are new.  I've tried changing the angle on my needles from 0 degrees alll the way up to 20 degrees, with no audible bettermen, as well as changing my anti-skating and performing several tone arm adjustments, still to no avail.Please give me a sloution or multible troubleshoots to help!      Thank you for your assistance!
  • 515 Answers
Go to the following reply to your original post:
http://www.fixya.com/support/t303119-technic_sl_1210m5g_problem
Posted on Feb 24, 2008
2 Suggested Answers
djproaudio
  • 515 Answers
SOURCE: 1210M5G- warped sound on most records.
I answered here:
The turntable on the Crosley I have just brought,spins round unevenly(up and down),is this a problem as it plays some records ok but will not play others.
The platter should be level. If it is not then it could either be warped, by oil, heat affecting in the past. Or just faulty. Even if a warped turntable plays a record OK, it could damage it, as it is so easy for a record to be damaged, it could cause a scratch on the record. It should be checked out.
Feb 23, 2015 | Crosley Cruiser 3-Speed Portable Turntable...
Crosley CR249 warped table
Sounds like you need a new platter. Has the platter worked OK before or has it always been like this?
I suspect you might have to contact Crosley to see who supplies parts.
Jan 10, 2013 | Crosley CR249TA Turntable
How to fix warped records?
There is no easy fix for warped records
Dec 28, 2012 | Crosley Director CD Recorder Turntable...
One side of my vinyl record will play fine but the other side won't spin right and the needle gets stuck on the record
The only thing you can do is clean the record with cleaning fluid. You will find special cleaning fluids for records on Amazon. If the record is warped you can try a weight pressing down on the record. But sadly if a record is warped bad there's no real cure.
Dec 28, 2012 | Crosley 0187SST Turntable
Lp starts off sounding good..shortly after sounds like a warped record.
It would sound like the speed control is not functioning and changing speed up and down. That might sound like a warped record as you describe it. You can try moving the controls and cleaning them with a commercial contact cleaner.
Nov 09, 2010 | Technics SL-BD22 Turntable
My Samsun 130 recorder says unable to read disc. I;ve tried DVD-R, DVD+R, DVD-ROM movie, & a CD.
i bought a lens cleaner disc, and i took it in for repair at a local place. some plastic part had warped from the heat of the machine. part replacement and cleaning for, i don't remember what. $30 or $40. turn it off when you're not using it. use a second machine for playing and save this one for recording.
Feb 20, 2009 | Panasonic DMR-ES25 DVD Recorder
Teac P-988 Everything sounds slow/warped
not passing the "wow and flutter" specs, eh?
The most common cause of this is a loose or defective belt. An inferior belt will have varying thicknesses along it's length. When it hits a skinny part, it will slow slightly. When it hits the thick part, it will speed slightly. Overall effect is that the record sounds warped.
needledoctor.com has got some good stuff.
Jun 12, 2008 | Teac P-988 Turntable
Pitch out of Tune
That is a strange issue. Not sure what could be causing this. Are you describing your issue correctly. Or do the records sound warped? If they sound warped, check to make sure that your voltage setting is set correctly for your area (115V or 220V). This is a switch located underneath your turntable platter. Just make sure you power off your unit before making the switch.
If this is not the issue, then I have no clue what you are talking about, as I've never hear about this on a 1200 turntable, and I work on them for a living.
Please be even more specific, or if you can, give us a call here @ the shop, and maybe play a record for us. Perhaps we can walk you through it over the phone. 1.877.357.7677 ext 1
- DJPROLAB
Feb 11, 2008 | Technics SL-1210 Turntable
I answered here:
Feb 02, 2008 | Technics SL-1210 Turntable
Power light and inconsistent speed
Ya, it does sound like a power issue. Unfortunately, for the cost of this model, it might not be worth getting repaired, although I am a big fan of recycling (let's reduce our waste!). As a service tech, I am forced to tell you that the cost of the repair will be around the $80 range, near the cost of this unit. Also, Numark does not provide much support for this unit. Parts are very hard to obtain from them, wait time is anywhere from 8-12 weeks. So, it's a matter of deciding what you want to do. Here are your options: 1) Spend the $80 or so (might be cheaper in your area - i'm in NYC) to get it fixed 2) Sell it to someone, tell them of the problem. Or better yet, give it to someone, and the cost of repairing the unit will be enough for them to have bought the unit. 3) Turn in to an elaborate paper weight! But please don't just toss it out. If anything, please drop it off at a plastic recycling plant. Lots of plastic in this thing!
Aug 31, 2007 | Numark PT01 Turntable
Technics SL-1210 Turntable Logo
1,055 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
